Is the 8 speed transmission a "dual clutch"?
Discussion in 'Dodge Charger SRT Hellcat' started by Hemibuck, Mar 15, 2015.
  1. Hemibuck
    Hemibuck Gold Member
    Jan 9, 2015
    1,937
    456
    253
    WA
    Just curious if the 8 speed automatic transmission is a "dual clutch" type transmission like in the more expensive rides? I'm hoping that with the paddle shifters that there isn't much delay in shifting. Thanks!
  2. fnkychkn
    fnkychkn Thread Killer Gold Supporting Member
    Jan 24, 2015
    1,663
    736
    633
    greasy cardboard box
    no, it is not a dual dry clutch. it's a conventional automatic transmission with a torque converter.
  3. Hemibuck
    Jan 9, 2015
    1,937
    456
    253
    WA
    Thanks Funky. Been a long time since I've seen you out on the forums. You helped me out over the years on the LX forums!
  4. fnkychkn
    Jan 24, 2015
    1,663
    736
    633
    IIRC, Chrysler says 250 ish millisecond shifts in track mode.
  5. Hemibuck
    Jan 9, 2015
    1,937
    456
    253
    WA
    That's pretty damn quick!
  6. B5 Blue
    1,746
    160 ish in track 250 is normal
  7. Mtr
    Mtr Silver Member
    Jan 13, 2015
    270
    71
    FYI, the ZF 8HP transmission used in these cars is widely admired as one of the best autos in the world, regardless of technology. The same model used in the Hellcat (8HP90) is used in the Rolls-Royce Ghost and Bentley Mulsanne. Variants of the transmission that can't handle as much torque are used by BMW, Range Rover and Audi. Lots of very expensive high performance and luxury cars use the ZF 8HP.
    There is one difference worth commenting on: while the hardware is shared, each manufacturer does its own shift map programming. So each vendor ends up with cars that shift differently. The way it shifts in a car like the Hellcat will be very different from how it shifts in a Rolls!
  8. SRT_HC_707
    Jan 1, 2015
    4,954
    1,445
    70.196059, -148.559760
    It is 160 ms in track mode. It's a sweet A8 for sure! Pretty compact in size too!
  9. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,452
    952
    668
    Cape Coral, SW Florida
    I posted this in Sept elsewhere. Drop it here for people interested. Maybe make a wiki entry
    Sept 2014 - TIGwelder
    I figured since this is new for the Challenger Hellcat, I would dig up some info and we can discuss this new transmission. Here are some informative
    links, a video showing the internals and some specs.
    An interesting thing is the converter can lock in first gear. Were the older units the same way?
    Also it can shift from 8th to 2nd.
    Along with a separate chain driven pump and other optimizations it looks like they worked hard to reduce parasitic loss.
    Main info:
    8HP Automatic Transmissions
    Video: fixed link
    ZF 8HP90 - Video
    Specs:
    8HP90_DataSheet.pdf
    ZF8 Info at Allpar
    845RE / 8R70: ZF 8-Speed Automatic Transmission for Chrysler cars
    ZF 8 Speed Automatic Transmission - Equipment and Tool Institute Tech Day - June13 2012
    Chrysler PDF Document
    Let's look at the transmission ratios for the Hellcat
    1st -- 4.714
    2nd -- 3.143
    3rd -- 2.106
    4th -- 1.667
    5th -- 1.285
    6th -- 1.000
    7th -- 0.839
    8th -- 0.667
    That first gear is crazy. I decided to do this because I wanted to know what was up with all the second gear starts I'm seeing. Then I wanted to compare it to other stuff. And then I just went silly with it :)
    Let's compare it to the NAG1 WA850
    1st -- 3.588
    2nd -- 2.186
    3rd -- 1.405
    4th -- 1.000
    5th -- 0.831
    So second is bit taller than first in the NAG1. ( Hellcat 2nd 3.142 vs NAG1 3.588 = 0.445 difference)
    Let's check out old school with the 904/727 for reference
    1st -- 2.45
    2nd -- 1.45
    3rd -- 1.00
    4th -- 0.69 ( later 4th used with above ratios, even the SRT Ram10 )
    Final Drive Ratio
    For the Hellcat with the 8 speed it's 2.62
    Tire: The 275/40R20 Pirelli P Zero is 28.7 inches in overall diameter.
    Let's look at gear multiplication, first gear comparisons for several ratios/setups.
    Hellcat
    ( 1st x Final )
    4.714 x 2.62 = 12.35068
    (2nd x Final )
    3.143 x 2.62 = 8.23466 (How I've seen people documenting 1/4 mile passes)
    Old NAG1
    ( 1st x Final )
    3.588 x 3.06 = 10.97928
    And to show the gearing now to my old school brain, let's compare it to some older stuff.
    OLD school 727/904 with various gear ratios
    ( 1st x final )
    2.45 x 4.10 = 10.045
    2.45 x 4.56 = 11.172 ( Close to NAG1 )
    2.45 x 4.88 = 11.956
    4.88s and still not there yet!!
