Low boost and horsepower?
Discussion in 'SRT Hellcat Performance' started by Mopar22, Feb 9, 2016.
  1. Mopar22
    Mopar22 Gold Member
    Jan 9, 2016
    215
    98
    278
    New Mexico
    Is there an issue with my hellcat? Last week I did a few WOT runs and on my performance page max boost was 9psi and max hp was 637 , it was 47 deg outside. Today I did a few more WOT runs and boost maxed out at 9 psi and hp only got up to 589, outside temp was 63 deg. I have 963 miles on the car and live up at 5,300 ft above sea level. Are the low numbers a result of the altitude or possibly something else? On another thread others report seeing as high as 720 hp. Anyone with knowledge on this subject? Thanks.
  2. Hammer Down
    Hammer Down Gold Member
    Jan 11, 2016
    407
    257
    South Jersey
    That would be the best answer. Many have seen like 2lbs less boost in high altitude.
  3. Top Cat
    Top Cat Gold Member Hellcat Car Club Fastest Cat/Record Holder HCC Charter Member
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    In that elevation you could get away with a Metco 2.85 upper pulley and NO tune.
    TC
  4. NorCaletch19He77Kat
    Aug 30, 2015
    917
    274
    173
    you know this horsepower screen can be deceiving--unless you wind it up just right, in just the right gear at the right grade and elevation--you may never actually see 707--I live at sea level and have seen a lot of 650-690 readings and I don't think it means anything really. at your elevation, you are probably handicapped to the numbers you are seeing--unless there is another specific performance issue like engine/cylinder miss, hesitation or check engine lights, you are probably just fine..
    just drive the shit out of it and have fun--I'm sorry, drive the HE77 out of it..
  5. Fast cat
    Sep 23, 2014
    2,255
    714
    498
    Indiana
    Top cat how much boost did you lose after doing the headers and exhaust? I was thinking that Ross (craven) told me that they seen a loss of about 2 lbs.
    Witch made me think if a person would do the full exhaust with ported heads if they could get a way with a 2.85 with out a tune. What are your thoughts?
  6. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    Last outing I had the same pulley set up as Linda and she made one lb more boost, I find it interesting that the cars that changed to ported and polished heads and a cam have no gains over stock, I don't think the heads are the issue but more in the cam that was used.
    TC
  7. Fast cat
    Sep 23, 2014
    2,255
    714
    498
    Indiana
    Who ran faster?
  8. Mopar22
    Mopar22 Gold Member
    Jan 9, 2016
    215
    98
    278
    New Mexico
    I was thinking about that and was going to call HHP to ask.
  9. Tweaked
    Tweaked Hellcat Member
    Mar 28, 2015
    98
    34
    18
    I live at 3700 elevation and yes you can swap pulleys and car will be fine without tune. However with a tune it will be faster. Been there done that.
  10. Ray Hunsaker
    Jan 26, 2015
    549
    161
    im at 4500 ft I got 9 lbs boost, changed to metco 285 pulley no tune took it out yesterday I was getting between 12 and 13 lbs boost witch im thinking a little higher than I expected. it might be the ass cold weather here will see?
  11. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    It was Linda's day,she set the Charger number 9.71 and if she hadn't gotten the boot as I did would have taken my number,;)
    TC
  12. Mills
    Mills Silver Member
    Jan 28, 2015
    712
    168
    Airdrie, Alberta
    Question: what results in more booster - ATI Lower or Metco 2.85" upper?
    Or should state perhaps: which one increases the speed of the supercharger more by pure math...not what someone has seen on their dash gauge ;)
  13. Mopar22
    Mopar22 Gold Member
    Jan 9, 2016
    215
    98
    278
    New Mexico
    What's the difficulty level to swap to the 2.85 pulley?
  14. Mills
    Mills Silver Member
    Jan 28, 2015
    712
    168
    Airdrie, Alberta
    Hit the Metco threads in the vendor section and there are some good reads and pics of guys who have done it. Fairly straight forward...not for the faint of heart
  15. Rick@Metco
    Rick@Metco Gold Member Hellcat Supporting Vendor
    Sep 7, 2014
    317
    172
    We manufacture the supercharger pulley rings in six sizes, from stock (3.35") all the way down to 2.40".
    The 2.85" pulley is generally worth 3-3.5 lbs of additional boost.
hellcat boost
