Hellcat Issues
Discussion in 'Dodge Challenger SRT Hellcat' started by Cleghornm, Sep 2, 2015.
  1. Cleghornm
    Cleghornm Hellcat Member
    Jan 1, 2015
    48
    13
    Just crossed the 500 mile point with my A8 Hellcat. I have had from day one a shimmy at approximately 80 Mph. My dealership sent a technician issue to Crysler, no response 1 month later. Second issue when driving slow I.e. Parking lot the car will sometimes violently down shift from 2nd to first I am assuming. The first time it happen I though someone hit me from the rear. Again has anyone had this happen to them?
  2. Dragon
    Dragon Gold Member
    Oct 16, 2014
    658
    230
    AZ
    first issue sounds like tire balance.....
    not sure about the second issue.....try different drive modes? does it still happen.
    GL
  3. 4510
    May 13, 2015
    751
    169
    Arizona
    Are throwing it into first and dumping the clutch? o_O
    I don't have that problem with my M6! :rolleyes:
  4. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    If your trans is in track mode, it will feel like someone is bumping you, at least that's how it is in my car,, it's a A8
  5. BonhommePerformance
    BonhommePerformance Rookie
    Nov 17, 2016
    0
    1
    What was the problem? My car does the same..
  6. Code3100
    Code3100 Silver Member Hellcat Car Club
    Sep 6, 2015
    268
    88
    178
    Second issue is common for me, when slowing down from 6th or 7th to 4th or 5th. Gives me a hard downshift.
  7. rayzazoo
    Nov 8, 2014
    3,875
    1,583
    818
    Have the carrier bearing inspected on the driveshaft.
  8. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,909
    1,331
    498
    Virginia
    I thought there was an update to change the downshift to help soften it out?
    What mode were you in? Street and Sport should be pretty tame, Track will be more aggressive by nature!
  9. BonhommePerformance
    Nov 17, 2016
    0
    1
    No mather the mode look like it stuck in second gear before a dead stop and bamm it goes in first a the last min. Almost looks like somebody hit me in the back.. weird thing
  10. BonhommePerformance
    Nov 17, 2016
    0
    1
    I will let the adaptive doing is job for a couple of miles..
  11. Blackbeast
    Blackbeast VIP Hellcat Member
    Sep 26, 2016
    823
    201
    73
    I have nothing like that...better take it in and show it to Dodge...
  12. Slowpoke387
    Slowpoke387 Gold Member
    Jan 31, 2016
    1,714
    515
    423
    Enfield, CT
    Tires are out of balance. My HC did the same thing. Had em rebalanced and good to go. Factory does a shit job of balancing.
    Totally normal downshift. My 2015 SRT had that and my 16 HC has it. In default it doesnt do it. I drive in custom mode which has track trans selected and it does it almost every time. Feels like getting bumped in the rear bumper when slowing to a complete stop. Was told something about the converter locking up causing it in track mode. Guess it needs to do that. Put urs in default mode, no track trans selected. I'll bet it doesnt happen.
    They really should warn buyers about it because i was freaked out when it first happened in my SRT. Now i know its normal.
  13. Blackbeast
    Sep 26, 2016
    823
    201
    73
    Mine were unbalanced also....in fact I just had them road force balanced at a Goodyear shop and I was able to watch them do the whole process. I never had that shifting problem...
    Did you have vibration of your steering wheel at around 75 MPH?
  14. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,483
    473
    408
    The Boonies
    mine were horribly balanced as well. it took several tries on three different balancers before they got it correct
  15. SRT Fan
    SRT Fan SRT Hellcat Supporter Gold Supporting Member
    Apr 27, 2016
    119
    74
    198
    Southern Oregon
    There is a TCM software update for that 2-1 downshift problem.
    Back in April when my car was new, I had the same problem. The transmission shifted so hard from 2nd to 1st that the beast lurched forward... exactly what you do not want when creeping forward slowly into a parking spot.... or stopping for someone in a crosswalk... It got better over time as the TCM learning process took place, but it still thumped into 1st gear unexpectedly once in a while.
    What griped me was that even though I called this problem into SRT Premium Care as a safety problem, I was not notified when the TCM software update was released. I also learned that Service Bulletins are not displayed on the Vehicle Health Report website for the car... and neither is the availability of PCM, TCM, or UCONNECT software updates. Only recalls and current "campaigns" (a campaign is a vehicle problem that is not a safety concern). Although, you can easily check for UCONNECT update availability with your VIN at the "driveuconnect" web site.
    The TCM update was apparently released in June. I found out about earlier this month and had the dealer flash the TCM a couple of weeks ago. This definitely fixed the 2-1 shifting issues. The transmission did not seem to start over from scratch with regard the TCM learning evolution - which was great because I expected that to be the case.
