KW HAS Lower springs installed
Discussion in 'SRT Hellcat Appearance' started by Billet Hellcat, Apr 12, 2015.
  1. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,064
    645
    413
    So Cal
    I had a few extra hrs at work tonight so I decided to install the KW Height adjustable Spring kit in my HellCat I took pics and will do a write up soon but too late tonight here is a before and after pic for now hard to see it was dark I will get some better pics up.:D BTW I want to Thank Member StellasHC for there post on this kit helping me save time with height adjustments and Speedlogix for the deal on the Kit ;)
    Install reference below!
    • Like Like x 9
    • Winner Winner x 2
  2. mblasr
    mblasr Silver Member
    Jan 13, 2015
    268
    117
    Northern California
    More pics bro. How long did it take
  3. Billet Hellcat
    Dec 2, 2014
    1,064
    645
    413
    So Cal
    KW adj springs install. Ok the install instruction are good on how to assemble the new springs but give no help in the removal of the factory units so I took a few pics as I installed my kit to help out other members that may run into a few problems along the way.
    Install time 1hr per side. Note: the measurements for the adjustments are for a 1" drop that may be 1 1/4" after settling.
    Front :
    1. Jack up vehicle I did one at a time with a low profile floor jack. Place a jack stand and remove the wheel I used a Mac 7/8" wheel socket with the plastic to protect the rim. Follow the wire from the shock the connector is behind the plastic fender and disconnect it. Remove the sway bar link remove the lower strut bolt and open the hood and remove the plastic cap and the 3 nuts holding the upper strut mount. Next you need to separate the upper control arm ball joint,loosen the nut but do not remove it all the way leave 2-3 turns on it then hit the end of the Upper spindle under the UCA with a hammer and it will pop loose. Support brake disc and remove the upper control arm nut and it will lower and move forward so you can remove the strut assembly. After removing the strut assy put the upper control arm back in the spindle and nut on finger tight to hold it together.( do not let it hang on the brake hose) Disassemble the strut with spring compressors (note the position of the top strut mount & spring you need to keep that in the same position when installing the new spring) see instruction with the kit to remove stock parts and to assemble the new spring and mounts. Install the strut assy in reverse order as it came out. I set the new spring adjustment to 5/8" from the bottom to the purple adj nut and tightened the set screws it gave me. 1" drop. Remove the UCA nut install the strut upper 3 nuts , UCA nut to spindle and tighten. Lower strut bolt and tighten upper & lower strut nuts & bolt , install sway bar link and run wire and plug in shock connector. Double check to make sure everythiInstall wheel & lugs and do the other side.
    Here are some reference pics:
    1. Strut assy UCA & spindle nut
    2. Plug for the shock assy behind plastic fender
    3. UCA & spindle separated with strut removed
    4. Nut put back on UCA & spindle.
    5. Oem strut assy.
    6. Spring compressors.
    7. Oem strut stripped down and assembled with KW kit
    8. KW strut installed.
    • Useful Useful x 2
  4. Billet Hellcat
    Dec 2, 2014
    1,064
    645
    413
    So Cal
    Rear spring install is much easier than the front took about 1/2 hr per side: also the adjustments that I made was for 1" drop after settling it may be 1 1/4"
    1. Jack up body and install jack stands remove rear wheel support cradle with jack remove 2 long bolts holding cradle in place note (only do one side at a time) remove 2 upper shock mounts and lower shock mount you (will remove the shock to install KW bump stop) lower cradle slow watch brake line it is short lower just enough to remove the spring & upper rubber spring mount. Set new KW rear adjuster 1/2" from adj nut to adj end put adj assy up against body and install spring ( make sure you time the new spring with the stock lower rubber mount) remove top shock mount remove oem bump stop and install new KW bump stop. Install shock jack up cradle and install 2 cradle bolts & tighten. Install shock bolts & tighten. I hope this post may help out members. Here are a few pics.
    Oem spring,bump stops,cradle bolts
    Cradle front mount
    Rear upper shock mount
    New KW rear spring assy
    • Useful Useful x 6
    • Like Like x 4
  5. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
    • Agree Agree x 4
  6. Chippy
    Chippy Silver Member
    Nov 27, 2014
    623
    130
    Alberta
    Looks good great write up. Pls include ride impressions. Mods should make a sticky?
  7. White Trash
    White Trash BMF Hellcat Car Club HCC Charter Member HCC National Vice Pres.
    Oct 23, 2014
    1,074
    395
    258
    (Undisclosed Classified)
    Great write up spot on !!!!
    Thx
    WT
  8. Srt8u
    Srt8u Silver Member Hellcat Supporting Vendor
    Mar 21, 2015
    697
    Car looks great, nice writeup! Thanks again for the business!
  9. Billet Hellcat
    Dec 2, 2014
    1,064
    645
    413
    So Cal
    Here is a pic with the sun setting :D
  10. ArtOfNoize
    ArtOfNoize Silver Member
    Sep 24, 2014
    268
    94
    Toledo Ohio
    Looks great. I've had these springs for a few weeks now just sitting in the garage. I have not had the time but your write up will help speed the process when I do. Much thanks.
  11. Speedlogix
    Speedlogix Gold Member Hellcat Supporting Vendor
    Mar 27, 2015
    684
    323
    West Palm Beach, FL
    Wow, that looks terrific. Great write-up, too. Thanks. :)
  12. Billet Hellcat
    Dec 2, 2014
    1,064
    645
    413
    So Cal
    A few more pics settled nice rides great too;)
  13. NX91Notch
    NX91Notch Gold Member
    Jan 8, 2015
    501
    249
    Seminole, FL
    How far does this put the camber out of spec?
    Or is it still hanging in the acceptable range?
  14. Fiveinch
    Fiveinch Hellcat Member
    Apr 15, 2015
    93
    36
    18
    Any tire-rub throughout stop-to-stop turn radius?
  15. Billet Hellcat
    Dec 2, 2014
    1,064
    645
    413
    So Cal
    Going in for alignment next week wanted the car to settle and only 1 guy I will let set up my car.
    No none at all.
2015 charger lowered forum
challenger hellcat lowering springs
challenger spring install instructions
hellcat sway bars installed forum
kw hellcat springs
kw installation springs hellcat
lowering springs for hellcat
