Info for Cats in Cold Storage
Discussion in 'SRT Hellcat General Discussions' started by paul suloff, Jan 21, 2015.
  1. paul suloff
    paul suloff Gold Member
    Aug 25, 2014
    747
    259
    Here in Ohio my cars won't see the roads for a couple months. During storage I like to spin the engine every month or so. This moves the rockers so the same valve springs aren't compressed all winter and spins the oil pump to get some lube up. Problem with these new cars, they start up the minute you hit the key and a short run only puts moisture in the motor and exhaust. Also a cold start adds wear on internals waiting on oil pressure.
    With the Viper I have pulled the fuel pump fuse which worked fine. On the Hellcat it's fuse 26 (30 amp) in the trunk. Pull it spin the motor without starting.
    Also read the owners manual on how to get the car in neutral without starting in case you need to push it around. Pull the cup holder next to shifter. Find the red tether strap attached to the lever, trip the clip on the right side of lever and use the red tether to pull up to unlock. I think all this info is on page 194 in manual.
    • Useful Useful x 3
  2. Jim Hetrick
    Jim Hetrick Silver Member
    Dec 5, 2014
    1,338
    264
    108
    Orange County Cal
    On west coast we just drive them.....................................................................................LOL
    • Funny Funny x 2
  3. B5 Blue
    1,747
    Cold Jim LOL
    • Funny Funny x 2
  4. GeneralLee
    GeneralLee Silver Member
    Oct 31, 2014
    148
    44
    Massachusetts
    I thought it was more about heat and spring compression cycles that wore them. I've seen older V8 motors that were sitting in storage for 10-20 years and after a few small gaskets and other things they fired right up and tested compression and leak downs equally. But who knows with what they're making stuff out of these days, lol. You think it would be better but since we already lost a rocker arm, I'm discouraged.
  5. magnummrk
    magnummrk Platinum Member
    Sep 30, 2014
    3,828
    1,115
    918
    Wisconsin
    I have started mine once/week since I parked it. I also put dryer sheets in the trunk and in the car. this supposed to deter mice. It also make the car smell spring fresh! ;) (seriously I do put the dryer sheets in)
  6. Sublimecat
    Sublimecat Silver Member
    Oct 2, 2014
    934
    348
    173
    Akron, Ohio
    Thanks, good info
  7. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    In the south we drive all the time too LOL
  8. Sublimecat
    Oct 2, 2014
    934
    348
    173
    Akron, Ohio
    You guys just wear them out faster. Ok I'm jealous ;)
    • Funny Funny x 1
  9. B5 Blue
    1,747
    You need to put the visors down also, mice use them to camp out.
  10. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    Lol well I don't drive unless I need to
  11. Gary J.
    Gary J. Hellcat Member
    Dec 28, 2014
    37
    11
    No reason to pull the fuse. If you push the accelerator pedal to the floor then hit the start button it will crank the engine without starting.
  12. magnummrk
    Sep 30, 2014
    3,828
    1,115
    918
    Wisconsin
    Did not know that one! Thanks
  13. Jim Hetrick
    Dec 5, 2014
    1,338
    264
    108
    Orange County Cal
    My neighbor has a car like that !!:):)
    • Funny Funny x 1
  14. paul suloff
    Aug 25, 2014
    747
    259
    I was not aware of that? Is computer not letting it start at WOT?
  15. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,149
    753
    628
    i start my cars 1-2x a winter and let them run for 30 minutes to get all the moisture out of the exhaust
    many people do nothing....just let it sit for 4-5 months
    i really dont think any of it matters
    i think some of you are over thinking
    i keep mine in a heated garage, but i still put a plastic moisture barrier on the floor under the car
challenger hellcat winter storage
storing srt winter
