Hellcat going into battery save mode?
Discussion in 'Dodge Challenger SRT Hellcat' started by skylane765, May 14, 2015.
  1. skylane765
    skylane765 Silver Member Hellcat Supporting Vendor
    Jan 27, 2015
    249
    50
    when driving at times the hellcat goes into battery saving mode and radio shuts off. I see that the voltage is all good 14.2 volts. If I stop and restart the alert goes away. The battery light also lights up. Anyone have this happen?
  2. B5 Blue
    1,745
    Does it store any codes? Use steering buttons
    Push and release the UP or DOWN arrow button until
    the diagnostic Menu is selected. Then, the Driver is able
    to view engine and emission vehicle faults.
    When you say 14.2 volts is that what it read while indicator was on?
  3. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    701
    154
    McKinney, TX
    That's really weird....doesn't sound normal.
  4. skylane765
    Jan 27, 2015
    249
    50
    No codes. Checked that. Also it is charging?? It does it only once in awhile.
  5. Mopar_Convert
    Mopar_Convert Hellcat Member
    Dec 3, 2014
    74
    San Diego, Ca
    Check your battery connections - they might be loose, someone else had an issue similar.
  6. skylane765
    Jan 27, 2015
    249
    50
    Yes 14.2 v normal. And when in battery saver mode 14.2. Sounds like a SW issue.
  7. fnkychkn
    Jan 24, 2015
    1,494
    606
    greasy cardboard box
    possible IBS (intelligent battery sensor) issue. IBS is mounted to battery negative terminal and monitors current flow into and out of the battery, as well as battery temperature, state of charge and state of health. this information is used by the PCM (powertrain control module) to control the charging system and by the BCM (body control module) to control load shedding functions.
    • Useful Useful x 3
  8. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    70.196059, -148.559760
    Do you know if IBS on these is anything like BMW. On BMW vehicles the type of battery (wet or gel) and the amperage needs to be coded to the car. You also have to reset when a new battery is installed. The IBS needs this info. for best battery life. If the battery is new I believe it let's it discharge a bit more before charging and then the type and amperage also plays a factor.
    For this reason I always use an OE battery and do the coding. Wonder if the Hellcat requires all this or if you can just change out a battery when needed like the 'good old days'.
  9. fnkychkn
    Jan 24, 2015
    1,494
    606
    it resets whenever the battery is disconnected/reconnected.
    from online database article:
    When the IBS is powered up for the first time or is powered after a power disconnection, it enters a "recalibration" phase, where the IBS must recognize the type of battery and its characteristics and state. So in this phase the tolerances on the state functions (SOC, SOF, SOH) are greater than in normal working condition.
    Information the Intelligent Battery Sensor (IBS) send out on the CAN Bus is:
    SOC
    = Battery state of charge (or SOC) is expressed as a percentage. The IBS calculates the SOC based on measured voltage, and charge and discharge rates. Therefore, SOC is not a direct percentage of battery voltage.
    SOH = Battery state of health (or SOH) is the percentage of actual battery capacity compared to the nominal capacity of the battery. As the battery ages and wears, its capacity declines.
    SOF = Battery State of Function: Battery state of function (or SOF) is a calculated prediction of the lowest voltage the battery will drop to during engine cranking.
    When IBS is disconnected from the battery, the device loses its stored memory. When power is restored, the IBS starts a relearn process. Until the relearn process is complete, accurate battery state information is unavailable to other vehicle systems. The IBS relearn process requires two -five normal, operator initiated starts with at least eight hours of engine off time between each start. Usually, the process takes a few days of vehicle operation to complete.
    • Useful Useful x 6
  10. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    Thanks fnkychkn I really appreciate all the information you provide.
    I wonder in this scenario how it knows the type of capacity of the battery and the technology (gel or wet) or if it just assumes OE. I wouldn't think you can really determine this from a sensor but I don't really know for sure.
  11. B5 Blue
    1,745
    Damn you're saying it has what Audi calls a BEM. Do you have readout capabilities from it that lists shutdown stages, last xx drive cycles, current draw (no key on 15 power etc.? Does the battery itself have a serial # that needs to be entered? Bosch makes Audi's do you know who makes Dodge's. Sorry for being long winded but I wrote the book on diagnosis on these for Audi.
  12. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    Hey B5 Blue I'd love to see that book or is it one of these things you can show me but then you have to promptly kill me and take my Hellcat LOL. Good info. for wifey's S5
  13. B5 Blue
    1,745
    Unless you can get into the 19 module with a scan tool (Rosstech will work) and read all the data from the BEM then I can't help me let alone you. And if you did I would have to decipher it for you. Germany doesn't know how it works and I had to argue with them on their shortcomings.
  14. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    Yup, I have Rosstech.... Can't own one of these cars without it IMO. I'll keep that in mind if I ever have issues... Thanks.
  15. B5 Blue
    1,745
    Then hook it up and see if it has "read history data" in 19 module or give me a pic what options you have
battery location 2015 dodge challenger hellcat
battery type for 2016 hellcat
