How do you get the car in neutral with engine off?
Discussion in 'SRT Hellcat General Discussions' started by paul suloff, Jan 14, 2015.
  1. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    701
    237
    I can't figure out how to move auto shift lever out of park without starting the engine. Tried Accessory and foot on brake, tried run with no brake. So what am I missing. Don't want to have to start the engine every time I move the car a little, or how do you push it in staging lanes.
  2. TallCool1
    2,438
    828
    Pacific NW
    It's in the owners manual. Leave it in park remove the coin / cubby holder to the right of the shift lever that lifts out. You'll see a red nylon loop under it. Use that but read in the owners manual how to engage and disengage it's not intuitive. It might be under towing or roadside maintenance can't recall...
  3. X-Men Fiend
    X-Men Fiend Gold Member
    Oct 25, 2014
    1,684
    579
    423
    East Phoenix Valley, AZ
    Shame they make it so complicated!
  4. paul suloff
    Aug 25, 2014
    701
    237
    Thanks! When everything else fails, read the instructions. I'll read the manual. Hope it is simple to do, keeping car cool before a run will be important.
    I'm already pissed the performance pages need to be rebooted every time you start the car. You need to see all your info as soon as the car starts. Hope they correct his on later models.
  5. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    Is it so you can clean the wheels, I wanted to do the same thing
  6. paul suloff
    Aug 25, 2014
    701
    237
    Well didn't think of that! If I have it on my lift or in garage and need to nudge it someplace I don't want to start it everytime. All that does is put moisture in the engine and exhaust if you don't let it run for 10 Mins. Biggest reason is to push it in the staging lanes next summer. You want everything as cool as possible before a run and starting it every time the line moves defeats that.
  7. Fast cat
    Sep 23, 2014
    2,255
    716
    498
    Indiana
    Maybe try shutting It down in neutral and putting the parking brake on .
  8. hellcat1
    Sep 27, 2014
    10,672
    2,033
    That don't work, Shutting it down in neutral, I have tried this, So i could clean the wheels
  9. B5 Blue
    1,745
    I swear I read this is an electronic shifter what happens when you shut it off in neutral?
  10. hellcat1
    Sep 27, 2014
    10,672
    2,033
    The car won't let you shut it off in neutral.. I was at the car wash, and wanted to turn it off in neutral, and it would not work, also would not let me put it in neutral while not running....mind you I have only tried this once,, just to clean the wheels
  11. B5 Blue
    1,745
    Then I assume it won't let you shut it off in Drive or Reverse as it would roll?
  12. hellcat1
    Sep 27, 2014
    10,672
    2,033
    This is also true,, but again,I only tried this once,, right before it got put in storage for the winter
  13. B5 Blue
    1,745
    From sales brochure
    Page 21 The
    new electronic shifter with AutoStick
    mimics the operation of a traditional
    linkage shifter, while allowing for smoother
    and more efficient shifting
    This may be why but my car ain't built yet so I can't look at it.
2015 dodge charger neutral
2016 dodge ram 1500 how to put in nuetral with engine off
how to put a push button start car in neutral
how to put car in neutral
how to put challenger in neutral
how to put dodge charger in neutral
how to set a car in neutral wen engine is on
putting dodge push start car in neutral
