How To Glue your Drag Radials
Discussion in 'SRT Hellcat Wheels and Tires' started by Just4Fun, Jun 18, 2015.
  1. Just4Fun
    Just4Fun Senior Hellcat Member
    Sep 21, 2014
    101
    33
    68
    I got some Permatex High Tack, I hear it's good for getting your slicks to stick to the rim if you're experiencing rim spin.
    Anybody have any experience with this?
    Any help on the application would be appreciated!
    Do you glue the rims only?
    Do you glue the tire bead and the rim?
  2. B5 Blue
    1,745
    Cleaning that off engine parts is a PIA so a wheel and tire would be worse. And no never heard of it you screw them in which ain't happening on my new 18 inch wheels
  3. Top Cat
    Top Cat Gold Member Hellcat Car Club Fastest Cat/Record Holder HCC Charter Member
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    Mark the tire and wheel and make some pass's before doing this, I doubt at this level you will need to, just make sure the wheel lip and tire are clean and dry when mounting them up.
    TC
  4. bam bam
    bam bam Silver Member
    May 30, 2015
    618
    240
    TEXAS
    if you want the tires to stick like glue to the bead we always mounted the slicks at the track with gumout just spray the tire bead real good mount them and they will stick like you vulcanized them to the rims. try it it works, and you can still get them apart. been doing it for years.BAM
  5. Noquarter
    Noquarter Gold Member
    Nov 19, 2014
    771
    249
    Columbus, OH
    I needed to get mine glued. My mark went almost all the way around at LXBN last year @18 psi. Once they were glued they moved less than in inch with over 80 runs.
  6. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    679
    226
    I tried 3M trim adhesive and it broke loose. Tires broke loose and move 3" each session.Going to use a chisel to score the wheel bead area and try Permatex Hi Tak. DON'T PUT SCREWS IN THEM
  7. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,076
    514
    413
    PASADENA, CALIFORNIA
    Just do what I do. Balance the wheel with TPMS/Valve stem by it's self. Then mount the tire and add NO more weight. The balancer actually has a setting for this. That way the tire can move around and it will not be an issue. Believe it or not I had some 305/45R18 Nitto NT555R's and I had him check after the initial balance of the bare wheel.......after mounting the tires it was only asking for another 1/4 Oz! Mickey Thompson ET Street "R" in the same size, no issues.
    I am having zero issues with this setup.
    No way would I goop up the beads with anything that would need to be cleaned off next time......Do you really think your tire guy is going to clean that off, and even if he does, will he do a good job?
  8. SRTFighter
    SRTFighter Silver Member
    Mar 21, 2015
    704
    149
    Houston, TX
    Why not just do it the right way and get some bead lock wheels from the start?
  9. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,076
    514
    413
    Expensive and will slow you down. Bead Locks do have their place but my car is not one of them.
  10. paul suloff
    Aug 25, 2014
    679
    226
    Question is as the tire slips how does it effect the 60 ft
  11. Noquarter
    Nov 19, 2014
    771
    249
    Columbus, OH
    Pretty sure there are no viable bead lock options for 18" yet.
    It could affect your 60' slightly depending on how bad its slipping.
  12. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,076
    514
    413
    I actually think the tire slipping might help your 60 foot in some cases. By absorbing energy and keeping you from breaking loose. On a really well prepped track you will do better if it does not slip and if you run a higher pressure and stiffer sidewall. It would be very difficult to determine if it is helping or hurting. We are only talking about a few degrees of rotation. I would not lose any sleep over it.
  13. Noquarter
    Nov 19, 2014
    771
    249
    Columbus, OH
    Again it depends onhow bad its slipping. My mark went all the way around with just a few runs until I glued. 100th of a second maybe. Would be hard to prove out though
drag radial high tack
high tack glue for drag radials
how to apply the drag race glue
how to drag race hellcat
how to glue drag radial to wheels
tire bead glue
tire glue for mounting drag tires
use high tack to mount drag race tires
