Hellcat ECU Packages Available
Discussion in 'HEMITUNER PERFORMANCE' started by Hemituner, Apr 23, 2015.
  1. Mills
    Mills Silver Member
    Jan 28, 2015
    762
    190
    Airdrie, Alberta
    I would like to see: Catch-Can (to eliminate the detonation from carryover), 180 deg T-stat (to drop temps and help with detonation) along with a pulley and ECM (and change fans to take advantage of the T-stat). I think the 1st two items are critical to ensure a good baseline from customer to customer to avoid issues and help from a "canned" tune starting point
    I have my doubts about a CAI adding much (Dodge would NOT have left much on the table with something as simple as a few bucks in way of the intake...same goes for exhaust if that comes up), but if it shows to be a measurable improvement (even if only IAT's) - then sure offer it.
    I think with proper tuning time this will be a +100 RHP package.
  2. Hemibuck
    Hemibuck Gold Member
    Jan 9, 2015
    1,885
    445
    WA
    Yes there has to be a pretty good gain to be had with just a tune. Swapping pulleys is not and easy job. Curious to see what they get with just a tune over the next few months.
  3. Gallitos98
    Gallitos98 Active Hellcat Member
    Aug 30, 2015
    106
    36
    28
    Click the link below........
    2015 Dodge Tuning (Important Information)
    HP Tuners is proud to release to the public a PCM modification service that unlocks the 2015 PCMs for tuning. The cost is $249 and can be purchased through the Order Page at the bottom of the page.
    If your tunner works with HP tunner you can upgrade the car with a new custom program.
  4. lucifer666
    lucifer666 Rookie
    Mar 31, 2016
    1
    0
    1
    I use E-85 in my cat no problems what so ever and it works well
dodge challenger hellcat ecu
dodge hellcat ecm unlock
dodge hellcat ecu
ecu change out on hellcat
hellcat performance package
hellcat performance packages
hellcat power package
why richen afr on hellcat produce knock
