I'm asking for it. . .
Discussion in 'General Automotive Discussion' started by intercooler, Jun 22, 2015.
  1. intercooler
    intercooler Gold Member
    Jan 16, 2015
    221
    187
    798
    N/A
  2. Carnage
    Sep 21, 2014
    12,107
    3,276
    823
    Houston, TX
    Someone is gonna say Google it :D
    • Funny Funny x 1
  3. 4510
    May 13, 2015
    751
    169
    Arizona
    I'll display my ignorance....
    Old School Challengers used a "live rear axle". So google that and you will get a good description. In general, live rear axles are better for drag racing.
    Since the reintroduction of the late model Challengers they have used a "Independent Rear Suspension" (IRS) in which the differential housing is bolted to the car's frame and there are two "1/2 shafts" for axles that go out the wheels. IRS is generally better for road racing and handling. Do a search for IRS.
    Both types of rear ends, depending on a bunch of other factors can be prone to wheel hop. It is generally easier to deal with wheel hop with a live rear axle. (traction bars) Wheel hop in an IRS setup carries a much higher risk because you can easily break a 1/2 shaft. Stiffened or solid mounting bushings for the differential housing to the subframe and subframe to the car are methods to address wheel hop. Changing the OEM rubber mounts to solid tends to introduce a lot more noise into the car (vibration, gear noise, road noise).
    Ok...I'm out... someone else tag in!
  4. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    Old school Challengers with the Hemi had the Dana 60. It was huge and weighed a lot. But very strong.
    Most E-body mopars had the mopar 8 3/4" both axles were solid axles with some gear options
    The new Challengers have an independent rear end. I did not see any gear options when I ordered my Hellcat. But I am guessing with todays engineering the independent rear end is stronger and lighter than the Dana 60 of the early 70s. But that is for somebody else to report on.
  5. B5 Blue
    1,745
    I'm better with old school so here goes.
    • Pig or Pumpkin-Removable from housing contains ring gear and pinion shaft. 70 muscle cars used 8 3/4 (it's named after ring gear size) with a 1 7/8 thick pinion shaft, pre 69 so 68 and earlier 8 3/4 had 1 3/4 pinion so not as strong. Option was Trak Pak that gave it a limited slip which are clutch packs on both sides of the carrier(part that holds ring gear).
    • Non muscle cars with 318 or 225 came with 8 1/4 rear end no pig.
    • Then there was Dana 60 which the option was Super Trak Pak which was a 9 3/4 ring gear contained in housing(no pig).
    • 8 3/4 gear ratios 2.76, 3.08, 3.23, 3.55, 390, 4.11. 4.56, 5.12 3.23 was common in muscle cars.
    • 9 3/4 gear ratios 3.54. 3.91, 4.10 from factory.
    • All 69 1/2 Six Pack cars came with Dana 60 and 4.10 gears
    • Dana 60 only could be had with 426 Hemi, 440 and 440 6BBL cars
    Is this what you wanted intercooler
  6. B5 Blue
    1,745
    not me you freakin millennial :p
    • Funny Funny x 1
  7. ljaviation
    ljaviation Self proclaimed Banned, Because I can.
    Feb 10, 2015
    680
    250
    Asheboro, NC
    My '70 340 4 speed car had the 8 and 3/4 with factory 323 gears. I put a set of Richmond 391s and what a difference. Being young and stupid, I decided to do it myself. I did learn that the 8 3/4 has a crush collar that is supposed to be a single use only and puts preload on the pinion bearings when being torqued. Also, the ring gear bolts that held the ring gear on to the "pumpkin" are left hand thread. I learned that after I snapped the first 2 bolts. I thought holy shit these are tight and did they put locktite on these? Um no, they just need to be loosened in the other direction. LH thread. They did that on the wheel lugs on half the car too, but I can't remember which side. Those brain cells are long gone.
    I thought the newer Challengers they took underpinnings from Daimler when they owned Dodge. I thought it was E class stuff.
    That's all I can add.
    L J
  8. B5 Blue
    1,745
    Left side got left hand thread lug nuts
  9. ljaviation
    Feb 10, 2015
    680
    250
    Asheboro, NC
    Thanks B5.
    L J
  10. purnrg
    purnrg BANNED
    Apr 12, 2015
    2,619
    1,154
    588
    Called the W210 platform E, C and S class mostly the same, same as Maserati, Hyundai Genesis, Equuos and I believe a Kia rear drive car probably others too but no one wants to admit it
  11. ljaviation
    Feb 10, 2015
    680
    250
    Asheboro, NC
    Thanks Purnrg. Hell, I'm learning something new and this isn't even my thread.
    Cool beans. I'm just trolling for the past hour.
    L J
  12. purnrg
    purnrg BANNED
    Apr 12, 2015
    2,619
    1,154
    588
    God piece of info, if you nee rear axle seals on an LX get them from a MB dealership they are a Sprinter Part, Chrysler will only sell you a rebut rear end, found that out when I put a 3.43 Gear in my 2008 Challenger, they are a bit of a dog of the line with the 3.06
2015 hellcat irs or solid
2016 charger hellcat solid axel
2016 charger rear axle independent or solid
323 gear for the hellcat
any gear whine with new hellcat
dana 60 independent rear suspension for late model challengers
do the charger and challenger hellcats have different gear ratios
does the dodge challenger have a solid rear axle
