How to Remove Center Console
Discussion in 'SRT Hellcat Electronics' started by Sublimecat, Jan 3, 2015.
  1. Sublimecat
    Sublimecat Silver Member
    Oct 2, 2014
    907
    330
    173
    Akron, Ohio
    In the event you want to take the center console out to install a shifter, wire in a radar detector is just want to see what's under there here is how to do it.
    Very similar to previous years. Lift shifter boot with a plastic trim tool and unbolt the shifter handle. Pic gives you an idea where the tabs are that need to pop out.
    image.jpg Remove the console center section with the trim tool. Again pic shows the tabs.
    Unplug the heater control panel harness. It will be obvious when you lift it out. Remove the two screws that hold the console to the dash in the front of the console that are now accessible from removing the center section (7mm). Remove plastic trim panels in the rear of the console underneath the armrest and the two bolts (10mm).
    Console slides to the rear for 1-2 inches. Unplug remaining two wiring harness plugs at the front of the console and it can be lifted out. Interesting observation, the center console has a tag on it with my VIN number.
    You need a plastic trim tool, 13mm, 10mm and 7mm sockets to remove the console. Once out you can get to the power outlet wiring and the shifter very easily. image.jpg
    • Like Like x 3
    • Useful Useful x 3
  2. rednug
    rednug Hellcat Member
    Jan 31, 2015
    39
    32
    18
    Oklahoma City
    good info. Thanks for sharing
  3. Chippy
    Chippy Silver Member
    Nov 27, 2014
    673
    146
    Alberta
    The for the write up. Will come in handy for many of us.
  4. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    715
    247
    We got a "how to" section? This stuff is great!!!
  5. Chippy
    Nov 27, 2014
    673
    146
    Alberta
    Anyone done this with an Auto?
  6. Sublimecat
    Oct 2, 2014
    907
    330
    173
    Akron, Ohio
    Sorry, I can't help you with an auto. I have never see one in person.
    • Funny Funny x 1
  7. MrBigKid
    MrBigKid BANNED
    Nov 29, 2014
    1,341
    409
    278
    Columbia, SC
    I just replied to your message chippy, thought I would put it here as well. Didn't know there was already a thread for it. But the auto is basically the same.
    Easiest way to do it I have found (removed console 3 times now) is to:
    Pop the aluminum piece up and pull it away from the dash so that the entire thing is loose.
    Put on the emergency brake, crank the car and hold down the brake pedal. Move the shifter into drive to give you room to move the panel.
    Unplug the connector to the switches, then twist it sideways. BE careful, the leather surround is very thin and the bottom on the cover could tear it if it snags on the switches or tabs.
    Once it is sideways, lift it up and reach under it and disconnect the cable.
    Then lift the shift boot as far up as you can. There is one star screw that you need to remove.
    It is tight quarters so be careful not to drop the screw into the console.
    Lift off the handle, remove the panel and place shift lever back in park.
    3 screws in the front of the console
    behind each seat at the rear of the console is a square cover, pop it out and remove the 2 screws. Console will now slide back to access the lighter power cable.
    I believe it is the pink with black stripe you want to tap into.
    Hope that helps
    • Useful Useful x 4
  8. Chippy
    Nov 27, 2014
    673
    146
    Alberta
    Thank you!!!
  9. Kaiju
    Kaiju Silver Member
    Oct 23, 2014
    495
    156
    Louisiana
    This was very helpful this weekend! Thanks for posting those steps. Finally got my dashcam hardwired using them. :)
  10. B5 Blue
    1,745
    Does the section with cupholder just pull up to remove w/o having to take anything else off?
  11. Sublimecat
    Oct 2, 2014
    907
    330
    173
    Akron, Ohio
    Lifts out as one piece
  12. gto19
    gto19 Silver Member
    Aug 18, 2015
    524
    154
    I know this is old but can you post a pic of your trim tool?
  13. Sublimecat
    Oct 2, 2014
    907
    330
    173
    Akron, Ohio
  14. gto19
    gto19 Silver Member
    Aug 18, 2015
    524
    154
    Thanks
    So basically you use those trim tools as a little pry bar ?
  15. Sublimecat
    Oct 2, 2014
    907
    330
    173
    Akron, Ohio
    Yep, plastic prevents damaging the trim components. In some spots you have to get aggressive with it. It all snaps together. Often the first snap you pop out is the hardest. Pictures show where the snaps are so you know where to work the tool in and pry.
2015 challenger shifter removal
2015 charger center console removal
2015 dodge challenger console removal
2015 dodge challenger shifter removal
2016 challenger shifter removal
center console removal of 2016 dodge challenger
how to remove center console 2015 challenger
removing the console on a 2015 charger
