HC making a weird scraping sound - any ideas??
Discussion in 'SRT Hellcat General Discussions' started by Hubbs, Apr 26, 2016.
  1. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    Today when I was driving about 5-10 mph in a parking lot I suddenly started hearing a pretty loud scraping sound form under the car. I had the windows down, but still couldn't tell exactly where it was coming from.
    If I were to guess, it's brake related judging by the type of sound and how it changes with vehicle speed. My other thought was something dragging on the driveshaft or on the ground. It sounds a lot like dragging the edge of sheetmetal on the ground.
    I got down on one knee and looked under the car from each side, but couldn't see anything unusual.
    What I do know is:
    It's not engine related (or engine speed related).
    It IS vehicle speed or wheel speed related.
    It doesn't seem to be affected much by hitting the brakes.
    It does not sound like clicking rotors.
    I can't feel anything through the steering wheel or seat tied to the sound.
    The fender is not dragging on the ground. (ha)
    Since I didn't find anything obvious, I drove around a bit at slow speed braking, accelerating, etc. trying to figure it out. After about a minute of this it suddenly went away.
    If it keeps doing it, I'll try to get a video to capture the sound. I want to avoid the dealership as much as possible, so I'm not heading straight there! o_O
  2. ciphros
    ciphros Gold Member
    Mar 13, 2016
    908
    457
    513
    Tri-cities WA
    Probably a stone caught in the caliper. If you have a friend that can listen, should ebsd able to isolate which wheel.
  3. Robocop1127
    Robocop1127 Silver Member
    Aug 26, 2015
    380
    117
    Pittsburgh,PA.
    It sounds like it's brake related. One of your calipers could be hanging up and sometimes a collapsed brake line is the cause for the caliper to remain as if the brakes were applied thus causing the pads to rub against the rotor. Seen it many times over & over on the SRT8 product line of vehicles.
  4. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    But why the noise? Rotors are about the same temp side to side, so don't think it's a caliper...but good idea.
  5. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    Hmmm, good idea as well. Since the sound just stopped suddenly, I'm betting you're right!
    Thx guys!
  6. TallCool1
    2,435
    825
    Pacific NW
    Capture sound, share.
  7. Catscratch Fever
    Catscratch Fever Silver Member
    Jul 10, 2015
    603
    112
    I'd say your rear differential. Low speeds like 5-10 mph while turning. Go to a large empty parking lot and do slow figure eights.
  8. TallCool1
    2,435
    825
    Pacific NW
    If it comes back put in neutral or disconnect procedure like you would during tow. Push the car usually you can hear something outside if its wedged in a caliper at any speed with engine off.
  9. Robocop1127
    Aug 26, 2015
    380
    117
    Pittsburgh,PA.
    If a caliper hangs up in an applied condition the pads will drag causing the scraping sound. Luckily, it's no longer making the sound but if a rock or anything else was caught in the caliper I'd be looking for damage to the rotor now but good luck with things.
  10. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    I will if it comes back!
    No, this is a harsh scraping sound, not a growling shutter like sticking clutches. I'm familiar with that sound! It also did it while going straight. Thx for the thought though.
  11. pivotal
    pivotal Senior Hellcat Member
    Mar 24, 2016
    122
    35
    Silver Spring MD
    I'm hearing something similar. It happens at low speed - especially in 2nd gear below 20mph. It goes away when I press in the clutch - is noise from the clutch/flywheel normal in this car?
    I'll try to take video as well, but I'm not sure how much of the sound will be picked up.
    Matt
  12. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    Hmm, I'd say NO. Could it be your throwout bearing?
  13. pivotal
    Mar 24, 2016
    122
    35
    Silver Spring MD
    It's possible, but what's more confusing is the noise is not consistent. It only happens some of the time - usually at the end of a 45-60 min drive (my normal commute). I'll have the whole car looked over in a couple weeks.
    Matt
  14. spbmopar
    spbmopar Silver Member
    Apr 1, 2016
    248
    108
    113
    I vote for a stone stuck in the caliper backing plate. Jack it up and spin the wheels, i'm sure its something simple.
  15. pivotal
    Mar 24, 2016
    122
    35
    Silver Spring MD
    I'll take a look at that - thanks for the suggestion.
    Matt
