Help w/codes u113f and u1140
Discussion in 'SRT Hellcat Performance' started by Hb hellcat, Oct 15, 2015.
  1. Hb hellcat
    Hb hellcat Black Betty...BamAlam!!!
    Feb 14, 2015
    593
    191
    Sunny Southern California
    Hi all,
    My car has been at dealer for over a week now with these two codes.
    Went in for brake fluid change and had code 121b for an actuator, dealer ordered and installed. Now has the aforementioned codes. Dealer orders new pcm. Came in and installed, still has those codes!
    Anyone know what they are and what could cause them? Tech says it just an internal communication error. Maybe a bad component, but doesn't know which one!.
    I'm heading back out to track this weekend and would really like to get this straightened out!
    Thank you for any help you could provide
  2. christman787
    christman787 Hellcat Member
    Feb 4, 2015
    34
    17
    Oshkosh,wi
    Those codes are for lost communication with active exhaust valves. They are on the tailpipes in the back. The codes are for each one of the valves.
  3. christman787
    Feb 4, 2015
    34
    17
    Oshkosh,wi
    I just found a star case that says they have issues for a pushed out terminal on a ten way connector for those exact codes.Tell the dealer to look up case number s1508000182 and they should be able to fix it.
  4. christman787
    Feb 4, 2015
    34
    17
    Oshkosh,wi
    Its a ten way connector by the rear diff. They have a terminal not fully seated into the connector
  5. Hb hellcat
    Feb 14, 2015
    593
    191
    Thank you, will get this info to dealer pronto!:)
  6. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,064
    646
    413
    So Cal
    HB didn't Borla just put in a cat back exhaust on your car ?
  7. TinCuda
    TinCuda Gold Member
    Aug 14, 2015
    262
    266
    513
    Texas
    Anyone happen to have a picture of that plug?
  8. Danny123
    Danny123 SRT Hellcat Moderator Staff Member
    Oct 4, 2015
    672
    401
    Was the connector they are talking about the problem? I have same code U113F replaced both exhaust valves service tech cleared code and it came back in 30 miles. I have the Zoomers cat back exhaust. Thanks Danny
  9. catdodgehell
    catdodgehell Gold Member
    Aug 30, 2016
    255
    131
    Waco, TX
    I had Amcco transmission put in a new clutch and drive shaft and they forgot to plug them back in. It right by rear axel on top of exhaust.
  10. Hb hellcat
    Feb 14, 2015
    593
    191
    Yes, Borla put the exhaust on. It was the prototype vehicle for them.
    Quite honestly, I don't know if the dealer ever figured what was wrong, but they got the light out and it stays off.
    When my car went in the code said left exhaust valve, they ordered new and replaced, then they said that valves were switched side to side (looks to be almost impossible to do) and they really needed a new right valve, ordered that, installed, then said it needed a new ecu, replaced that. I finally got my car back three days later with no codes showing and no explanation on why they need her for the three days after ecu was installed.
    I still think it was electrical plug issue and not a hardware issue. I know the mechanic doesn't like to see my car come in for work as I'm always wanting to know more info than the service writer can tell me so I go straight to the mech for the scoop. I guess insurance doesn't like that.
    Then we all get spoken to.
  11. Hb hellcat
    Feb 14, 2015
    593
    191
    My advice is to check the 10 pin connector near diff and the plugs on the valves themselves. There is an adjustment procedure for the valves as well. There were several threads when I had my issue.
pcm code u113f
u1140
u1140 code helcat
