Lower grill
Discussion in 'Dodge Challenger SRT Hellcat' started by Darin Gosoir, Jan 20, 2016.
  1. Darin Gosoir
    Darin Gosoir Hellcat Member
    Oct 30, 2014
    96
    36
    18
    Minnesota
    Anyone removed lower grill? & how does it come off, I want to mount some driving lights behind the lower grill but I can't ( or haven't tried hard enough) to remove it, I removed all the screws across the top, do you have to remove the plastic belly pan under the car to get you're hand up there to squeeze the 4 bottom mounting tabs? That's what it looks like, any help would be greatly appreciated!
  2. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    I had mine out to install parking sensors, it's a *****
    You need to get under the car remove the belly pan and get in there with "baby" hands to undo the bolts, I believe there were four or five across the bottom, threaded into the speed nuts
  3. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,212
    279
    Can't help you with how to remove lower grill, but just wanted to make sure someone close to you has checked your temp to make sure you aren't sick, or made sure you aren't drinking too much for even thinking of wanting to add aftermarket "driving lights" to the lower grill of a Hellcat!! :)
    • Funny Funny x 1
  4. Fast cat
    Sep 23, 2014
    2,255
    716
    498
    Indiana
    I thought someone said they pop out easy for track days.
  5. gts_2001
    gts_2001 Gold Member
    Dec 7, 2014
    1,359
    407
    358
    Grand Rapids, MI
    Is it not correct that the main reason Hellcats don't have driving lights is because there was no room to place them on the front of the car without obstructing airflow for cooling and combustion purposes? I believe that the same holds true for the absence of the crash avoidance / adaptive cruise control sensor as well.
  6. toasteroven
    toasteroven Silver Member
    Feb 13, 2015
    225
    74
    Canadian, 300 SRT392
    • Funny Funny x 1
  7. Johnman
    Johnman Senior Hellcat Member
    Jan 6, 2015
    57
    28
    The cooling and aero for this car has been very carefully thought out, for both safety and the preservation of the engine. You mess with that at your own peril.
  8. toasteroven
    Feb 13, 2015
    225
    74
    That's exactly the justification Dodge made for the hood vent on the previous generation Charger SRT8. But the Challenger had ones much smaller (and in a different location), and the 300 SRT8 had nothing at all.
    There's also the plethora of people bolting their license plates to the lower grille opening (on both Challenger and Chargers), so I wouldn't be too concerned about a slight drop in cooling unless your daily commute involves 20+ minutes of an unrestricted road course on a track.
  9. alinjack
    alinjack Hellcat Member
    Sep 26, 2016
    73
    26
    18
    I have had mine out... you don't need to remove the belly pan... there are ' plugs' that access 7 mm.bolts. Just use an extension and they undo. The top ones are simply easily accessible screws. 10 Minutes is all it takes.... if you are really careful and slow.
  10. clickr
    clickr Silver Member
    Apr 18, 2015
    357
    116
    only if: I someone wants a HC yet isn't going to track/race the car nor drive at 160MPH, why would I be concerned with reducing the air flow by having the technology upgrade sensor in the front? Hell, mount it in the plastic part above the lower grill of the cat. seems like the HC should have the tech package over and above the 392.
2015 challenger lower grill removal
hellcat cooling lower grille
hellcat license in lower grille problems
is the lower grille of a hellcat functional
