KB BAP and plugs
Discussion in 'Dodge Challenger SRT Hellcat' started by Bucks666, Oct 25, 2015.
  1. Bucks666
    Bucks666 Silver Member
    Apr 21, 2015
    168
    55
    Central Ohio
    Anyone running a BAP ? KB shows two a street and a competition which one is sufficient for some pulleys, tune, headers, injectors. Also looking to go one step colder plugs , which is better brisk or ngk? I've used both in the past but can't find the right part #.
    Thanks in advance
  2. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    Bucks, unless you are modding the car the stock plugs are fine, if modding NGK's are a better plug, BTW did I mention how much a PITA it is to change plugs?
    Also you don't need a BAP, most people don't know that the Hellcat has one built in from the factory and can be verified if you put a meter on the line.
    TC
  3. Obiefox
    Obiefox Silver Member
    Aug 22, 2015
    378
    97
    Cincinnati
    Tell me more about this built in boost a pump....how much can the stock pump flow?
  4. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    My car is 900 HP plus and is running the stock pump no BAP
    TC
  5. Bucks666
    Apr 21, 2015
    168
    55
    Central Ohio
    Thanks TC ... Im definitely interested in learning how the stock pump picks up the flow rate . Does the computer adjust the amount as needed or will my tuner need to set all this ? I actually have just about everything to install now so what plugs are you using , # if you have it sir.
    I've done plugs and such in many other street cars but man looking at this setup it's gonna be a mother getting to . Headers aren't looking to easy either !
  6. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    The cars electronics will make the voltage changes as needed, I will have to check on a number, but they were NGK's.
    TC
  7. Obiefox
    Aug 22, 2015
    378
    97
    Cincinnati
    Do you know the maximum flow rate of the factory pump or pumps and control module?
    I'm still not sure what you mean by we have a built in BAP. I understand that factory returnless fuel pump control modules vary fuel pressure and flow by changing the voltage delivered to the pump, but the BAP allows for an additional voltage increase to command increased flow beyond the factory parameters.
    I come from the Ford world and am still learning on these HC's.....
    thanks,
    Kevin
  8. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,668
    2,027
    Top Cat, Have you thought about running on E85 ???
bap install on hellcat charger
boost a pump install hellcat
hellcat 1 step colder plug
hellcat boost a pump
kb bap hellcat
