HK Speaker Crossover's
Discussion in 'SRT Hellcat Electronics' started by zippy, May 16, 2015.
  1. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    135
    Ontario
    Many thanks to fnkychkn for sharing the radio/amp pinouts for me to install a pair of subs in my charger HC.
    Factory is just OK as many have noted, I like a little more umph . . . Inside the car des sound clean......
    Is anyone aware of the frequencies going to each speaker ?
    ie Dash L/R/C, Ft Door L/R, Rear Deck L/R, Sub etc
    Ideally I would like to tap volume controlled full range speaker (s) for the signal and use my new amp to cross over the new subs.
    Thanks for any insight !!
    Zip
  2. Colorado Hellcat
    Colorado Hellcat Silver Member
    Nov 13, 2014
    573
    135
    Zippy, aside from you wanting more base. I can understand that.
    Have you had the TSB Amp flash done yet? The speakers ARE wired wrong. At least in the back. There is a Night & day difference in the Back now after the update to the amp!
  3. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    135
    Ontario
    Thanks for the reply from Colorado !
    Yes I got my cat last sat. It was built just a couple weeks ago
    I am on software 15.06.01
    Just looking for more lower end.
    Need a couple full range speakers to tap into...
  4. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    135
    Ontario
    image.jpg Update:
    Tapped the rear deck speakers for my subs, They do not have the sub frequencies (ie, not full range)
    Thanks to fnkchkn and the pinouts, I actually tapped the factory sub wires out of the amp then my alpine's came alive. (see pics)
    Now I am at the point that I want to rewire the audio system. ie new amp for the car and new speakers. factory just isn't doing it for me.
    Am really curious if anyone has found out what the crossover frequencies are for each of the speakers, or do I need a frequency combiner (CL-SSI - Car Audio - OEM Interface - OEM Integration - JL Audio
    If I had the frequencies, I may have an alternative . . .
    Thanks Everyone
    ZIp
  5. ChargeCat
    ChargeCat Senior Hellcat Member
    Feb 2, 2015
    126
    41
    The only way that I was able to determine the individual input frequencies in my Bose CTS-V aftermarket system was with using the setup in a Rockford Fosgate 360.3.
  6. Themip
    Themip Gold Member
    Nov 15, 2014
    511
    'Murica
    how can you tell if i have the updated software or whatever?
2016 dodge 9 speaker alpine system crossover frequencies
hk speaker crossover
