Intermittent blow by on cold start
Discussion in 'SRT Hellcat TSB's' started by mxer14, Jan 4, 2016.
  1. mxer14
    mxer14 Rookie
    Jan 16, 2015
    26
    7
    I've been noticing some "blow by" on cold start after a hot soak. Meaning, if I do some spirited driving and let the car sit until it's cold then restart it, I notice a puff of smoke coming from the exhaust on initial start.
    It's definitely smells like oil is burning. Oil level is still at full and so it doesn't seem to be consuming a lot of it.
    Anyone else noticed this too? I only have about 8500 miles.
  2. themarshall
    themarshall Silver Member Hellcat Car Club Gold Supporting Member HCC Charter Member
    Feb 3, 2015
    229
    51
    Yo MXER14, going by what you are saying it could be nothing, mine does the same thing off and on. 2015 HC. With a everyday average car it could mean valve seal leak, but you and I dont have a average car. Keep your eye on it , I would check oil level when you stop for gas.
  3. mxer14
    mxer14 Rookie
    Jan 16, 2015
    26
    7
    Thanks for the confirmation! I just wanted to know if somebody else had the same experience.
  4. Menesesjesse
    Menesesjesse #147
    Mar 2, 2015
    157
    95
    278
    Maryland
    I have the same issue but the car uses a quart of oil at 2k miles
  5. tsubahog
    tsubahog Gold Member
    Mar 30, 2015
    366
    172
    NJ
    Me too. Dealer SRT mechanic says no big deal as the engine runs so hot. I check the oil every 500 miles. Oil changed at 500 and 2000 miles.
    2015 Challenger with 3100 miles in NJ. Next oil change in the spring.
  6. Paladin06
    Sep 3, 2014
    4,979
    2,121
    818
    San Tan Valley, AZ
    A quart every 2K is not good.
  7. Black feline
    Black feline Rookie
    Jun 4, 2016
    17
    15
    Just bought mine and at 32 miles at startup it gave a puff of smoke. Dealer said the smoke is normal at startup because the hellcat has soft piston rings. I asked my friend which is the main mechanic there and he said the same. As long as it's not excessive I'm not worried.
  8. denis85
    denis85 Hellcat Member
    Feb 15, 2017
    34
    20
    Yup! Same thing here too. Not a huge issue but it's not too alarming either.
  9. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    7,908
    5,473
    963
    Def something to watch and check oil after 3 tanks of fuel. (SRT tech) gave me that tip when the cat is newer.
    I get some light blow by but not everytime. I watch my oil quite a bit. 1,022 miles for me
  10. Mr.yuck
    Mr.yuck Rookie
    Jan 9, 2017
    29
    20
    Mine gave a big puff of blue smoke at about 300 miles, checked the oil and was about 1/2 quart low, topped it off and it still full at 600 miles, mashed the throttle today pretty good through 3 gears, pulled it to a hundred getting on the freeway, no smoke oil still good.
  11. The Ghost
    The Ghost Senior Hellcat Member
    Dec 27, 2016
    60
    63
    Fayetteville GA
    Mine does the same on cold start. After 2k mine was down 2 quarts. Been checking at least once a week and after 4k miles it seems to have stopped.
  12. slowSRT
    slowSRT Rookie
    May 14, 2017
    1
    Get catch cans and it will never happen again.
  13. orrwhat
    orrwhat Hellcat Member
    Jan 19, 2017
    43
    27
    18
    Lubbock Texas
    I would assume it is because forced induction engines need a larger gap on rings which naturally creates a little blow by but nothing to worry about. It can also be condensation in the exhaust at times as well.
  14. d1ws6
    d1ws6 Rookie
    Mar 12, 2016
    2
    1
    I get the same thing . Went through a quart the first 700 miles . When I hit 3k oil consumption went down allot . may be a 1/4 after 1300 miles.
