(Installed 12/13/2015) splitter guards came in from ZL1 Addons
Discussion in 'ZL1 Addons' started by carcass, Dec 4, 2015.
  1. carcass
    carcass Silver Member
    Sep 7, 2015
    858
    266
    173
    ZL1 addons sent my splitter guards right out after ordering. They look cool, going to get them in asap.
  2. Dragons90
    Dragons90 Silver Member
    Feb 23, 2015
    203
    82
    178
    Round Rock
    Let us know how easy or hard it goes
  3. terryturner
    terryturner Gold Member
    Apr 1, 2015
    1,268
    372
    Newport, MI
    Just installed mine finally. Pretty easy to install. Took me about an hour total. Only thing I don't like is #1 the blocks don't sit flush with the edge of the splitter. Prolly sit about 1/8" lower. #2 the screw that goes thru the protector and into the block continues up into the splitter. So if for any reason I ever wanted to remove these for some unforseen reason there will be 5 small holes in the underside of my splitter. I know it's not a big deal but just want to make everyone aware
  4. terryturner
    Apr 1, 2015
    1,268
    372
    Newport, MI
    Also, for the 2 outside ones I had to grind down the washer a bit cuz it was too big to fit there. And one of the short ones the bolt hole wasn't recessed like the others so took me a couple minutes to catch a thread. Hopefully it holds. Finally, #2 and 4 I wish there was a way to tighten them with the rubber still in. When I put the rubber close out back in it kinda sits on the block. So maybe those coulda been a tad shorter. This is me just being anal
  5. terryturner
    Apr 1, 2015
    1,268
    372
    Newport, MI
    Here are pix of the non recessed screw and the rubber over the block. In the rubber over the block pic u can kinda see how that screw is recessed a bit to compare to the other one.
  6. Catless
    Catless Silver Member
    Feb 2, 2015
    1,033
    215
    198
    Parkersburg, WV
    I found the same with the washers and slight interference with the close out plugs but it didn't concern me or I would have modified the end of the block.
    Despite being careful, mine tagged the concrete at the bottom of my driveway on about the 3rd trip. So well worth the price and install time.
  7. Dragons90
    Feb 23, 2015
    203
    82
    178
    Round Rock
    Appreciate the info.
  8. BULL
    Nov 20, 2014
    3,758
    1,281
    Would you be able to get a picture from roughly those angles but far enough back to see the entire unit?
  9. terryturner
    Apr 1, 2015
    1,268
    372
    Newport, MI
    I will do that tomorrow. Thinking about removing them all and making them a little more perfect
  10. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,141
    748
    mine were installed long ago, they were missing parts and the company sent me a new set in like 2 days (next day shipping)
    i know they work...mine have scrapes on them and my splitter is mint
  11. carcass
    Sep 7, 2015
    858
    266
    173
    I installed the splitter guards today from ZL1 ADDONS.
    They went on pretty easy,
    the two outside ones that are longest where tight to the edge of the splitter but with some force I was able to push them up to the splitter and run the self tapping screw in. The screw is under considerable tension though and I wonder if I should have modified the end of the protector deal by filing it or grinding to create some space. I would say that ground clearance is reduced by about 1/2" by putting these on.
    Heres a couple bad pictures sorry about the quality.
    december 13 2015 282.JPG december 13 2015 283.JPG december 13 2015 284.JPG december 13 2015 285.JPG
  12. terryturner
    Apr 1, 2015
    1,268
    372
    Newport, MI
    I'm going to remachine mine tomorrow morning. Will repost my results. Shaving about a 16th from each side I think
