Help, Charger Cat Rear wheel hop at drag track
Discussion in 'SRT Hellcat General Discussions' started by themarshall, Jul 18, 2015.
  1. themarshall
    themarshall Silver Member Hellcat Car Club Gold Supporting Member HCC Charter Member
    Feb 3, 2015
    229
    50
    Super wheel hop 1st gear at local drag track last night. Summer tires, sport mode, 32 psi. all four tires. What the heck am I doing wrong? Need input. Thanks
  2. purnrg
    purnrg BANNED
    Apr 12, 2015
    2,619
    1,154
    588
    Suspension work
  3. B5 Blue
    1,745
    Need to launch different. When do you get the hop? Got time slips?Sport mode in traction?
  4. themarshall
    Feb 3, 2015
    229
    50
    Got so pissed off I put the time slips in the trash can at the track. Dam I screw up, trap speed 122 mph. Wheel hop first & second gear after I lifted twice. Sport mode says traction control off.
  5. themarshall
    Feb 3, 2015
    229
    50
    Suspension work ok I'm all ears, what is avail. out there?
  6. B5 Blue
    1,745
    Drag radials 1 st
  7. themarshall
    Feb 3, 2015
    229
    50
    I have nito's in the trailer (storage) but if I put DR's on wont that give me more hop because they will hook better?
  8. Dubs
    Dubs Rookie
    Dec 19, 2014
    15
    1
    No, wheel hop is a stick /slip condition with the tires. Get more grip and it will lessen the slip part....really want to eliminate it, put slicks on it. Once you try the DR's and launch harder you might get into wheel hop again, so you might just have to change the way your driving.
  9. Dubs
    Dubs Rookie
    Dec 19, 2014
    15
    1
    oh, and for the summer tires I would bring the rears down to the mid 20's and give them a little burnout. They want to be around 175F.
  10. themarshall
    Feb 3, 2015
    229
    50
    Yo B5 Blue thanks for the help with the drag radials. You can guess what I;m going to do the next time out, put the dam DR's on! Anthing else I should get schooled on before I go out and wip the Mustang & Chevy boys?-------thanks again-----
  11. themarshall
    Feb 3, 2015
    229
    50
    Yo Dubs, thank you for the info on summer tires. -------thanks again-----
  12. B5 Blue
    1,745
    The tree. Go on 3rd green and adjust up/down. With DR you can launch in sport mode after a 5 second burnout so you need a Tazer linelock from Z automotive
  13. themarshall
    Feb 3, 2015
    229
    50
    Yo B5Blue thanks again for info on the line lock.----------thanks-----
  14. Trucker Bob
    Trucker Bob Silver Member
    Feb 21, 2015
    371
    91
    Northern IL
    My Wife's 2010 R/T gets wheel hop. I have not taken Cat to the strip yet. But after going to my SRT Driving day, I have played around a bit. I have not used the on board timers. That being said, the car feels faster with the trac. control in street come off the line on the soft side than nail the loud peddle to the floor. I get a little spin.. Than hang on!! Plus I don't think I'll blow the Drive Shaft out of the Car."Sometimes you have to go slow to go fast". "Days of Thunder"
  15. dodgeboy
    dodgeboy Silver Member
    Dec 31, 2014
    344
    113
    It's a combination of the tires and the suspension. Wheel hop is generally caused by poorly designed suspension (or simply suspension that was not designed to handle the kind of power it's getting thrown at it). In our case, the geometry is pretty good, but I think the bushings are too soft. You could put Pedders (or some other poly bushings) in the rear, but it isn't cheap. Someone else (speedlogix?) sells a rear suspension component that is supposed to eliminate hop, as well.
    Putting stickier tires on it is more of a workaround than a fix. Lessening the chances of the tire slipping will lessen the chance of wheel hop, but if stickier tires do slip (poor track prep), it increases the chances of breaking something when the wheels start hopping. I've had wheel hop on the street with mine; more so than any other IRS vehicle I've driven. I also have summer tires.
challenger rear hop tires
pedders bushings for hellcat wheel hop
