Hellcat displacement...
Discussion in 'SRT Hellcat General Discussions' started by deroiad, Dec 18, 2015.
  1. deroiad
    deroiad Rookie
    Nov 24, 2015
    17
    1
    Question for those who are techies...The HC engine displacement in liters is 6.2 which translates to 378.35 cubic inches but most refer to the HC 6.2L as a 392. Can anyone speak to why it may be rounded up so high or is it just false info.? thanks
  2. Hemi Rocket
    Hemi Rocket Gold Member
    Sep 27, 2015
    1,488
    Albany NY
    Bad info... it 376 CI (rounded) I've never heard of anyone refer to it as a 6.4 or a 392!;)
  3. Zebug
    Zebug Gold Member
    Nov 11, 2014
    2,618
    866
    628
    Houston Texas
    Agree.. The 392 is one model lower on the challenger scale.
  4. Hemi Rocket
    Sep 27, 2015
    1,488
    Albany NY
    I wouldn't call it one model lower on the Challenger scale... I would refer to it as model lower on the HP scale! :D Still a very sweet car with many of the same or similar features that are on the Hellcat! When I was struggling to get the HC... I had a hard time passing on one... Had to force myself to just say no!
  5. CrewDoggie
    CrewDoggie Gold Member
    Dec 1, 2015
    135
    65
    278
    Tehachapi Ca.
    All I can say is that the Hellcat engine was originally a blown 392 during testing. 80% to 90% of the engine was changed during the R&D according to many publications that I have read. Example: Car & Driver, forums, SRT.com, Motor Trend.....etc. several slave variants of the 392 were used as test beds to achieve the full rate production blown 6.2 that we know and love today as the Hellcat engine.
  6. rwhite692
    rwhite692 Gold Member
    Jul 17, 2015
    646
    257
    Central Valley, Northern California
  7. Halfshaft
    Halfshaft Silver Member Hellcat Car Club
    Oct 30, 2015
    184
    86
    178
    Waxahachie, Texas
    I read some where to get lower compression on thoso drop forged pistons they had to offset on the dropped forged crank which destroked the 392 from 6.4 to 6.2 so everything would fit in the already proven 392 engine block, supercharger needed lower compression to work. To me its just known as Hellcat engine. Also tack on dash redlines 5800 that's where 707 HP is established, at that setting Hellcat engine just barley qualified inside the emission standards, changing the RPM to 6250 nets approx. 735 HP and pushs emissions on border line, that's challenger Hellcats are delivered default to 5800 rpm setting.
    • Funny Funny x 1
  8. jaque
    jaque Silver Member Hellcat Car Club HCC Charter Member
    Apr 6, 2015
    532
    140
    chicagoland
    so is the hellcat motor a 6.4?? with 5.7 -6.1 crank?? from what im reading seems like.. thought the 6.2 was its own animal. guess the 6.4 block was used??
  9. deroiad
    deroiad Rookie
    Nov 24, 2015
    17
    1
  10. CNYHC
    CNYHC SRT Hellcat Supporter Gold Supporting Member
    May 25, 2015
    1,183
    499
    258
    Central New York
    Check out the above link^^^^ comment #6. It tells you all about the engine and the differences for the Hellcat.
  11. Halfshaft
    Oct 30, 2015
    184
    86
    178
    Waxahachie, Texas
    Yes they used the 5.7 crank but drop forged it to make it bullet proof, used the same Apache 392 cast iron block, combination yield 6.2 liter, cubic inch depending on how calculated is 376 or some say 378
  12. deroiad
    deroiad Rookie
    Nov 24, 2015
    17
    1
    Hey guys, thanks to all that replied but with all the inputs still a bit confusing and see why now. Special thanks to rwhite692 for the link to the great article (We take a hard look at dodges paradigm...); Halfshaft for his info. on the 'destroked 392' and jaque stating the 6.4L. Well, with the info. from these 3 guys and the article, it appears that the beginning of the Hellcat engine, as we know it today, is essentially the Apache 6.4L (translates to ~392) which is why I heard of the reference from the beginning. There is information in the article (which I have partially included below) that describes how the displacement difference between the 6.4L and the Hellcat 6.2L is all in the 'stroke' (3.72 inches vs. 3.58 inches). A little more complex than one would think. What does it all matter? Not much if all we care about is the endgame 707 HP. But it does address the question of why do some reference the HC engine 'block' as a 392 (6.4L), it's because it started as one. See the whole article which is a good one! or immediately below is part of the article that addresses this. Thanks again!
    From the article - We Take A Hard Look At Dodge's Paradigm-Shifting 707hp Hellcat Hemi (Hot Rod Network)
    Short-Block
    "The engine block is the bedrock of the Hellcat. All 707 of the Hellcat's horsepower get transmitted through the block, which is made of cast gray iron. Outwardly, it looks very similar to the Apache block that underpins the 392, but there are two primary changes—three if you count the standard Hemi Orange powdercoat paint! During development, it was discovered that a significant change in the coolant circuit was needed in order to manage the Hellcat's increased thermal output. Specifically, the water jackets now continue all the way down to a level equal with the piston crown's bottom dead center. Second, the amount of material in the webbing between the bores and the main caps has been increased. Lastly, the piston oil squirters have been retargeted to cool a slightly different region of the piston, which itself is significantly different than the cast piston in the 392 Apache. These revised squirters also have a pressure-sensitive lube valve to shut off flow to them at low pressure; this is done to prioritize volume and pressure to the rest of the lube circuit.
    The difference in displacement between the 6.4L Apache and the 6.2L Hellcat is all in the stroke (3.72 inches versus 3.58 inches), so the rotating assembly is different dimensionally. The Hellcat's shorter-throw forged steel crank is actually machined from the same forging as the longer stroke Apache crank, but because of increased journal overlap, it's stronger."
    • Useful Useful x 2
  13. fnkychkn
    Jan 24, 2015
    1,450
    558
    423
    plastic take-out container
    using the formula [​IMG] X 8, where r = 2.045" (51.95 mm) and h = 3.58" (90.9 mm),
    the results are 376.278 CID or 6.165 L.
    • Agree Agree x 3
    • Funny Funny x 1
  14. Catscratch Fever
    Catscratch Fever Silver Member
    Jul 10, 2015
    597
    111
  15. srtdusty
    srtdusty Silver Member
    Apr 5, 2015
    239
    99
    178
    Good call Hemi Rocket, couldn't agree with you more
challenger hellcat engine block size
dodge challenger hellcat cubic inches
hellcat displacement
hellcat engine displacement
hellcat motor size cubic
how many cu in hellcat
what size is dodge halicat motor in cubic inch
