lower pulley worth it?
Discussion in 'SRT Hellcat Performance' started by BAADCAT, May 14, 2016.
  1. BAADCAT
    BAADCAT Silver Member
    Apr 14, 2016
    141
    35
    The Great State of Texas
    I have Metco 2.75 upper going on and I planned on just pinning the stock lower, but is it worth going ahead an swapping on the ATI OD? Seems you can make just about all the boost you want with different uppers. So is it worth swapping the lower?
  2. Bstudey01
    Bstudey01 Gold Member
    Mar 26, 2016
    206
    159
    493
    Racine, WI
    I think if you start trying the really small uppers you would need to make as much boost as lets say the 2.75 upper/10% ati lower that you will start experiencing belt slip on that upper pulley. Also the ati has a damper that will help with torsional vibration.
  3. TNCHARGER
    Nov 19, 2015
    1,219
    478
    408
    The OEM upper pulley has a clutch built in that the aftermarket pulley doesnt have....I was advised if I was only going to replace one pulley it would be better to leave the upper on....and that is what I did..
  4. Bstudey01
    Mar 26, 2016
    206
    159
    493
    Racine, WI
    I
    I would probably agree with this.
    • Agree Agree x 3
  5. Jettster
    Jettster Gold Member Hellcat Car Club
    May 1, 2016
    411
    226
    Can you put on the ATI lower as a stand alone mod? Seems like it would take you from 11.5 to 13 pounds of boost-or will the computer just open the bypass as it senses over boost?
  6. TNCHARGER
    Nov 19, 2015
    1,219
    478
    408
    I believe a few have installed w/o a tune and it works...a/f is on the ragged edge though.....I would not install it on my car w/o a tune.
  7. goingsolo2
    Oct 29, 2014
    1,561
    642
    Long Island, NY
    I run only the ATI lower, and I am getting 14.5 lbs. of boost. I made 791whp (A8)...plenty of power for me. I won't touch the upper pulley either because of the built-in clutch. I read and heard that it is there to prolong supercharger life, so I am not touching it. The lower is plenty!
  8. TNCHARGER
    Nov 19, 2015
    1,219
    478
    408
    I am running only the ATI lower and only get 13psi based on the EVIC gauge..hmm
  9. goingsolo2
    Oct 29, 2014
    1,561
    642
    Long Island, NY
    Not sure....it's what we saw on the dyno, and I saw 14 on the EVIC gauge last time I punched it.
  10. TNCHARGER
    Nov 19, 2015
    1,219
    478
    408
    Could be difference in altitude and DA...
  11. DB2
    DB2 Silver Member
    Feb 4, 2015
    344
    85
    I wondered about the clutch on the aftermarket pulleys......that answers that. I dont like that you have to grind off a bolt head for the lower ATI but i think when i mod its what i will do.
    I would like low 10s for sure, but longevity trumps speed for me. I may do the lower or at the very least pin the stocker. Plus around here they are taking the rollcage issue pretty seriously at the race tracks. My personal best is 10.79 @ 128.50. Car is 4650 lb;s with me in it. It just blows peoples minds man....what a car.
  12. jvm728
    jvm728 Active Hellcat Member
    Mar 14, 2016
    200
    55
    28
    McKinney TX
    How many aftermarket twin screws have a clutched pulley
  13. Rick@Metco
    Rick@Metco Gold Member Hellcat Supporting Vendor
    Sep 7, 2014
    333
    180
    None.
    And other factory-supercharged applications like the Lightning, Cobra, GT500, ZL1, CTS-V, and Z06 use fixed (non-clutched) pulleys.
    The IHI-manufactured blower used in the HC application has been offered on performance European cars for years, and during that time many enthusiasts replaced the OEM pulleys with fixed units.
    I'm not here to convince anyone of anything, just stating some facts. There is some degree of risk associated with any performance upgrade, and the choice is yours to make.
  14. Bstudey01
    Mar 26, 2016
    206
    159
    493
    Racine, WI
    My E55 had a clutched pulley from the factory on the twin screw supercharger. Replaced with non clutched pulley and had zero issues for the 30K miles I put on it.
  15. Rick@Metco
    Sep 7, 2014
    333
    180
    ^ That is exactly the type of application I was referencing when I mentioned the European supercharged cars.
lower pulley hellcat
