info for installing KW lowering springs
Discussion in 'SRT Hellcat General Discussions' started by thedynoguy, Mar 22, 2016.
  1. thedynoguy
    thedynoguy Gold Member
    Jun 22, 2015
    169
    126
    493
    Webster, NY
    I've got a set of KW adjustable springs that I'm planning to have a local shop install on my HC Challenger. The instructions that came with the spring kit are weak, to say the least. Is there a baseline adjustable collar measurement that the shop can use to set up the initial ride height? Thanks! TA
  2. rwhite692
    rwhite692 Gold Member
    Jul 17, 2015
    646
    257
    Central Valley, Northern California
    Yes there is, if you search for the threads here on KW lowering Springs you will find them.
  3. ArchGE
    ArchGE Silver Member
    Feb 29, 2016
    306
    103
    113
    Parker, Colorado
    image.jpeg ^^^^ Yep, I copied that post and gave it to the install shop. Works perfect for a 1" drop plus a 1/4" approx. settle. Could have dropped more but do a couple of track days a year and didn't want to mess up camber. They said the camber was still off a fuzz but shouldn't be a problem. Loving these springs and the ride is still similar to stock but more stable on hard cornering. Only thing to keep in mind is the OEM Shock travel is reduced a bit so need to be a little careful on the bumps but not a big deal. Works great in all drive modes.
  4. thedynoguy
    Jun 22, 2015
    169
    126
    493
    Webster, NY
    I found the post, thanks...
