Just had a P025A code come up...fuel pump?
Discussion in 'SRT Hellcat Electronics' started by HCone, May 16, 2015.
  1. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    Just had engine light come on and did a search and P025A popped up, then it went away, engine light still on.
    Trying a hard reset on the system and see if it's just a gremlin.
    Car runs fine, no power loss.
    Car has 1000 miles
    I think it is fuel pump related?
  2. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    805
    563
    What's the build date ? So we have as reference to follow
  3. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    805
    563
    And ask funky chicken he has secret hellcat info on codes and stuff
  4. B5 Blue
    1,745
    ^^^^is correct
  5. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    Build date 01/29, as stated, did hard reset, no code and no engine light so far, will do a few miles tonight and see if it comes back or not.
    It came on during some "spirited driving"
  6. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    805
    563
    On previous cars driving 30-60 miles off hard reset if comes back is problem if not it's a glitch
  7. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    I guess I'll find out tonight, I'll post up later
  8. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,612
    508
    423
    Chattanooga, Tennessee
    Spirited driving in Mexico, right???????????
  9. NX91Notch
    NX91Notch Gold Member
    Jan 8, 2015
    501
    249
    Seminole, FL
    P025A - Fuel pump control circuit open.
    Possible causes are wiring, fuel pump control module, or a PCM.
  10. B5 Blue
    1,745
    Thanks NX
  11. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    44 miles and still off, no codes detected
    Will have dealer check it over next week,
  12. fnkychkn
    Jan 24, 2015
    1,490
    603
    greasy cardboard box
    P025A-FUEL PUMP CONTROL CIRCUIT OPEN
    Theory of Operation
    When the Powertrain Control Module (PCM) receives a ‘Start’ or ‘Run’ signal, it energizes the Fuel Pump relay which sends a continuous 12 volt supply to the Fuel Pump Control Module (FPCM). The PCM also sends a Pulse Width Modulated (PWM) control signal directly to the FPCM which regulates the PWM voltage that will be sent to the Fuel Pump Module. The PWM will vary from 10-100% depending on the input of the Fuel Rail Pressure Sensor and other engine demands. The PCM receives a PWM signal from the FPCM representing the state of all inputs and outputs of the FPCM. This is a Constant Pressure Fuel system which means any pressure test performed on the Fuel Pump would show a continuous pressure (regardless of the changes in PWM). If a pressure sensor fails or other failures are present; The duty cycle goes to a default setting (100%) to maintain fuel pressure.
    When Monitored: This diagnostic runs continuously when the following conditions are met:
    • With the ignition on
    • The Fuel Pump Control Module commanded on
    Set Conditions:
    • The Duty Cycle command from the Powertrain Control Module (PCM) to the Fuel Pump Control Module (FPCM) on the FPCM PWM Control circuit is outside the calibrated threshold.
    Default Actions:
    • When this DTC is set; The FPCM will continue to run the Fuel Pump Module at 100% duty cycle.
    • MIL is illuminated on the second consecutive trip that the diagnostic fails.
    • The MIL will be turned off on the third consecutive trip that the diagnostic passes.
    Possible Causes
    FPCM PWM CONTROL CIRCUIT OPEN/HIGH RESISTANCE
    FPCM PWM CONTROL CIRCUIT SHORT TO GROUND
    FPCM PWM CONTROL CIRCUIT SHORT TO VOLTAGE
    FUEL PUMP CONTROL MODULE
    POWERTRAIN CONTROL MODULE
  13. fnkychkn
    Jan 24, 2015
    1,490
    603
    since you erased the code from PCM memory, your dealer might not be able to help you.
  14. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    Thanks for the info, seems to be fine, had dealer mech over last night ( friend ), he found loose module
  15. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    300 miles and still no code or engine light, so I guess all good now
ford p025a
gm p025a
gm p025a-00
p025a
p025a chevy
p025a code
p025a code jaguar
p025a vw