    2.45 x 5.13 = 12.5685
    Hellcat vs Old School
    To compare a 1st gear start - Your final drive ratio would be around 5.04 with a 28" tire ( wow )
    To compare a 2nd gear start - Your final drive ratio would be around 3.36 with a 28" tire
    So back to the Challenger Hellcat. Let's look at max speed in each gear.
    It's basically
    MPH = ( RPM x tire dia ) / ( gear ratio x 336 )
    or
    MPH = ( 6000 x 28.7 ) / ( gear ratio x 336 )
    where 'gear ratio' will be ( trans ratio x Final )
    or ( 172,200 / (( trans ratio x Final ) x 336 )) @ 6000 RPM
    AND ( 177,940 / (( trans ratio x Final ) x 336 )) @ 6200 RPM
    1st -- 4.714 x 2.62 = 12.351 ( x 336 = 4,149 ) = 41.5 MPH @ 6000 -- 42.8 MPH @ 6200
    2nd -- 3.143 x 2.62 = 8.235 ( x 336 = 2,766 ) = 62.3 MPH @ 6000 -- 64.3 MPH @ 6200
    3rd -- 2.106 x 2.62 = 5.518 ( x 336 = 1,854 ) = 92.9 MPH @ 6000 -- 95.9 MPH @ 6200
    4th -- 1.667 x 2.62 = 4.368 ( x 336 = 1,467 ) = 117.3 MPH @ 6000 -- 121.29 MPH @ 6200
    5th -- 1.285 x 2.62 = 3.367 ( x 336 = 1,131 ) = 152.2 MPH @ 6000 -- 157.32 MPH @ 6200
    6th -- 1.000 x 2.62 = 2.620 ( x 336 = 880 ) = 195.6 MPH @ 6000 -- 202.20 MPH @ 6200
    7th -- 0.839 x 2.62 = 2.198 ( x 336 = 738 ) = 233.3 MPH @ 6000 -- 241.11 MPH @ 6200 ( we're past the aero limit here )
    Then we enter driving in a vacuum land :)
    8th -- 0.667 x 2.62 = 1.748 ( x 336 = 587 ) = 293.3 MPH @ 6000 -- 303.13MPH @ 6200
    That's right..let it rip to redline in 8th with zero wind resistance and look at the speed!! haha!
    Note: I watched the K&N dyno run, the shift into 6th was around 148MPH, 7th at 191
    So my above results are close. There is some rounding in the above numbers.
    Also the Tire dia used plays a part ( no resting weight, air pressure, using tire specs, etc ).
    So what did I learn.
    - Well, I have to much time for one :)
    - Starting in 2nd has a gearing disadvantage to older NAG1 and gears used before. They have 2nd gear start in valet mode and it would be nice to be able to toggle that feature separately in transmission settings. If 2nd gear start is used then gearing could be changed.
    - It's insane how final gearing in first gear is compared to old school cars. 5.04s on a 28" tire, really? Need to stop thinking old school gearing.
    Questions:
    When does the converter lock? Did I read that it can lock in first gear? ( "The tall first gear allows for early lockup of the torque converter clutch. -- Allpar ). Under what conditions though? When does it lock on launch or hard acceleration?
    Maybe somebody will throw in a spreadsheet to play with ratios/tire sizes
    Anybody want to tackle the 6M??
    Mistakes? :notallthere: Let me know!
    Discuss :)
    Edited:
    v1.02 - Changed/recalculated old NAG1 gearing to 3.06, not 3.09
    - Changed "steeper" to "taller"
    - Added MPH calcs for 6200 RPM
    - Added link for Allpar ZF8 info
    - Added converter lockup quote from Allpar ZF8
    - Added Chrysler document link
    • Useful Useful x 4
  10. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    Very interesting
  11. DShatzer
    DShatzer Gold Member
    Oct 13, 2014
    1,263
    285
    More gears = keeping the engine in its torque band with less revs. Not particularly of interest to HCs, but I am certain it does play a part in the improved mileage for CAFE and other calculations. Nice work, lots of time. Pray for no more CVTs
  12. Fast cat
    Sep 23, 2014
    2,255
    716
    498
    Indiana
    Ok I have no clue on where to start to look!
    So I think I figured it out !
    Press brake put in drive and stomp on gas and pray like hell it stays straight and goes fast!
    • Funny Funny x 1
  13. upnorthstar
    upnorthstar Silver Member
    Mar 2, 2015
    597
    156
    Good info...the 8HP90 handles 737 ft.lbs...some room there to play with...
  14. SRT_HC_707
    Jan 1, 2015
    4,954
    1,445
    This is great info. I didn't check but if you didn't put this in the WIKI section on this site you need to go do that. Great stuff. I'm a dork and I love this stuff!
  15. Bossnova3
    Bossnova3 Silver Member
    Mar 31, 2015
    174
    70
    178
    But very little these cars should exceed that number with a tune and CAI
2014 jeep srt dual clutch
2015 hellcat 8 speed transmission
hp90 transmission
torque flite 8hp ram mod
torqueflite 8 speed transmission ratings
torqueflite 8-speed automatic 8hp90 transmission
zf 8 speed vs dual clutch
zf 8hp dual clutch
