HC pops and shudders in first gear. Anybody else have/had this issue?
Discussion in 'SRT Hellcat Maintenance' started by BLKCAT22, Aug 9, 2015.
  1. BLKCAT22
    BLKCAT22 Rookie
    Jun 6, 2015
    4
    Just started yesterday. M6 with 900 miles on it. Really sounds and feels pretty bad when in first gear.
  2. chuck
    chuck Gold Member Hellcat Car Club Gold Supporting Member HCC National President HCC Charter Member
    Jun 22, 2015
    2,452
    783
    348
    North East Ms
    No I got 1100 miles no problems yet on anything I haven't gave it all it has but have went through the gears pretty good but no problems . I do make sure I'm straight when I push the gas in sport mode . Learned alittle with my SS camaro RS 426 HP nothing like the hellcat but will turn you around in a second with a M6 if you got traction off and not straight you couldn't drove a nail up my butt lol in my hellcat I don't shift untill I got good rpms up I try to keep rpm up when I'm shifting gears just my habit
  3. cruizinrc
    cruizinrc HCC New Jersey State President Hellcat Car Club HCC Charter Member
    Jan 26, 2015
    875
    401
    Does it only do it if your trying to take off easy my car try's to stall all the time if I go easy like I can't drive stick I've driven one other m6 and his car was way better then mine when driven easy
    Thinking of bringing to dealer myself
    Just getting in my garage is a joke as I have to go over my floor lift and stall it all the time
    Ron
  4. B5 Blue
    1,743
    Any codes?
  5. hellzya
    hellzya Silver Member
    Feb 27, 2015
    599
    109
    What you discribe almost sounds like an ignition issue whether it be coil plug or even timing. Take it in let us know what is the cause.
  6. BLKCAT22
    BLKCAT22 Rookie
    Jun 6, 2015
    4
    No codes at all
  7. BLKCAT22
    BLKCAT22 Rookie
    Jun 6, 2015
    4
    Will dp
  8. fnkychkn
    Jan 24, 2015
    1,450
    558
    423
    plastic take-out container
    what RPM?
  9. redhemi
    redhemi Gold Member
    Dec 9, 2014
    469
    222
    southeast Pa.
    I think 1st gear is too tall,very easy to stall.My pedal grabs when almost all the way out and no free play! At a idle with clutch out mph is 8,who can pull into a garage at 8mph:eek:
    After some research i found out no pedal/linkage adjustment so i went out for a few hours with the radio down and got use to it.:cool:
  10. chuck
    Jun 22, 2015
    2,452
    783
    348
    North East Ms
    Mine grabs as you let out just a little on clutch so you right yours need adjusted no problem taking off in mine I usually drive in sport mode
  11. dHL0L
    dHL0L Gold Member
    Apr 7, 2015
    304
    158
    Racine, WI
    Mine sort of does that going into second if I don't let everything warm up. For clarity, I start car and immediately drive out down the road to the stop sign. Take a right and shift from 1st to second and it sort of shudders. Might do it one more time at after next stop sign but then it goes away. If I let my car sit at idle for 3-5 minutes before going after initial start up, it doesn't do that.
  12. chuck
    Jun 22, 2015
    2,452
    783
    348
    North East Ms
    Yes that's good I been driving M6 for years and I usually run a long distance in first gear not running high RPMS just to let trans fluid to warm up and it shifts. Better just something I do especially in cold weather . My last car was SS camaro convertable RS 426 HP M6 and did same with it no problems I like my trans fluid to warm some before I shift gears
  13. chuck
    Jun 22, 2015
    2,452
    783
    348
    North East Ms
    My car also runs about that fast in first gear I just let out a little and coast in garage but my clutch grabs when I let it out alittle quick grab not much slack atall when I let out you best be ready to go
  14. Lumpy53
    Lumpy53 Silver Member
    Nov 25, 2015
    354
    62
    Janesville wi
    Is it rear end hop when power is applied?
  15. Linda's Hell Cat
    Linda's Hell Cat
    Record Holder
    Fastest HC Charger/Record Holder
    Oct 28, 2015
    672
    613
    568
    Bucks County Pa
    Have you paid attention to your gas tank and the level you are at. I'm not sure if this this could happen with an M6 or without a tune. But I had this popping happen if the dash light read low miles. Not First gear, but First gear shifting in other cars I owned seem to take alot of gas once you get it in gear and wanting to go fast.
    I'm thinking you might be having fun and taking off pretty quick.
    Which caused a popping sound in my car with my car at low miles going down the track.
    See if this happens at a half tank of gas.
    Linda :)
2011 dodge durango 1st gear shudder when warm
hellcat firts gear
