HP without supercharger
Discussion in 'Dodge Challenger SRT Hellcat' started by Slowpoke387, May 2, 2016.
  1. Slowpoke387
    Slowpoke387 Gold Member
    Jan 31, 2016
    1,702
    513
    423
    Enfield, CT
    So i roll up with the new cat Friday and start answering questions from curious people who want to know all the juicy details, and someone asks me how much power the supercharger actually adds. But in a way that made me curious. They asked how much power would the 6.2 have with no supercharger. I seemed to have never come across this before and now im curious too.
  2. bighit2883
    bighit2883 Gold Member
    Mar 15, 2015
    1,373
    491
    358
    Well the 6.4 pushes 485 hp. So the 6.2 id say would be 475 meaning the blower adds an additional 232 hp
  3. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    The 6.2 was designed for a blower (lower CR, cam, etc) so I would bet the HP would be closer to 400 or less...if the 6.2 was built for N/A probably close to the 6.4...
  4. Heavy Metal
    Heavy Metal Silver Member
    Mar 14, 2016
    658
    189
    113
    California
    Are there superchargers available for the 6.4? If so, where?
  5. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,899
    1,314
    498
    Virginia
    So if it takes 80 HP to run the blower, what is the base and how much does the supercharger add up and above that to produce 707 HP at the shaft?
  6. Slowpoke387
    Jan 31, 2016
    1,702
    513
    423
    Enfield, CT
    My question was basically if you were to remove the supercharger, what would the 6.2 make for power?
  7. DShatzer
    DShatzer Gold Member
    Oct 13, 2014
    1,262
    285
    Arrington, Kenne-Belle, Procharger, many folks make superchargers for the 6.4. Tread carefully supercharging the 6.4. There is a reason Chrysler did not just supercharge the 6.4...........
    • Agree Agree x 4
  8. Slowpoke387
    Jan 31, 2016
    1,702
    513
    423
    Enfield, CT
    Yep, saw a few vids comparing the internals. 6.2 is beefed up quite a bit internally to accomodate the extra power. Not to mention the cooling issues you would run into. I'd never do this.
  9. BODUKE
    BODUKE Gold Member
    Jan 31, 2015
    1,711
    404
    Detroit
    You would have a 12 second car.
    • Funny Funny x 1
  10. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,715
    497
    368
    Henderson, NV
    Using the 392 as comparison slight decrease in stroke and compression ratio plus a slightly milder cam I'm thinking about 440-450 crank HP.
    From a good article I came across:
    "Assuming an engine with a compression ratio of around 9:1 running pump gas,if a supercharger gives your engine 14.7 psi of boost (another atmosphere) that will essentially double the output of your engine, everything else being equal. After adjusting for thermal and mechanical energy transfer, if an efficient centrifugal supercharger is generating 7.5 psi (approx. 1/2 an atmosphere), you will see around a 35-40% gain in horsepower and torque at your non-supercharged maximum horsepower rpm."
  11. Slowpoke387
    Jan 31, 2016
    1,702
    513
    423
    Enfield, CT
    Ok so that second paragraph - i dont see any wiki posts on how to translate that into English...
    • Funny Funny x 1
  12. DShatzer
    Oct 13, 2014
    1,262
    285
    Funny, but true.
  13. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,715
    497
    368
    Henderson, NV
    Not wiki but it's pretty self explanatory. In thoery 14.7 psi will basically double your hp output. Just giving you a frame of reference.
  14. DShatzer
    Oct 13, 2014
    1,262
    285
    Basically USMC341 said the supercharger doubles the horsepower of a properly designed, efficient supercharger system. Simply put, divide 707 by 2 to reverse the doubling effect of the supercharger, and that gives you 353.5 "advertised" horsepower. More details...Reversing the post from USMC341, if the properly designed supercharger adds 100 percent extra horsepower (doubling), removing the supercharger, intake and replacing with a fuel injection intake would probably net you 350-400 horsepower, with all the other factors remaining the same. (Same cam, compression ratio, exhaust manifolds, etcetera). Hope this helps. Oh yes, because it has a different cam, it would be on the lower side of horsepower.
  15. DShatzer
    Oct 13, 2014
    1,262
    285
    I agree, the concept is simple. The halving of double can get confusing, I guess.....
hellcat or srt cam supercharger
hellcat without supercharger
how much boost does a hellcat supercharger make
how much horsepower does the srt have without supercharger
how much horsepower would a hellcat have without the supercharger
how much hp does a supercharger make
