HELP
Discussion in 'SRT Hellcat Performance' started by Link, May 21, 2016.
  1. Link
    Link Silver Member
    Jan 27, 2015
    939
    220
    Just installed new HHP PCM, car tries to start but then dies immediatly. No codes
  2. fnkychkn
    fnkychkn Thread Killer Gold Supporting Member
    Jan 24, 2015
    1,698
    762
    633
    greasy cardboard box
    is there a red dot flashing in the cluster? if so, the PCM needs to be programmed with SKIM code.
  3. Link
    Link Silver Member
    Jan 27, 2015
    939
    220
    yes it is. what is that? and how?
  4. fnkychkn
    Jan 24, 2015
    1,698
    762
    633
    the PCM must communicate with the BCM (body control module) and RFH (radio frequency hub). all 3 must be programmed with a matcing secret code. once code is verified by all 3 modules, it will allow the engine to run. pretty sure HHP PCMs come pre-programmed with your VIN and code.
  5. Link
    Link Silver Member
    Jan 27, 2015
    939
    220
    yes I gave them the vin, what do I do now?????? take it back out?
    I don't know how to contact Josh.
  6. Link
    Link Silver Member
    Jan 27, 2015
    939
    220
    should i try to save the existing tune and load stock one. If i can do that without screwing up everything
  7. fnkychkn
    Jan 24, 2015
    1,698
    762
    633
    does the red dot flash?
    HHP 1-888-894-1115
  8. Link
    Link Silver Member
    Jan 27, 2015
    939
    220
    yes
  9. fnkychkn
    Jan 24, 2015
    1,698
    762
    633
    best call HHP before messing with the tune.
  10. Link
    Link Silver Member
    Jan 27, 2015
    939
    220
    agreed
    thx
  11. fnkychkn
    Jan 24, 2015
    1,698
    762
    633
    if you can't resolve this right away, reinstall your stock PCM to get you mobile.
  12. Link
    Link Silver Member
    Jan 27, 2015
    939
    220
    had a thought, that it wasn't starting because the hood was open. Shut it, disconnected battery for a few minutes but it doesn't even try to turn over now. o_O
  13. Linda's Hell Cat
    Linda's Hell Cat SRT Hellcat Supporter Gold Supporting Member Fastest HC Charger/Record Holder
    Oct 28, 2015
    1,877
    2,491
    763
    Bucks County Pa
    Hemituner Performance
    100 Dale Street
    Westbabylon NY.11704
    516-603-9276
    aj@hemituner.com
    You need to get in touch with AJ
    Also check your connections and clear any codes.
    It may be something easy for AJ to check
    Linda :)
  14. Link
    Link Silver Member
    Jan 27, 2015
    939
    220
    I ran the diag,
    no codes other than flashing red light
    I had tried about 6 times to start it with hood open tho.
  15. Linda's Hell Cat
    Oct 28, 2015
    1,877
    2,491
    763
    Bucks County Pa
    I know you are excited for the change.
    Send AJ an email with your info and the problems you are having.
    It could very well be the pcm. Only AJ can fix that.
    Take FC's advice and put the stock pcm back in.
    Linda :)
