Launch control
Discussion in 'SRT Hellcat General Discussions' started by sahak, Nov 8, 2015.
  1. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    I've been trying out launch control lately. First few times I used it with traction off at 3,000 rpm and had the throttle all the way down and she just hooked and took off but ever since then it doesn't hook it just spins out. I am trying this on the street I haven't been on the drag strip yet. Also if I punch it on first gear at about 4K rpm it won't spin but when I shift to 2nd gear it will spin out. How the hell do I not spin out?
  2. Aaron Vogel
    Aaron Vogel Silver Member
    Jan 23, 2015
    1,311
    235
    198
    Everywhere
    I haven't gotten to play with it too much, the couple times I tried it real quick, the car just spun as well. But, to your comment about doing it on the street, that is whatit was for. Our launch control was designed more for use on the street then on a track. On a track it can actually affect your times
  3. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    Ya I figured that but I was thinking maybe something isn't working right?
  4. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    701
    154
    McKinney, TX
    I can't get mine to work too well either. It almost always spins the tires so much that it turns itself off. It says "Launch Control Cancelled".
  5. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    That hasn't happened to me yet. Are you on the stock tires? I have the 555's on mine and it still spins out really bad
  6. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    701
    154
    McKinney, TX
    I've tried it on the factory summer tires and 555's. Was obviously better with the DR's, but it still happened.
  7. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,472
    758
    Virginia
    Try 1800 rpm, start in 2nd gear, manual shifting
  8. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,442
    258
    The Boonies
    launch control is tricky. you need everything set right and the steering wheel STRAIGHT. any amount of left or right will cancel it out
  9. HOONAGN
    HOONAGN FLOOR IT!
    Jan 28, 2015
    254
    133
    Fullerton CA
    Launch control on these cars is a joke really.
    2nd gear roll to mash FTW. Unless you have an upgraded DS - then mash the fugger.
    • Funny Funny x 2
  10. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    701
    154
    McKinney, TX
    I didn't think starting in 2nd gear was necessary when using launch control. Maybe that's what I've been doing wrong.
  11. Cerino2000
    Cerino2000 Gold Member
    Nov 8, 2014
    528
    130
    The trick (at least in the autos) is that the car has to detect a certain amount of pressure on the brake pedal. I can tell you it is more pressure than what you'd expect. I have a video of the process on here some where. Just search launch control.
    • Useful Useful x 2
  12. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    We played with the launch control early in testing as it was supose to drop some of the trans TQ management, but it really never worked right, to this day I'm not sure what the engineers in visioned this would be used for,LOL
    TC
    • Funny Funny x 1
  13. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    I tried it at 3500 rpm and it hooked and took off. Tried again at 3000 rpm and just spun out lol
    • Funny Funny x 1
  14. Hemi Rocket
    Hemi Rocket Gold Member
    Sep 27, 2015
    1,488
    Albany NY
    I thought the launch control was really intended for a car with Slicks or DR... not a street tire. Trying it with the stock Perelli's on the street... it just blows them off like a Funny Car doing a burnout. I haven't played with it much (Yet) so I can't pass judgement on if it is effective.Just curious... you guys racing your cats, what is your launch technique?
  15. Mtr
    Mtr Silver Member
    Jan 13, 2015
    262
    69
    I think they must've had a summer intern design their launch control. In other high power cars with proper launch control, like a 911 Turbo S, once it's engaged you just release the brake and the car manages power to keep the tires *right* on the edge of adhesion -- basically exactly what ABS does, only under power instead of braking. So the norm in a car like that is perfect launches time after time. It boggles my mind that Dodge's idea of launch control is just a rev limiter. It's not like this is a cutting edge concept; other cars have had this type of advanced launch control for years.
