hellcat MAP sensor for Water/Meth?
Discussion in 'SRT Hellcat Performance' started by upnorthstar, Jun 9, 2015.
  1. upnorthstar
    upnorthstar Silver Member
    Mar 2, 2015
    532
    143
    Anyone know exactly which MAP sensors are used? I'm trying to figure out the best signal to tap & the appropriate scaling for water/meth injection..Note: I can only calibrate flow using IPW or MAP signals for the Aquamist HKS-3, and prefer to go with MAP...
    The MAP options for this circuit board are...
    a: Absolute (can be used for any sensor with 0-5V...ie:TPS)
    b: 2.5 bar MAP sensor (converts a 2.5 bar MAP to read from atmospheric to 22psi full scale 0-5V output)
    c: 3.5 bar MAP sensor (converts 3.5 bar MAP to read from atmospheric to 36psi full scale 0-5V ouput)
    just doing for cooler combustion temps, 50/50 mix, not tuning for it ( don't want to constantly worry about running out)
    thoughts?
    thanks
  2. B5 Blue
    1,745
    I'm confused. Are you trying to tap into the map wiring physically? IPW? Pulse width? Anyhow MAP should be 3 wire power/ground and signal just need to see if power is 5 volt reference or battery power.
  3. upnorthstar
    Mar 2, 2015
    532
    143
    Thanks B5...Yes physically splice the MAP sensor...trying to figure out which sensor this car has...so I can set the controller for an accurate reading...
  4. B5 Blue
    1,745
    I don't know which type it is ask fnkychkn or NX91Notch I just know the wiring
  5. SRTFighter
    SRTFighter Silver Member
    Mar 21, 2015
    725
    151
    Houston, TX
    Old thread...any updates? I am also looking at MAP/MAT upgrades and possibly water/meth.
  6. upnorthstar
    Mar 2, 2015
    532
    143
    Here's the Fuel Wiring diagram if you need it
  7. SRTFighter
    Mar 21, 2015
    725
    151
    Houston, TX
    Thanks!
does water meth tap into stock map sensor
hellcat 3 bar map sensor
hellcat map sensor
maps sensors in challenger hellcat
methanol water injection hellcat
water injection dodge hellcat
water mentanol injection hellcat
water methanol injection hellcat
