High Altitude help
Discussion in 'SRT Hellcat Performance' started by Chippy, Apr 25, 2015.
  1. Chippy
    Chippy Silver Member
    Nov 27, 2014
    654
    139
    Alberta
    Some of us unfortunately do not live at or even close to sea level. I personally have air here at about 5000ft. We generally lose about 2 pounds of boost. My guestion is would a pulley change to get some or all of that lost 2 pounds back set off codes or put into limp mode? Thank you in advance. And if not which pulley and maybe who could make them. One last thing is the belt a dodge specific or can you get something aftermarket in different sizes?
  2. Titletaker
    Titletaker Hellcat Member
    Dec 6, 2014
    56
    The east coast guys have it made.
  3. KLR CAT
    KLR CAT Active Hellcat Member
    Apr 9, 2015
    42
    28
    Pulley will help for sure, but will need tuning. More airflow means MAF transfer will need to be tuned, as well as Power enrichment tables.
  4. Chippy
    Nov 27, 2014
    654
    139
    Alberta
    So even if we're losing approx 2 lbs boost still needing tune if just trying to get boost back up to stock levels? Which if can be done I'm OK with but what a pita.
  5. B5 Blue
    1,745
  6. Cruisin1966
    Cruisin1966 Silver Member
    Nov 8, 2014
    1,103
    235
    198
    Calgary
    Do you even have your car yet? ;)
    You know I'm just poking the bear, lol
  7. KLR CAT
    Apr 9, 2015
    42
    28
    Tuning is not about boost, its about airflow and the calibration of the MAF to determine that airflow. Flow and Density are different things. You are down on boost and HP relative to sealevel due to less dense air, and less oxygen content in it. Spinning the blower faster increases airflow consumption before the rotors and across the MAF, and increased charge density post rotors into the heads. The ECU determines fueling based on that airflow. a Certain MAF frequency is an expected to be a certain airmass, and a commanded injector pulse to fuel towards that airmass appropriately. Now the hellcat looks to use both MAF and MAP, and I haven't seen the stock calibration myself yet, so I'm not exactly sure what strategies the ECU uses, but generally anything that changes airflow into and out of the motor substantially ( and a 20% overdrive is substantial) needs to be calibrated correctly.
  8. Chippy
    Nov 27, 2014
    654
    139
    Alberta
    Thank you for the explanation.
  9. VanishingPoint
    VanishingPoint Silver Member
    Jan 6, 2015
    953
    245
    Somewhere, Texas
    The good news is, everyone is on the same playing field at that elevation, so no fear.
    IIRC, NA cars lose 3%, and blown cars 2% per thousand feet?
