launch control in manual
Discussion in 'Dodge Challenger SRT Hellcat' started by bighit2883, Apr 16, 2015.
  1. bighit2883
    bighit2883 Gold Member
    Mar 15, 2015
    1,389
    496
    358
    How does this work with the M6? I have not yet played around with it yet. Anybody care to share how to use it with the manual?
  2. StellasHC
    StellasHC Platinum Member
    Nov 18, 2014
    1,836
    1,333
    933
    Kenosha, Wisconsin
    You can set up the rpm up to 4250 (I think) in 250 rpm incriments... push the launch button on console. Dash will display "push clutch and depress throttle" or something like that... floor accelerator pedal and it will hold at your selected rpm.. dump clutch and off you go!
    Ive tried it a few times with drag radials. At 3750 rpm set point it spun a couple feet and bogged down pretty bad.. did 3.9 0-60.
  3. bighit2883
    Mar 15, 2015
    1,389
    496
    358
    This is unrelated but my car has bogged down bad a few times when I've been going like 39 in 3rd gear and then mashed the gas. It bogged real bad. Has ur ever done that
  4. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    LAUNCH CONTROL
    Manual Transmission — If Equipped
    Vehicles with a manual transmission have an adjustable launch RPM controlled through the Uconnect® system.
    Launch Control is only available when the following procedure is followed:
    1. Pressing the “LAUNCH” button on the center stack switch bank.
    NOTE: Pushing the SRT button on the center stack or pressing the “SRT & Apps” button on the touchscreen are two other options to access launch control features. Please refer to “Uconnect® Settings” within your Own- er’s Manual on the DVD for further information.
    2. Press the “Launch RPM Set-Up” button on the touch- screen. This screen will allow you to adjust your launch RPM’s for optimum launch/traction.
    3. Press the “Activate Launch Mode” button on the touchscreen.
    4. Make sure the vehicle is not moving.
    5. Make sure the steering wheel is pointing straight.
    1. Fully depress the clutch pedal and make sure the vehicle is in first gear.
    2. While holding the clutch depressed, rapidly apply the accelerator pedal to wide open throttle. The engine speed will hold at the pre-selected launch RPM. The engine speed will hold at the RPM that was set in the “Launch RPM Set-up” screen.
    NOTE: Messages will appear in the Driver Information Display (DID) to inform the driver if one or more of the above conditions have not been met.
    8. When conditions 5 through 8 have been met, the Driver Information Display (DID) will read “Launch Ready Release Clutch”. Release the clutch quickly and continue to hold wide open throttle to launch execute shifts. Refer to “Manual Transmission – Shifting” in this section for further information.
    Release the brake and continue to hold wide open throttle to launch.
    9. Keep the vehicle pointed straight.
    Launch control will be active until the vehicle reaches 62 mph (100 km/h), at which point the ESC system will return to its current ESC mode.
  5. StellasHC
    Nov 18, 2014
    1,836
    1,333
    933
    Kenosha, Wisconsin
    No never had an issue like that. However, if I nail it at 40 or so mph, I am always in second gear... better yet, put it in second at 40 mph, traction control off, push in clutch and rev it to about 5000 rpm and dump the clutch/ floor accelerator at the same time... f*#k yes
    • Funny Funny x 2
  6. bighit2883
    Mar 15, 2015
    1,389
    496
    358
    Haha oh believe me I've done that plenty. But yeah with the issue i had i was just slow rolling down the road thats patrolled heavily so i just wanted to keep my speed down and noise level down but had to kick it down quickly and it bogged crazy bad
  7. StellasHC
    Nov 18, 2014
    1,836
    1,333
    933
    Kenosha, Wisconsin
    Ill try exactly what you are describing tomorrow and report back.
  8. bighit2883
    Mar 15, 2015
    1,389
    496
    358
    Now i can't remember if it was 39 or 31 lol. Try both but in 3rd
  9. StellasHC
    Nov 18, 2014
    1,836
    1,333
    933
    Kenosha, Wisconsin
    31 is WAY too slow for 3rd gear.. I cant remember the last time I was in 3rd at 31mph. Lol.. try going 31mph in first and punching it.. see if it bogs then;)
    • Funny Funny x 1
  10. bighit2883
    Mar 15, 2015
    1,389
    496
    358
    So i tried luanch control....left it at the lowest rpm setting and i did everything right....or so i thought. When holding wot it puddered....i released the clutch and the car stalled. Help!
  11. StellasHC
    Nov 18, 2014
    1,836
    1,333
    933
    Kenosha, Wisconsin
    you will hear it sound like it is hitting the rev limiter with your foot to the floor with the accelerator. Keep it on the floor the whole time. Quickly release clutch and keep gas floored.. 1st gear. It will spin, then bog, then maybe spin a bit more. Quite a waste of time on street tires. Drag radials might be ideal.
  12. Shake&Bake
    Shake&Bake Back to (1) Club?
    Mar 9, 2015
    1,260
    780
    733
    The United State of Texas
    Turn off launch control and try this method. See video
    • Like Like x 3
  13. Ohiotj
    Ohiotj Silver Member
    Nov 29, 2014
    370
    118
    I tired the launch control once and it failed pretty bad. Had it set to 3k and dumped the clutch. It bogged down. My thoughts are this.
    1. I may need to launch at a higher rpm.
    2. I need to ride the clutch pedal out.
    3. The computer doesn't like any wheels spin and kills power at the first sign.
    My guess is the clutch needs to be let out slower.
  14. StellasHC
    Nov 18, 2014
    1,836
    1,333
    933
    Kenosha, Wisconsin
    I would be careful "riding" that clutch. Too much heat is a no no.
  15. Cruisin1966
    Cruisin1966 Gold Member
    Nov 8, 2014
    1,147
    256
    Calgary
    Are you in "track" mode?
dodge challenger hellcat manual transmission
hellcat
hellcat launch control
hellcat launch control manual
hellcat launch control manual transmission
how to use launch control challenger
how to use launch control on 2015 dodge challenger manual transmition
