Keep an eye on your Metco Pulley. EDIT: Use Threadlocker - Pulley Bolts Loosened
Discussion in 'SRT Hellcat Builds' started by weebz, Sep 24, 2016.
  1. weebz
    weebz Gold Member
    Jan 17, 2016
    355
    329
    513
    I was able to avoid tragedy today by picking up on an unusual noise. I pulled the car out of the garage to go check my mail at my shop. I walked around the front of the car to shut the garage door and everything sounded fine. I drove 7 miles, got out of my car to walk to the mailbox and I heard a frightening chattering sound. It was obviously coming from the supercharger snout in the area of the pulley. Against my better judgement, I very carefully drove the car back home. My fear was that the bearing was going out on my brand new installed Metco upper pulley. After closer inspection I was able to tell that 2 of the 6 bolts holding the pulley on the hub had backed out about 40% of the way and the other four backed out 10%. We were able to back to 6 bolts out take the pulley off which did have significant damage around the bolt holes from the chattering. We were still concerned about further damage and bearing damage as a result of this pulley coming loose.After we put Loctite on the 6 bolts and got everything back together it sounded normal but I am concerned about bearing wear.
    Please do an inspection of your metco pulleys, it wouldn't hurt to put a allen wrench on the bolts and give them a turn to see if they have moved. I also dabbed each bolt with red fingernail polish for a quick visual inspection.
    As you can tell from the picture below, I had damage around all 6 bolt holes which is evidence that all 6 screws backed out some.
    Catastrophe avoided!
    • Useful Useful x 2
  2. ArchGE
    ArchGE Silver Member
    Feb 29, 2016
    318
    104
    113
    Parker, Colorado
    Looks like the lock washers spun on soft metal. That's pretty bizarre.
  3. cole3986
    cole3986 Gold Member
    Apr 25, 2015
    1,762
    912
    563
    Lawrenceville, NJ
    why would you think there would be bearing damage? Are your sure that they were properly torqued?
  4. 19Dart69
    19Dart69 Silver Member
    Apr 9, 2016
    311
    101
    113
    Did the bolts originally have loctite on them when they were first installed? Highly unlikely there's any bearing damage.
  5. Racist Cat
    Racist Cat Silver Member
    Jan 28, 2016
    1,385
    494
    I used blue loctite on all mine, and the cover bolt.
    Was very disappointed there was no torque value given.
  6. weebz
    weebz Gold Member
    Jan 17, 2016
    355
    329
    513
    Any time you have parts spinning at high a very high speed and the drive pulley comes loose and is now wobbeling and spinning untrue, you will certainly transfer that unbalanced load to the bearing which would indeed be your next failure. At this point it looks like we avoided bearing damage.
  7. cole3986
    Apr 25, 2015
    1,762
    912
    563
    Lawrenceville, NJ
    The belt tensioner would absorb the wobble, since it is still attached and on the hub, I doubt the wobble could be that severe.
  8. TallCool1
    2,401
    798
    Pacific NW
  9. Viper04
    Viper04 Senior Hellcat Member
    Feb 14, 2016
    268
    78
    Wisconsin
    Weebz
    Just asking did you use loctite on all the bolts? Matco provides some with all there pulleys. I can't tell from the first picture. It's just odd that with loctite and a lock washer they would all back out. Good you found it in time.
  10. Wack_Cat
    Wack_Cat Senior Hellcat Member
    Feb 5, 2016
    175
    27
    Northern Colorado
    I use high heat race lock tight
  11. J Schiz
    J Schiz Hellcat Member
    Aug 11, 2016
    112
    22
    18
    Southland
    wassup with the white can man...looks lik n old dog terd
  12. weebz
    weebz Gold Member
    Jan 17, 2016
    355
    329
    513
    Wow! Here we go. Dude your car looks like you dropped a piano on it and you want to knock a feature that most of us have.
    You have insulted the thread, but what you have done to your car is unspeakable!
    Go find a tunner site to hack, your not wanted here.
    Educate yourself before you come back.
    • Funny Funny x 2
  13. PlumTexasCrazy
    Oct 3, 2015
    2,292
    689
    308
    Central Texas
    Weebz, was any lock tight detected, before u corrected and installed?? Hope all is well!! Great save!!!
  14. weebz
    weebz Gold Member
    Jan 17, 2016
    355
    329
    513
    If there was locktite it was minimal, there were some minor indications. Perhaps one of the greatest failures may have been, must have been, that the bolts were not tight enough.
  15. PlumTexasCrazy
    Oct 3, 2015
    2,292
    689
    308
    Central Texas
    I didn't realize, there is no torque spec! Great info and thanks for sharing!!
