Hellcat exhaust leaks !!!!
Discussion in 'General Automotive Discussion' started by mark wizgen, Apr 2, 2016.
  1. mark wizgen
    mark wizgen Silver Member
    Sep 7, 2014
    280
    99
    178
    Dallas, Tx
    I am sure this has been addressed already on this site somewhere but I could not find it.
    I noticed , on my garage floor dark nasty water spots in the middle of
    Where my car is parked. Past experience told me exhaust leaks.
    Sure enough , right under that drivers and passenger seats where the exhaust pipes are clamped together , I seen seen water dripping when I first started my car then it stopped after the pipes got hot.
    I tightened the bolts as tight as u could , even with an electric impac gun and still water drips. I got to cat it up in the air on a lift and felt by the pipes and sure enough, I felt air coming out of the pipes.
    Any ideas on fixing this problem???
    I went to a Muffler place to have it welded and they said it may void the factory warranty. Ugh !!!
    What to do ???
  2. 16SRT
    16SRT VIP Hellcat Member
    Feb 20, 2016
    420
    122
    73
    It's under warranty. Get an expert opinion from your third-party exhaust shop, drop them $40 for taking a half hour of their time, and then head to your dealer for the recommended fix (if any).
    • Agree Agree x 3
  3. Mean707
    Mean707 Rookie
    Feb 21, 2016
    19
    Eaton,Ohio
    I've used permatex ultra copper maximum temp rtv on a leaky exhaust ball and socket joint on my prior GT500 and it worked great. Simply took the clamp off and seperated the joint and applied a small amount around the socket and reclamped. Never had an issue after that.
  4. Mills
    Mills Silver Member
    Jan 28, 2015
    710
    166
    Airdrie, Alberta
    Unless the gap is massive - it will seal itself with corrosion
  5. nocarbutmopar
    nocarbutmopar Silver Member
    Oct 21, 2015
    399
    120
    New Mexico
    Exhaust is Stainless, maybe Carbon
  6. Steven_sbs
    Steven_sbs Browncoats Unite Gold Supporting Member
    Dec 18, 2014
    845
    345
    South Jersey
  7. mark wizgen
    Sep 7, 2014
    280
    99
    178
    Dallas, Tx
    Going to the dealership is a hassle for what could be an easy fix if I can do it myself. I am pretty protective of my car and I seen mechanics abuse cars because I work for car dealerships as a vender for 20 years. Do not trust most of them !
  8. TNCHARGER
    Nov 19, 2015
    1,175
    426
    258
    The mufflers and resonators have small holes to let the condensation out. Leaks around joints is an issue unless the joint is sealing as soon as the pipe gets hot...
  9. mark wizgen
    Sep 7, 2014
    280
    99
    178
    Dallas, Tx
    Had the car running for at least 10 min, and then tried to tighten the bolts. Bolts are as tight as I can without fear of breaking the bolts. I had the car up on a lift and I felt exhaust air leaking out if both pipes right where they connect under the briber and pass, seat.
  10. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,122
    739
    almost every HC has this issue....its been discussed 50x's....black spots under the middle of the car is normal....what you'd expect from a dodge build quality
    nothing to fix
    • Funny Funny x 2
  11. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,454
    466
    258
    The Boonies
    Just get some old coke cans and cut the top and bottoms off. Wrap them around the pipe and secure w clamps. Piece of cake and looks great too!
    • Funny Funny x 2
  12. Catless
    Catless Silver Member
    Feb 2, 2015
    989
    204
    Parkersburg, WV
    If it doesn't leak out, it will just blow out the back - learn to love it.
    • Funny Funny x 2
  13. TNCHARGER
    Nov 19, 2015
    1,175
    426
    258
    What you are describing is an exhaust leak...this is a warranty issue...
  14. mark wizgen
    Sep 7, 2014
    280
    99
    178
    Dallas, Tx
    Guess I have to take the car in to fix this exhaust leak ! Ugh
    Hate dealerships !
  15. 392
    392 Silver Member
    Nov 6, 2015
    568
    82
    arizona
    it's totally normal....don't worry about it....when the engine is cold it will do that....I have 2 other srt's, a jeep wrangler, & a ram.....they all do it.....I went crazy trying to tighten all the clamps....all tight.... water will always find its way.... .
black leak or fluid or drip forums middle exhaust condensation
water leaks after start up challenger hellcat
