jlt oil catch can
Discussion in 'Dodge Challenger SRT Hellcat' started by cfuels25, Sep 10, 2015.
  1. cfuels25
    cfuels25 Gold Member
    Jul 20, 2015
    240
    258
    513
    toledo
    How many of you guys are running the jlt catch can? Any pros or cons so far? Me and my dad will be putting one on his cat tonight just wanted some input on them is all
  2. HF11CAT
    HF11CAT Gold Member Hellcat Car Club Gold Supporting Member HCC Charter Member
    Mar 29, 2015
    351
    261
    513
    Manchester England
    Installed mine a couple of week ago and was very easy to fit. Checked after a couple of runs and can was empty. My next run was a few hundred miles and once checked again there was oil residue in the can.
    Looks smart and does the job.
  3. cfuels25
    Jul 20, 2015
    240
    258
    513
    toledo
    Very nice thank you for the response I think they are deff worth the money
  4. Fionn MacCumhaill
    Fionn MacCumhaill Irish A'Hole - Wanna Fight About It!? Hellcat Car Club HCC Charter Member
    Nov 14, 2014
    605
    300
    Denver Colorado
    I have had my JLT catch can on for a little over 1800 miles now. I check and drain it after every trip to the drag strip and then again at every oil change. Last oil change it was about 1/3 full (approx. 3 oz. of oil) so it is definitely doing its job. I think my oil amount may be slightly higher than other drivers because I go to the drag strip at least every other week, I daily drive the car, and I drive like an ahole on fire, so your results may vary lol. :D
    Great product though and very happy I bought it.
    • Like Like x 3
    • Funny Funny x 2
  5. TallCool1
    2,435
    825
    Pacific NW
    • Like Like x 3
  6. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,775
    1,153
    498
    Virginia
    Ordered on Thursday, arrived at my house on Friday. Installed Friday night.
    Good product, fully functional. Hoses are preconfigured so it's a 5 minute install.
    - Pop off the stock hose (2 clips)
    - Use two nuts to secure bracket to existing engine stud.
    - Two screws thru bracket into can lid (locktite).
    - Pop new hose ends onto engine connectors.
    Only drawback is that the bracket material is a little thin (but this does allow you to adjust position).
    My one gripe on all units mounting to engine is that they conduct heat to the can. The JLT bracket while thin still conducts heat but far less heat than a billet aluminum arm/stem. Oil vapor would be more likely to condense faster if the unit was not engine block temps (hot). I'm still pondering remoting my JLT to the fender area or adding some gasket material to isolate the can from the bracket to slow down the heat transfer.
  7. Bananahead
    Bananahead Gold Member Hellcat Car Club HCC Charter Member
    May 28, 2015
    272
    135
    Woodinville, WA
    5 minute install, looks like it belongs there and is catching oil. I'm still under 1000 miles but the can has a tablespoon of oil in it already.
    My only continued question has to do with what would be happening to that captured oil if I didn't have the can. Would it REALLY muss things up eventually, and did FCA REALLY miss this in their engine design?
    I have it because I kinda believe keeping oil out of the supercharger intake is a good thing over time, but its hard to get a definitive answer on this.
  8. cfuels25
    Jul 20, 2015
    240
    258
    513
    toledo
    I think over time it wouldnt be a good thing too have oil in the supercharger...I had a 2004 supercharged cobra and had oil in the intake allthe time it needed a catch can bad but ford must have missed that in their engine design aswell along with the FCA
  9. Lord Hellcat
    Jan 6, 2015
    1,609
    726
    UK
    I'm running the JLT catch can. Collected about a tablespoon of oil in around 1000 miles. Far better in the catch can than the intake
  10. Obiefox
    Obiefox Silver Member
    Aug 22, 2015
    378
    97
    Cincinnati
    Why do we think they "missed" it? Maybe it is not actually a problem? :cool:
  11. TallCool1
    2,435
    825
    Pacific NW
    Nothing was missed. Emissions regs prevent venting blowby direct into the atmosphere. A separator was included (proving the need especially on this engine and other forced induction motors which generate more blowyby) its just that the OE setup isn't as efficient as it could be.
    Seems most miss the question that should be more obvious to ask (although I guess it's not intuitive, for some.) What gains are there by directing blowby into your combustion process; answer none it's detrimental to peak performance and has the potential to cause hardware problems down the road.
  12. Obiefox
    Aug 22, 2015
    378
    97
    Cincinnati
    There is an OE separator on the Hellcats?
  13. FreightTrain
    FreightTrain Comfortably Numb
    Sep 13, 2014
    3,514
    1,428
    818
    Endless Mtns of Pa
    yes built into the L shaped valve covers
  14. Obiefox
    Aug 22, 2015
    378
    97
    Cincinnati
    Very cool. I did not know that. Why add another then?
  15. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    Should be easy enough to run longer hoses and fender-mount it or somewhere similar away from heat...although everything under the hood will be hot/warm.
    You don't want any more oil in your intake air than you must have. It can foul your IAT sensor readings, your MAF readings, coat the inside of your super charger, oil slicked lobes...nobody wants that.
    This is a supercharged, positive displacement motor...use a catch can and keep your oil level topped off, especially during the break-in and early miles.
catch can engine light void warranty
catch can for dodge hellcat charger
checking oil on hellcat
hellcat challenger catch can
hellcat jlt or billet technology catch
jlt catch can
jlt catch can for dodge hellcat
jlt oil catch can
