Hellcat Low Oil - Dipstick Question
Discussion in 'SRT Hellcat General Discussions' started by CubeMan, Aug 28, 2015.
  1. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    1,985
    473
    403
    Westchester
    So I monitored my hellcats oil at 3k miles and the dip stick was filled, but i ticked 4k miles yesterday and all of a sudden my dipstick doesn't even register any oil.
    Steps taken
    1. Start car, let it run for a few minutes
    2. Turn off car, pull dipstick (Its covered with oil)
    3. Put dipstick back in after cleaning it off
    4. Pull dipstick out, nothing.
    Should the dipstick be bone dry after a second pulling? My entire car history says no, i can't find anything in the manual stating the dipstick besides just checking oil levels itself.
    Dropping it off in the dealer in the morning, This car gets driven hard (High triple speed digits reached multiple times). Will update you guys in the morning.
  2. Catless
    Catless Silver Member
    Feb 2, 2015
    968
    199
    Parkersburg, WV
    So you are saying that for the first 3K miles it burned no oil and then from 3-4K miles it burned what 2 Qts at least?
  3. CubeMan
    Dec 31, 2014
    1,985
    473
    403
    Westchester
    Correct.
  4. Catless
    Feb 2, 2015
    968
    199
    Parkersburg, WV
    Did you add oil? I don't think I would want to drive it with the oil off the dipstick and therefore at a completely unknown level.
  5. CubeMan
    Dec 31, 2014
    1,985
    473
    403
    Westchester
    It's sitting in the garage until I call the dealer, Took photos and a video. I'm going to fill it before i go up there, but i need documentation for them and myself to show the engine is burning oil like a mad man.
  6. purnrg
    purnrg BANNED
    Apr 12, 2015
    2,619
    1,154
    588
    It only takes 1 litre when the stick show nothing, I see the same thing but no evidence of excessive oil consumption or leakage except the dipstick, I'm keeping an eye on it every time I drive
  7. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,608
    507
    423
    Chattanooga, Tennessee
    I have 1078 miles on the odometer. Yesterday I checked the oil for the second time. Just barely touching the very bottom of the dipstick. Added one quart and brought it up to top of the xxxx. I'm driving it pretty hard right now, so not surprised. FWIW
  8. Grey Eagle
    Grey Eagle Rookie
    Apr 22, 2015
    24
    18
    New York
    Have had a similar experience. I added a quart...and keep an extra in the trunk. Keeping an eye on it.
    As an aside, I am buying the oil from the dealer and having them put the oil in so that at least I have a record of it if this turns out to be a problem.
  9. purnrg
    purnrg BANNED
    Apr 12, 2015
    2,619
    1,154
    588
    My 2008 did the same thing for the first 10k as well, then I started using a 10/40 oil instead of the 0/20 as recommended
  10. Catless
    Feb 2, 2015
    968
    199
    Parkersburg, WV
    I thought the oil recommendation for SRTs has always been 0W-40 not 0W-20?
  11. Catless
    Feb 2, 2015
    968
    199
    Parkersburg, WV
    Let us know what they say.
  12. Snappycat
    Jan 22, 2015
    3,464
    1,034
    628
    The I.E. So. Cal
    Same thing here. I check my oil on a regular basis...always looked good. At 2800 miles I checked it again and stick was dry...nothing. Added a qt and it was back to normal. Took it in for its first oil changed later that day and tech said it is not uncommon for these engines to use a qt every 3-4K miles. No leaks or burning. If it gets excessive, an oil consumption test may be necessary. At $9.50 a qt/ the oil is not cheap. Using Penzoil synthetic 0-40 made for SRT motors.
  13. CubeMan
    Dec 31, 2014
    1,985
    473
    403
    Westchester
    LMFAO, brand new motor and it's common to just burn a qrt? I've owned 6.1's and 6.4's, none just magically sipped up oil like it was crack
  14. CubeMan
    Dec 31, 2014
    1,985
    473
    403
    Westchester
    Dealer gave me 2 quarters, that brought the dipstick to 3/4th full. So math wise it's burned about 2.25 quarts? That's crazy, No signs of oil leaking
  15. Lord Hellcat
    Jan 6, 2015
    1,559
    686
    UK
    I've checked the oil hot and left to stand for five minutes and stone cold. No difference on the stick so I always check mine cold. Hope you get it resolved and do not have any issues
2016 challenger hellcat oil low
brand new hellcat low on oil
hellcat code low oil
hellcat dipstick
hellcat oil quarts
no oil on hellcat dip stick
oil dipstick hellcat
