Installed Catch Cans and Breather Valve
Discussion in 'SRT Hellcat General Discussions' started by im3cpo, Dec 4, 2015.
  1. im3cpo
    im3cpo Senior Hellcat Member
    Oct 25, 2015
    199
    77
    Seattle
    I have seen a few people post pictures of oil catch can installs, but havent seen anyone use the ones from Billettech, so thought I would share as their mounting locations and brackets are different from all the others I have seen. I also installed a breather valve from Metco in place of the oil fill cap. Here are a few pictures:
  2. Dragons90
    Dragons90 Silver Member
    Feb 23, 2015
    202
    82
    178
    Round Rock
    What is the breather valve do? Relieve pressure in the crank case? I have the same set up minus the breather valve.
  3. im3cpo
    Oct 25, 2015
    199
    77
    Seattle
    Yes, exactly! There is a one-way valve within the neck before the mounted filter so its only "venting" when there is actually pressure there to relieve.
  4. Dragons90
    Feb 23, 2015
    202
    82
    178
    Round Rock
    You take some darn good pictures very clear. This was my first mod so far. What else have you done or plan on doing?
  5. terryturner
    terryturner Gold Member
    Apr 1, 2015
    1,266
    372
    Newport, MI
    I wish that breather valve came apart so I could powder coat or plastidip the chrome parts
  6. im3cpo
    Oct 25, 2015
    199
    77
    Seattle
    Thanks for the compliment on the pictures! :)
    The only other mods I have thus far are visual. The color difference of the stripes (sublime green and matte black) make it very difficult to photograph. Its almost like the color green I used freaks the CCD pickup on the camera! Anyways, I did have the car photographed in a professional studio (yes, its big enough to fit the car inside) but I dont have those "finalized" pictures yet.
    Here is what I have done thus far:
    1) Full Front XPEL Clear Bra
    2) All badges blacked out
    3) Window Tint (including Windshield)
    4) Side markers blacked (wrapped) with LED area exposed
    5) Custom twin matte black stripes with Challenger/Charger grill pattern
    6) Twin sublime green stripes
    7) Side view mirrors outlined in sublime green
    8) Custom made "Hellcat" door sill protectors (same material as sublime stripes but covered with XPEL clear bra)
    ... And technically the green I used isn't really "sublime", but I forget the actual name of the color but used that name so you knew what I was referencing.
    I just got a set of Evolution Sport Z23 carbon/ceramic brake pads (switching out for lower brake dust vs. performance difference) but havent gotten those installed yet. Hopefully this weekend though!
    Here are some misc pics:
    • Like Like x 4
  7. im3cpo
    Oct 25, 2015
    199
    77
    Seattle
    The breather filter is already a separate piece from the portion that installs into the oil filler valve, so just cover the top of bottom of the oil filler part with painters tape and plastidip away! The only area of the filter portion itself is the metal top, so all you need to do is cover the filter with painters tape and you should be all set there too!
    It seriously would be really easy to do!
  8. waiting for mine
    waiting for mine 10/30/15 DELIVERED ON DEVILS NIGHT
    Jul 24, 2015
    310
    111
    Ay im3cpo where did you get your Custom made "Hellcat" door sill protectors? they look sweet bud
  9. Catless
    Catless Silver Member
    Feb 2, 2015
    1,025
    209
    198
    Parkersburg, WV
    I have the same catch can except I used the standard hoses. I don't think I will need the breather unless the engine has a lot of wear on it in later years.
  10. Zebug
    Zebug Gold Member
    Nov 11, 2014
    2,793
    966
    628
    Houston Texas
    love the changes to the car man, looks sharp...thanks for sharing
  11. FireLane
    Jul 23, 2015
    398
    117
    Palm Beach County, FL
    The breather prevents the crankcase from being pressurized which will help stop oil leaks in the future.
  12. greenwithenvy
    greenwithenvy Gold Member
    Nov 16, 2014
    340
    173
    493
    Texas
    I put both catch cans one mine as well. The upgraded aluminum fittings with the "braided" lines were not really what I expected. At a $40 up charge, quite honestly it is a total rip off and the bend radius on the hose was so tight on the passenger side the hose kinked.
  13. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    311
    Oklahoma
    I love the breather and catch can with the black hoses. Were those hoses an upgrade or the standard for that package?
    Also love the textured stripes, what is that called or what brand?
    I'm trying to decide between the CQuarts and the Expel Clear Bra. How much was the Expel for the whole front? I'd like to have the rockers done as well.
  14. TallCool1
    2,439
    829
    Pacific NW
    The car can already vent crank case pressure through the makeup vent line terminating to air intake (termed foul air condition.) One way to stop that is installing a check valve in that line that will shut it down and force pressure flow through the Metco check valve. Which in turn completely eliminates any need for a catch can on the makeup air supply side.
  15. im3cpo
    Oct 25, 2015
    199
    77
    Seattle
    Is the makeup vent line the hose that attaches via the drviers side and into the intake? I have catch cans installed on both sides in addition to the metco breather. If the makeup vent line is somewhere else, can you tell me how to find it? Lastly, any recommendations on how to block the vent to force it to use the metco breather?
bwoody catch can hellcat
bwoody hellcat check valve install
challenger oil cap vent hellcat
crankcase overflow catch can for hellcat challenger
hellcat driver side catch can
