LARGER rear tires
Discussion in 'Dodge Challenger SRT Hellcat' started by jaybird12, Nov 3, 2015.
  1. jaybird12
    jaybird12 Hellcat Member
    Jan 26, 2015
    55
    4
    Newport Coast, CA
    I have 305 Nittos in the rear ... they work OK on stock rims... no problem.
    Has ANYONE successfully reworked wheel well to fit larger tires... without major re engineering?
    Thanks for any input from those who have done it!
  2. Halfshaft
    Halfshaft Silver Member Hellcat Car Club
    Oct 30, 2015
    185
    88
    178
    Waxahachie, Texas
    I am running 315/35/20 MT's drag radials on recommend Mickey Thompson Challenger rims at 16 lbs have 11 1/2 rubber on ground, street I run 28 lbs. Clearances good around tire, could run 325's I would have to check the inside splash plastic gard with the 315 only get my pinky between tie and gard, that's the area in front of rear tire, good clearance everywhere else.
  3. jaybird12
    Jan 26, 2015
    55
    4
    Newport Coast, CA
    Thanks for the info... what width rims? Which model m/t rim? I am considering Bravado 18" 11 W and mounting 315/40/18 Nittos.
    My current 305 NIttos actually rubbed a bit of the plastic splash guard away... a bit larger may have to massage a bit.
  4. Halfshaft
    Oct 30, 2015
    185
    88
    178
    Waxahachie, Texas
    Mickey Thompson, Street Comp SC-5 part #3020415, rims 20x10.5
  5. jaybird12
    Jan 26, 2015
    55
    4
    Newport Coast, CA
    Thanks... that offset/parameter must be the magic size to fit 315s with no mods... NOW if have to figure it out if I lower the car One inch!
    Does it appear you have room left on the inside and out if you lowered one inch?
    Thanks again for the input.
    Do you have photo of the wheel/tire you could post (I cannot quite see it in your profile photo)
  6. Halfshaft
    Oct 30, 2015
    185
    88
    178
    Waxahachie, Texas
    There in Ohio at brothers, left them there to run at Norwalk drag strip and National Trails drag strip in Columbus, didn't think to take picture of them on the rear. Lowering your car probably would clear sitting still, but driving hitting a dip in the road might push tire up to far in wheel wields and rub.
  7. Greenkat
    Greenkat Rookie
    Oct 29, 2015
    22
    15
    Just wanted to share because it took me looking through lots of posts about the Nitto 305/35-20 555R on the rear to see how much trouble this would be. Turns out it was very easy and I actually had Firestone put the new tires on for me and balance them and they had no issues. There is absolutely no rubbing and they stick to the road way better than the Pirelli summer tires. Ebay has them for $640, but every so often than have a coupon code for $100 off of a tire purchase over $400. These two tires for $540 isn't too bad if you wait for the coupon code.
    They bubble out a little bit but not too much. No issues with these whatsoever. Great purchase - should get 10,000-15,000 miles out of them.
    2 NEW 305/35-20 NITTO NT 555R DRAG 35R R20 TIRES
  8. Hemi Rocket
    Hemi Rocket Gold Member
    Sep 27, 2015
    1,570
    522
    273
    Albany NY
    Thx for sharing they look great! Are you doing the DS as well?
  9. Gallitos98
    Gallitos98 Active Hellcat Member
    Aug 30, 2015
    106
    36
    28
  10. Greenkat
    Greenkat Rookie
    Oct 29, 2015
    22
    15
    I haven't yet but I plan to when it gets warm again in the spring! They are great everyday tires as well.
charger hellcat rear tires
ford mustang hellcat wheels fitment size
hellcat 315 tires in rear
hellcat rear tires
larger rear tires 305 hellcat charger
largest rear wheel challenger srt
mickey thompson 305 challenger
tire forum larger sizes on rear
