how to heat up your nitto's
Discussion in 'SRT Hellcat General Discussions' started by huggytree, Oct 14, 2015.
  1. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,136
    744
    Been to the track 2x's now.....im still learning how to do a proper burnout....1st time at the track i didnt heat them up enough.......2nd time at the track i put effort into it.....it never really gets smokey....i put the car in sport, gas it...i let it shift into 2nd while doing the burnout....it seems 10-15 seconds.....but still not working
    i spin too much off the line....im at 11.6.......im told im still not heating them up enough...i need to see tons of smoke.....i stay in the water box during the burnout....some say to roll out of the water box, then spin the tires...
    im going to the track again this weekend......shooting for low 11's
  2. CDNHellcat
    CDNHellcat Silver Member Hellcat Supporting Vendor
    Nov 23, 2014
    499
    223
    Vancouver BC
    What Nittos? I run NT05R drag radial and I still don't go through the water box. I have the PSI set at 19 and do a 3 to 5 second burnout
  3. Chippy
    Chippy Silver Member
    Nov 27, 2014
    673
    146
    Alberta
    NTO5r here I do a 5 sec only in first ran this last weekend against the P85d in insane mode. I'm right lane
  4. CDNHellcat
    Nov 23, 2014
    499
    223
    Vancouver BC
    Good run what is the elevation at that track?
  5. Chippy
    Nov 27, 2014
    673
    146
    Alberta
  6. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    How wide are your NT05R's?
  7. Chippy
    Nov 27, 2014
    673
    146
    Alberta
    315 I have the dash cam vid of the race its 36 sec long but can't seem to post to YouTube. I can send it to someone if they want to see it or post.
  8. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    You got the 315's on stock rims or you got different rims?
  9. Chippy
    Nov 27, 2014
    673
    146
    Alberta
    I have 2 sets of rims but run the Drag radials on the stock rims. My second set of rims are 11" wide for rear and I run the 315 NT05 on those for daily.
  10. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    Got it. So it looks like I'm gonna have to get different rims to put the 315's on
  11. Chippy
    Nov 27, 2014
    673
    146
    Alberta
    My NT05 fit a lot nicer on the aftermarket 11" rim than the NT05r,s on the stock rim.
  12. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    Ya I bet, my cousin had the 315 NT05R on his cts-v and the rim is 9.5 inches wide on the cts-v also and he said that the tire formed a belly after a while because the rim is too small
  13. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,650
    538
    423
    Chattanooga, Tennessee
    Definitely need to roll out of the water box. When you finish your burnout, your tires should be dry and hot. 3-5 seconds burning out should get you there if your not in standing water.
    edited to add.... Let the car roll forward slightly as you are burning out. You'll hear a change in tire squeal as they dry out and heat up.
  14. StellasHC
    StellasHC Platinum Member
    Nov 18, 2014
    1,832
    1,322
    933
    Kenosha, Wisconsin
    huggytree I'll give you a first hand demo Saturday when we go.. my technique is good enough for a 1.58 60' and a 2.9 0-60mph, so I must be doing something right.
    • Winner Winner x 2
  15. Dubya
    Dubya Silver Member
    Jan 3, 2015
    717
    202
    I run 555's and my burnouts produce very little smoke. I run 18psi, roll through the water, do a 3-4 second burnout at about 2500rpm's and roll out about 20 feet to hear my distinctive sticky chirp. I stage at 2000-2500rpm depending on the prep. Make sure you're in the groove. I usually hook well after that routine. Too long a burnout will just make them greasy.
    Caveat emptor - Not all tracks prep worth a damn, some not at all on Test N Tune nights.
