Hellcat Valentine 1 Install (BlendMount / HardTap)
Discussion in 'SRT Hellcat Electronics' started by HOONAGN, Feb 8, 2015.
  1. HOONAGN
    HOONAGN FLOOR IT!
    Jan 28, 2015
    260
    134
    Fullerton CA
    Part 1
    Decided to install the Valentine 1 using the BlendMount and the HardTap hardwire kit; figured documenting it might be helpful to someone. This will be the same for any other radar and mount combo.
    Step 1 - Passenger side A-Pillar removal. This can be a little tricky but you basically pull from the top and slip your fingers down both sides of the cover and gently pull with some pressure. There's only two anchoring points with clips and it will eventually pop off. Don't man handle it, take your time.
    [​IMG]
    Step 2 - There is a safety lanyard that needs to be removed for the A-Piller to completely come off. Use your thumb, and while pushing the tab in, remove from the metal clip by sliding it upwards.
    [​IMG]
    Closer look of the tab connected to the A-Pillar:
    [​IMG]
    The metal tab it slides out of:
    [​IMG]
    Step 3 - Install BlendMount. Pretty straight forward; comes with instructions.
    [​IMG]
    Step 4 - Mount the Valentine 1 and run the HardWire cable up to the head liner and tuck in while guiding it towards the A-Pillar. Recommend you connect it to the Valentine 1 in order to get a proper clean look.
    [​IMG]
    Step 5 - Zip-Tie the HardWire to the existing wire loom that is in the A-Pillar. (I used 3)
    [​IMG]
  2. HOONAGN
    HOONAGN FLOOR IT!
    Jan 28, 2015
    260
    134
    Fullerton CA
    Step 6 - Open the glove box and remove the 6 bolts that hold it in place.
    [​IMG]
    Step 7 - Gently remove the side vent cover and gently remove the plastic cover molding along the door jam.
    [​IMG]
    Step 8 - Remove the 2 bolts from the side of the of the glove box.
    [​IMG]
    Step 9 - Gently pull down and remove the lower cover that is below the glove box.
    [​IMG]
    Step 10 - Remove the LED connection from the lower cover.
    [​IMG]
    Step 11 - Gently pull down the glove box while closed. There are 3 tabs that hold it in place.
    [​IMG]
    Step 12 - Remove the plug unit in the lower back by sliding it to the left.
    [​IMG]
    Step 13 - Remove the glove box light connector from the top.
    [​IMG]
    Step 14 - After removal locate the large grey connector.
    [​IMG]
    Step 15 - Connect the HardTap to the pink with purple stripe wire.
    [​IMG]
    Step 16 - Attach to the ground wire to bolt in the door jam.
    [​IMG]
    Step 17 - Zip tie / Clean up your wiring.
    [​IMG]
    Step 18 - Replace all trim pieces that were removed in the opposite order and you're done!
    • Like Like x 4
  3. HOONAGN
    HOONAGN FLOOR IT!
    Jan 28, 2015
    260
    134
    Fullerton CA
  4. HOONAGN
    HOONAGN FLOOR IT!
    Jan 28, 2015
    260
    134
    Fullerton CA
    PM me if you have any questions :p
  5. rayzazoo
    Nov 8, 2014
    3,627
    1,377
    818
    What Blendmount model did you use? I still have the one from my 2012 that I'm thinking of using but I think the bracket is different.
    Excellent write up and can easily be used for other installations as well!
  6. HOONAGN
    HOONAGN FLOOR IT!
    Jan 28, 2015
    260
    134
    Fullerton CA
    Mirror ID# DOD-005
  7. MaxxMuscle
    MaxxMuscle Gold Member Hellcat Car Club HCC Charter Member
    Feb 10, 2015
    714
    284
    Lafayette La.
    U make it look easy HOONAGN.Thanks for the write up.
  8. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,011
    484
    403
    Westchester
    i dont trust myself to do this but ill have my shop do it with this guide when i get my hellcat, thanks!
  9. Johnny Popcorn
    Johnny Popcorn Hellcat Member
    Dec 20, 2014
    91
    14
    Hello! Thank you so much for posting, HOONAGN. This is execellent. I'd like to confirm that the blendmount ID-DOD-005 is their SKU BMX-2002. Yes? Just want to get it right. Thanks again!
  10. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,770
    Wisconsin, USA
    nice Raptor yours??
  11. HOONAGN
    HOONAGN FLOOR IT!
    Jan 28, 2015
    260
    134
    Fullerton CA
    yup.. That's my Raptor :p Fun truck but mine is modified some /wink
    [​IMG]
  12. HOONAGN
    HOONAGN FLOOR IT!
    Jan 28, 2015
    260
    134
    Fullerton CA
    Mirror ID-DOD-005
    Valentine 1 - SKU: BV1-2002
    Escort / Beltronics - SKU:BMX-2002
    I also edited the post bit to have the correct step numbers. I also have it in PDF form if you'd like.
  13. HOONAGN
    HOONAGN FLOOR IT!
    Jan 28, 2015
    260
    134
    Fullerton CA
    It really is easy but understand you fully. Just make sure the guy doing it treats your Hellcat better than you would.
    Also, if anyone in SoCal wants to do this - just hit me up. I have no problem helping out for a beer, or two, or three! :p
hellcat hard
id-dod-005
mirror id-dod-005
