Issue with DSS drive shaft
Discussion in 'SRT Hellcat Performance' started by Top Cat, Apr 18, 2015.
  1. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    We had an issue yesterday when installing the DSS aluminum drive shaft I wanted to make people aware of, the shaft was perfect,it's the 8 bolts that are used to attach to the rear that are a problem. We started to torque down the bolts and the second bolt failed at 40 ft lbs of TQ, so we took all 8 out and replaced them with the next grade up and finished the install in about 30 min, a call will be made to Frank to make him aware of the issue today. Off to the track to test the shaft this morning:)
    TC
    • Useful Useful x 6
    • Like Like x 3
  2. ROBY IRLE
    ROBY IRLE Silver Member
    Jan 17, 2015
    144
    29
    go get em top cat
  3. SRT_HC_707
    Jan 1, 2015
    4,921
    1,421
    70.196059, -148.559760
    That's pretty scary if they are sending cheap hardware. What is torque spec? What size bolt? I'm assuming it was an 8.8 and you replaced it with a 10.9?
  4. B5 Blue
    1,743
    thanks for sharing
  5. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    671
    224
    Had the same sort of problem installing mine. One of the allen heads started to strip while torqueing . Seems like that bolt head is very shallow and small for 57 #? I'm going on torque specs listed here, there were no instructions with the DS.
  6. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    805
    563
    What track you going too?? You should come next week to e town Friday night or Sunday im gonna be there too
  7. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,204
    276
    Keep us informed of the solution. Hopefully they will make a change to the bolts on future orders. One of the reasons I'm waiting a bit, so little issues like these get sorted out before I order. Thanks
  8. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    DSS has been made aware of the issue and Frank said he will call Bruce @ HHP to get his thoughts and a few pictures of the failure, looking at the bolt there was not much left where the head meets the threads and the failure was the head coming off.
    • Like Like x 3
  9. Noquarter
    Noquarter Gold Member
    Nov 19, 2014
    769
    249
    Columbus, OH
    Do we know if this issue was fixed? I just received mine yesterday.
    Also, do you need to remove exhaust to put it in?
  10. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    I can't say if the bolt was changed, post up a picture if you can, as far as dropping the exhaust no if you have a lift, unhook the two rear fasteners and unplug the cutouts, support the two pipes and let them hang a bit down so you can work around them, if working on the floor it will be easier to drop the entire system.
    TC
    • Funny Funny x 1
  11. Noquarter
    Nov 19, 2014
    769
    249
    Columbus, OH
    Thanks TC
  12. Driver72
    Mar 10, 2015
    1,204
    276
    Funny I must have been in the same batch as you. I got mine yesterday too.
    Got mine through Dr.B
    Have a shop install.
    My local Mopar shop specialists are charging me like $325 to install both aluminum DS and my catback exhaust this Friday.
    For that, not worth dealing with it myself, and worrying about whether or not any mistakes are being made.
    And as I posted a few posts up back in April, this is why I usually wait a bit before buying something that could fail or not perform properly and have serious results because of it.
    TC back in April stated they made them aware of it. I'd think they'd of made the changes on the very next batch, back in April. A lot of people have gotten an aluminum DS since then and not one has mentioned this issue since that I've heard of.
  13. srtfan
    srtfan SRT Hellcat Supporter Gold Supporting Member
    May 29, 2015
    235
    113
    Canada
    Thanks TC. I was stuck on whether to go Aluminum or CF. Both rated to 1000hp (or more) - any advice?
  14. B5 Blue
    1,743
    I called DSS and told them my plans and they said aluminum for me.
  15. VanishingPoint
    VanishingPoint Silver Member
    Jan 6, 2015
    917
    235
    Somewhere, Texas
    ??? More than 1,000 horses?
2016 dodge challenger rt drive shaft problem
challenger drive shaft
dodge challenger hellcat diveshaft torque specs
dodge charger forum aluminum driveshaft
dss drive shaft for manual hellcat
hellcat challenger aluminum driveshaft
hellcat challenger driveshaft
hellcat dss driveshaft shifter issues
