How to safely remove Line Striping paint
Discussion in 'SRT Hellcat Detailing' started by BluRidge, Jun 18, 2016.
  1. BluRidge
    BluRidge Hellcat Member
    Jan 26, 2015
    38
    5
    Northern VA
    Apparently some time during the past week I changed lanes on a road where the white center lines had been freshly painted and my tires kicked it up onto the driver's side of my cat. I was able to remove it from the painted surfaces fairly easily, but it seems to be literally baked on to the black rocker panel below the door, and to my black vinyl hockey stripe on the rear quarter. I would appreciate any suggestions in terms of the correct product(s) that I should use to safely remove the paint from those areas. Thanks!
  2. Red Harley
    Red Harley Silver Member Hellcat Car Club Gold Supporting Member HCC National Secretary HCC Charter Member
    Jul 27, 2015
    690
    258
    173
    Hamilton Ms
    I used Goo Gone on a truck one time it took the stuff off and did not hurt my paint job. I also used it on my Hellcat to remove some badges I didn't like. Worth a try before a more expensive method.
  3. BluRidge
    Jan 26, 2015
    38
    5
    Northern VA
    Thanks. I have a product called "Goof Off" which I guess is similar to what you are describing. I just wasn't sure if it was safe to use on plastics... the rocker is some type of hard ABS plastic while the hockey stripe is vinyl.
  4. Red Harley
    Jul 27, 2015
    690
    258
    173
    Hamilton Ms
    Try in a very small spot if you can and check the label first.
  5. BluRidge
    Jan 26, 2015
    38
    5
    Northern VA
    Ok, I see that the product you are recommending (Goo Gone) is absolutely safe for plastics and vinyl...my goof-off product is definitely not. Will pick up some Goo Gone and give it a try. Thanks again.
  6. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    6,131
    3,041
    863
    Oops is a good product to use. Make sure you apply a wax to the area after use
    Always use any cleaner in small areas to avoid a bigger problem
  7. Red Harley
    Jul 27, 2015
    690
    258
    173
    Hamilton Ms
    Yes they are very different. You let me know if helps.
  8. C. Charles Hahn
    C. Charles Hahn Silver Member Hellcat Supporting Vendor
    Jan 6, 2015
    103
    61
    168
    Lansing, MI
    The easiest method I've found is to use Vaseline... put a fairly light layer of it onto the paint and let it sit for a few hours, then pressure wash it off. The Vaseline will soften the road paint and allow it to release.
  9. 4510
    May 13, 2015
    723
    159
    Arizona
    Soooo... when I see fresh painted lines with tire tracks dragging paint into the next lane... I'm going to forever more think... BluRidge was here!
  10. BluRidge
    Jan 26, 2015
    38
    5
    Northern VA
    :D Yes, it figures that just when I finally get the cat, VA DOT decides to repave every road in and around my neighborhood. The tar comes off fairly easily but the paint was the kicker.
  11. BluRidge
    Jan 26, 2015
    38
    5
    Northern VA
    Thanks, I will give that a try if the goo gone does not do the trick.
  12. BluRidge
    Jan 26, 2015
    38
    5
    Northern VA
    Goo Gone did the trick. I sprayed it on the rocker panel and the hockey stripe and let it sit for 30 mins, then used a very soft toothbrush to work the paint off...good as new with no damage to the hard plastic trim or the vinyl. Thanks again!
  13. Red Harley
    Jul 27, 2015
    690
    258
    173
    Hamilton Ms
    You are very welcome! I keep at least two bottles of it on hand at all times.
