largest tire front
Discussion in 'SRT Hellcat Wheels and Tires' started by BALZ-OUT, Oct 16, 2015.
  1. BALZ-OUT
    BALZ-OUT Hellcat Member
    Oct 8, 2015
    61
    20
    NEWYORK
    Hey Does anyone know what is the largest tire that fits on the front with out rubbing? im looking into putting Hankook R-S3 V2. they run big according to tire rack the 255/40ZR20 are 10.6" side wall width & 9.5" thread & the 285/35ZR20 are 11.7" side wall width and 10.6" thread width. trying to decide on which to put on the front.
    can anyone help
  2. Teo
    Teo Judge Yooper
    Jun 7, 2015
    889
    443
    Yooper Land
  3. DGatzby
    Jan 16, 2015
    3,397
    1,778
    598
    Twin Cities, MN
    First how much room do we have to add, with the OEM wheels? I can barely get a finger between the tire and the suspension.
  4. Teo
    Teo Judge Yooper
    Jun 7, 2015
    889
    443
    Yooper Land
    OEM of 275-40-20 is 28.7" dia. x 10.8" width The 295-35-20 is 28.1" dia. x 11.6" width should not rub, but?? The 305-35-20 is 28.4" dia. but 12" width :-(
    Per their steer sizes of 748mm(29.4") x 285mm(11.2") is MAX for proper tire clearance, but does not address full suspension compression with full (left or right) lock turns.
    Rear fitment appears to be approx. 345"s max to 315's but with-out actual testing it is just a WAG?
    Their size comparator helps to visualize most of the what if's???
    Per rimsntires calc's
    OEM tires: 275/40-20 (728x275mm). Big Brakes. Bolt pattern: 5x115. Offset: 15 to 22 mm. Tires up to 748x285mm (front). Rims up to 23x10.0" (front).
  5. DGatzby
    Jan 16, 2015
    3,397
    1,778
    598
    Twin Cities, MN
    I can tell you rear, the magic max number is 10.5" rim, 25-27mm backset; Nitto and most other 315/35's. Look great, work good and guys are able to lower them also.
    Those fronts seem to indicate the 275's are about it. Lots of numbers above, but that is what I read.
  6. Teo
    Teo Judge Yooper
    Jun 7, 2015
    889
    443
    Yooper Land
    285-40-20 on oem rims may be the max? Until fully proven out. I'll stay with the 275-40-20 on my steers. Especially with some of the tire brand variances.
  7. Puffy
    Puffy Gold Member
    Jan 23, 2015
    1,117
    460
    258
    Hanover, Maryland
    Up front I'm sticking with 275. On my stock rears I have 295s and they fit perfectly. Planning to lower the ride so keeping my staggered setup sane.
  8. BALZ-OUT
    Oct 8, 2015
    61
    20
    NEWYORK
    im putting them on Forgeline GA1R OPEN LUG wheels on. Accordind to Howey Industries Inc
    www.howeyindustries.com
    We normally do:
    20x9.5 +18 / 20x10.5 +29
    or
    20x9.5 +18 / 20x11 +35
    im going with the 10.5
    on Rims&tires.com the say 285/35 goodyear F1 supercar will fit in front which are 11.4 wide sec width. the R-S3 285/35 run a little wider at 11.7 wide. i think they might fit.
  9. DGatzby
    Jan 16, 2015
    3,397
    1,778
    598
    Twin Cities, MN
    Go for it, please let us know the fronts' magic tolerance for larger rubber. Me and others, hope to use the 9.5" OEM rims and obviously get a sticker and little wider tire on the front for off road racing purposes. I like that you are sticking with the OEM width and backset for the fronts. Good luck!
  10. BALZ-OUT
    Oct 8, 2015
    61
    20
    NEWYORK
    i already pulled it on the wheels. im going to pull the trigger on the ventus R-S3 305/35 in the rear and 285/35 in the front. ill let everyone know. hope i dont wast on the front. just for info the R-S3 255/40 are very close in width to the 275/40 P-ZERO's. these tires run wide
  11. BALZ-OUT
    Oct 8, 2015
    61
    20
    NEWYORK
    heres a pic of the wheel they weigh 19lbs
  12. BALZ-OUT
    Oct 8, 2015
    61
    20
    NEWYORK
  13. BALZ-OUT
    Oct 8, 2015
    61
    20
    NEWYORK
    im still up in air for the front 255 or 285. i dont know why but i cant pull the trigger. i need a push on one or the other
    heres the P-zero specs that the cat comes with
  14. Puffy
    Puffy Gold Member
    Jan 23, 2015
    1,117
    460
    258
    Hanover, Maryland
    I'm staying with the 275/40s up front. I wanted to go with the 285s but I wanted a stay with a 40 series tire.
  15. HC MEOW
    HC MEOW Hellcat Member
    Jan 24, 2015
    59
    7
    I have Michelin Pilot Sport 295/35 20 on factory wheels all around with no problems.
    • Winner Winner x 2
2853520 front challenger hellcat
biggest front wheel and tire hell cat charger
front tires on the dodge hellcat
largest front tire charger srt
largest front tires for hellcat
largest wheel on charger srt
what is the widest wheel and tire for 2011 dodge charger
widest tires for 22 charger forum
