Is the clutch automaticity adjusted, if so is there an aftermarket manual adjuster?
Discussion in 'Dodge Challenger SRT Hellcat' started by Meat, Sep 27, 2015.
  1. Meat
    Meat Hellcat Member
    Sep 12, 2015
    46
    12
    Huntsville, AL
    I am worried that the clutch is set to engage at the top of the stroke and not manually adjustable. If so, is there an aftermarket manual clutch adjuster?
  2. fnkychkn
    Jan 24, 2015
    1,607
    697
    greasy cardboard box
    clutch release is hydraulic, therefore, no adjustment. if contact point is not where it should be (no specs), worn, bent or damaged components can be suspected. best to compare with similar vehicle.
  3. Meat
    Meat Hellcat Member
    Sep 12, 2015
    46
    12
    Huntsville, AL
    I don't have my car yet but my concern is that the clutch engage/disengage point is near the top, such as in the camero. I much prefer the clutch engage/disengage much closer to the floor and wanted to know if there was a way to adjust this location either through stock configuration or an aftermarket part.
  4. Obiefox
    Obiefox Silver Member
    Aug 22, 2015
    381
    97
    Cincinnati
    Clutch engagement has migrated to the top of the stroke for american muscle over the past 5-10 years. I don't like it either, but I think the logic is that it helps power shifting and helps to avoid transmission "lockout" during quick, high RPM shifts.
2009 challenger clutch adjustment
2015 dodge challenger clutch adjustment
adjustable clutch pedal hellcat
clutch engagement point high srt 10
