Hellcat Challenger Transport 24 foot enclosed trailer loading will it rub???
Discussion in 'SRT Hellcat General Discussions' started by Helldog, May 13, 2016.
  1. Helldog
    Helldog Silver Member
    Oct 16, 2014
    188
    55
    Hopefully tomorrow I will finally purchase a Challenger Hellcat. I have a 24 foot enclosed car hauler and am concerned that the front of the car will be too low for me to load it without rubbing or removing something. Any advice?
  2. Shadow
    Shadow Silver Member Hellcat Car Club
    Feb 13, 2015
    140
    49
    Texas
    I used a set of ramp extenders to get mine in and out of the trailer, and it worked perfectly. Would have rubbed the splitter without them. Also had it on a roll back wrecker once and we used some 2 x 6's to get past the pinch point of the splitter rubbing. Get a few short boards handy, if you don't have access to ramp extenders, take your sweet time with someone guiding you that has a brain, and you'll be able to get it in and out.
  3. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,149
    752
    628
    my 2011 srt didnt rub on my lift, but my HC does....so its pretty low...i added some ramp extensions to prevent further damage...id recommend bringing some plywood and a battery circle saw...drive it up slow and if its going to rub add some plywood under your ramp
  4. Top Cat
    Nov 26, 2014
    1,925
    1,084
    768
    Doylestown,Pa
    Picture of the trailer would help, all trailers are different in height so the angle of the ramp is different, you can jack up on the trailers front jack point to reduce the angle.
  5. Sawdust
    Sawdust Silver Member
    Mar 13, 2016
    117
    53
    198
    Green Lane, PA
    Any reason not to just drive the thing home?
  6. JollyRoger
    JollyRoger Gold Member
    Sep 19, 2015
    1,394
    444
    258
    Austin, TX
    Beat me to it Sawdust! Great way to move through your break in period quickly.
  7. Helldog
    Oct 16, 2014
    188
    55
    Potential damage, wear and tear, I have an enclosed trailer why not use it?
  8. Rocket Man
    Rocket Man Silver Member
    Aug 27, 2015
    204
    92
    178
    Lexington Park, Maryland
    ^^^This FTW^^^
    Also, depending on how the wheel wells are configured, it *may* not squeeze between them and/or if they are drive over wells, the angles could be too severe & drag the undercarriage depending on height.
    Be prepared to crawl out through the trunk if necessary if the trailer walls are too narrow.
  9. JT's shaker
    JT's shaker Silver Member
    Mar 20, 2015
    155
    49
    Northeast PA
    I hauled mine home in my 24 foot Haulmark trailer, without any issues. However I did raise the front of the trailer with the jack to minimize any possibility of the splitter hitting the ramp. I had to modify the inside of the trailer later, in order to utilize the side exit door. I had to raise the car by installing 2 X 12 boards on the floor, so the Cat would ride up on them. It was necessary to cut them on an angle and stagger them like a ramp so they wouldn't hit the splitter. Screwed them to the floor, and it's worked well for me.
  10. Sawdust
    Mar 13, 2016
    117
    53
    198
    Green Lane, PA
    I guess that's understandable.
    As TC mentioned a picture would help, or maybe manufacturer/model. I have a Haulmark enclosed race trailer which the hemi'cuda clears, barely. It is as low as the HC but I had to put blocks and plates where the wheels sit to have the door clear the trailer wheel wells.
  11. Challengerfarmer
    Challengerfarmer Silver Member
    Sep 20, 2015
    144
    44
    I have a Sharp 24' enclosed trailer. Had it special made so the left side escape door is right in front of the fenders.
    Loaded the Hellcat it in last weekend. It was close on the front and also the mirrors are a tight fit going past the door opening, but no problems. I have the nose of my trailer set fairly high, which helps lessen the angle. Then it levels out once the car is loaded since the front of the car is about 18" from the front of the trailer. Needs to be that far ahead so the car door is in line with the trailer door. Strapping it down is the fun part.
  12. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    7,908
    5,473
    963
    Good morning and congratulations on picking up your hellcat. In agreement with TC here and good idea to post this information to make sure everything goes OK
  13. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    7,908
    5,473
    963
    The dip in a a driveway or a business like a gas station with poor levels isn't good. Our cars are lower and the splitter will rub or even break if we are not careful when pulling into the things I mentioned. I agree with using it however experience tells me this could be a fit issue by inches if it too low going into trailer
  14. Redboots
    Redboots Silver Member
    Nov 30, 2014
    549
    134
    Southern Utah
    Just drive it. We just picked up a '16 and drove it 500 miles home. No problems except a few bugs. Its a car.
  15. Helldog
    Oct 16, 2014
    188
    55
    image.jpeg It's a Cargo Craft Dragster. The ramp measures 8 feet long and over the 8 feet it rises 16 inches. I have 82 inches between the fender wells and the wells are 10 inches tall. Here's a pic of the ramp. I can't just drive it because it's only me so I don't have anyone to drive the other vehicle or drop me off.
hellcats 14 trailers
