Hellcat TR-6060 safety
Discussion in 'SRT Hellcat General Discussions' started by Dak59RT, Dec 3, 2014.
  1. Dak59RT
    Dak59RT Gold Member
    Nov 14, 2014
    594
    278
    Houston, TX
    Can anyone educate me on the safety of the challenger hellcats with the tr-6060? I was talking to my father earlier (who was big into drag racing back in the 60s) and he was asking me about whether the hellcat has scatter-shield. I can't really find anything online about it but from what I can tell, scatter shields are typically installed to protect your feet from getting chopped off if the clutch explodes (under full loads in cars with tons of power, especially launching). It looks like more modern high performance transmissions may have thicker blow-proof bell-housings, which integrate the safety of a scatter shield. I assume the tr-6060 has a blow-proof bell-housing, but I want to be sure.
    Can anyone who knows about the tremec tr-6060 and the challenger hellcat give some input? Does it need an aftermarket upgrade to make it safer?
  2. ChallengerDad
    ChallengerDad SRT Hellcat Moderator Staff Member Gold Supporting Member
    Oct 5, 2014
    1,469
    627
    563
    Bethlehem, New York
  3. BossHawg
    BossHawg Senior Hellcat Member
    Oct 10, 2014
    797
    270
    63
    With rev limiters, balanced fly wheels and the stronger metal used in bell housings you won't need a scatter shield in this transmission at the current power levels. Do you need a scatter shield? No. Would a scatter shield make you safer? Yes. Another reason us hot rodders retrofit newer transmissions into older cars is because they are way stronger.....unless you are running a glide. Lol
  4. Dak59RT
    Dak59RT Gold Member
    Nov 14, 2014
    594
    278
    Houston, TX
    Thanks for the link.
    I actually called Tremec earlier today and had an interesting conversation. Long story short, if the Tremec rep had a hellcat (or any high HP car like a ZL1, vette, viper, gt500, etc) with a tr-6060 he wouldn't be drag racing it at all unless he upgraded the bell housing to a blow-proof SFI-approved bell housing.
    I'm sure that's just his response for liability purposes, but it does point to the fact that we should all be careful and aware that should the clutch go out (which is more likely in a drag racing scenario), the cast aluminum stock bell housing will not keep the exploding shrapnel from slicing in every direction.
    With that said, I can find no references of the TR-6060 exploding in all of the cars it's in. I'm sure it's happened, but it must be rare. I doubt Dodge would release a dangerous car but we should all be aware of the risks that are inherent with racing these TR-6060 trannys. There are aftermarket steel bell housings that can contain an explosion and available for about $800... I will just have to keep that in the back of my mind should I get the urge to race mine. But I'm not really buying the manual to be a drag racer... It's just a fun toy that may see an occasional drag night.
  5. Dak59RT
    Dak59RT Gold Member
    Nov 14, 2014
    594
    278
    Houston, TX
    Sounds like you know a little about this. So in your opinion when would you be adding a blow-proof bell housing or scatter shield? The tremec rep says its a good idea if we mod it or race it... Uhhh... Isn't this car modded quite a bit already and it's sort of marketed as a drag racing car? lol
  6. ChallengerDad
    Oct 5, 2014
    1,469
    627
    563
    Bethlehem, New York
    The Tremec TR-6060 is in the Shelby Mustang, Challenger, Viper, Camaro, and CTS-V. These are all high-HP cars built from 2007 - present. I haven't heard of any failures or recalls, or any recurring problems on this transmission for any of these vehicles (and I know a LOT of them have been heavily modified for competition).
    I think you have a better chance of having a rear shaft snapping long before the gear-box has any problems.
  7. BossHawg
    Oct 10, 2014
    797
    270
    63
    If You're going to run in certain classes and et's you have to have an sfi bell housing/scatter shield or sfi blanket...in addition to sfi flywheel and etc. If you're just running stock I wouldn't change a thing, just make sure you don't over rev. I don't know what the rev limiter is on the hellcat is but stock you should be fine. Also NHRA has made concessions for these newer faster factory muscle cars. If you're going to mod heavily I would go in and start beefing up the whole tranny and including the bellhousing/scattershield.
  8. BossHawg
    Oct 10, 2014
    797
    270
    63
    Lastly if you upgrade the internals there's a less likely a chance of it exploding.
    If you're running stock you're fine.
    If you start making more power, I would upgrade the internals to maybe stage VI
    Going all out racing rebuild and upgrade the whole thing.
    Check out RPM Transmissions, they do all of my work for years.
  9. Dak59RT
    Dak59RT Gold Member
    Nov 14, 2014
    594
    278
    Houston, TX
    So you're saying "hellcat stock" is still a low enough amount of power to be fine with the transmission that comes with it. That's kind of the conclusion I'm coming to as well... But it's just difficult to look at the hellcat as "stock" even though it is!
  10. BossHawg
    Oct 10, 2014
    797
    270
    63
    Yes that's what I'm saying. :)
  11. Bjax
    Bjax Hellcat Member
    Oct 23, 2014
    46
    12
    Just don't drop the clutch above 5,000 rpm. Should be fine.
    Anyone know what material the flywheel is made from????
    Cast?
    Steel?
    Aluminum?
  12. MOPARBBY
    MOPARBBY Rookie
    Dec 15, 2016
    4
    0
    1
    cast iron
  13. tsubahog
    tsubahog Gold Member
    Mar 30, 2015
    349
    161
    NJ
    At last a great thread with intelligent information and commentary. Beats the threads with 37 pages about how to remove the DODGE letters on the trunk lid.
    Well done:)
    • Funny Funny x 1
  14. MOPARBBY
    MOPARBBY Rookie
    Dec 15, 2016
    4
    0
    1
    THE CLUTCH DOES EXPLODES UNDER HEAVY USE I HAVE MINE OUT NOW WITH THE CLUTCH CARRIER PLATE MANGLED, CRUSHED AND SEPERATED IN MULTIPLE PIECES, IT PUT SMALL GOUGES IN THE BELL HOUSING BUT DID NOT CRACK OR DO A TON OF DAMAGE.
  15. MOPARBBY
    MOPARBBY Rookie
    Dec 15, 2016
    4
    0
    1
    HERE ARE SOME PICS FOR YOU GUYS.
beefing up challenger manual transmission forum
hellcat challenger tr6060
hellcat tremec 6060 nibble
hellcat use scatter
tr60-60 trans blanket
tr6060 blanket
tr6060 in hellcat
tremec 6060 upgrades
