Lunge forward after putting in park?
Discussion in 'Dodge Charger SRT Hellcat' started by dodgeboy, Apr 20, 2015.
  1. dodgeboy
    dodgeboy Silver Member
    Dec 31, 2014
    344
    113
    I've recently noticed that my Charger HC (A8, obviously) will lunge forward a few inches after putting it in park (and letting my foot off the brake). For instance, you pull into a parking spot, stop, put it in park, and let off the brake. Then it will lunge forward. It does this on level ground, and with enough enthusiasm that I think it might even do it on a slight incline. It's not just slowly rolling until it hits the park pin. It's got a little force behind it.
    I recently had my transmission replaced (completely unrelated issue), and I don't recall it doing this before I had it replaced. But I only owned it for 8 days before I took it to the shop, so I may have just not noticed it. I can't think of what would be causing this, whether it be related to the transmission swap or not.
    Does this happen to anyone else?
  2. Lord Hellcat
    Jan 6, 2015
    1,610
    727
    UK
    Does not sound right to me. Sure a slow roll till it hits the lockout pin but not a lunge. What happens if you put it in park. Hold the brake whilst you turn the engine off ?
  3. dodgeboy
    Dec 31, 2014
    344
    113
    Good question. I'll try to remember to do that next time I drive it (the weather is rough right now).
  4. Dances With Empties
    Dances With Empties Gold Member
    Nov 10, 2014
    1,283
    373
    368
    Where rednecks are nervous of hillbillies
    That doesn't sound even remotely acceptable. I don't think I would trust it until it goes back to the dealer. A runaway 'park position' is not something I'd like to deal with....
  5. noboost4you
    noboost4you <Insert witty title here>
    Oct 30, 2014
    554
    151
    Cleveland, OH
    I'm experiencing the same, dodgeboy. To prevent a massive lunge, I ease out of the brake once in Park rather than dumping the pedal. It can be pretty forceful if you dump the brake pedal, but at no time have I ever thought it would continue forward.
  6. SRT_HC_707
    Jan 1, 2015
    4,938
    1,432
    70.196059, -148.559760
    Post a video of this please....
  7. CanuckH3llKat
    CanuckH3llKat Silver Member
    Feb 18, 2015
    258
    57
    Calgary
    I've got the same thing. It does lunge forward a bit after put in Park. Have to be careful when parked that you are far enough away from a parking barricade or wall so you don't scratch, I already got a small one on the front spoiler from that happening.
  8. HOONAGN
    HOONAGN FLOOR IT!
    Jan 28, 2015
    260
    134
    Fullerton CA
    Lunging like that does not sound right at all. Granted, I use the parking break religiously but when I park mine flat and don't use it there's no lunge. What RPM is it spooling at in park? Does it leach down after?
  9. gilgamesh
    gilgamesh Silver Member
    Sep 20, 2014
    356
    120
    That's weird. Mine has never done this.
  10. jjtt
    jjtt Hellcat Member
    Apr 2, 2015
    30
    2
    Same here.
  11. upnorthstar
    upnorthstar Silver Member
    Mar 2, 2015
    476
    122
    Same here...if you hold the brake for a few seconds after shifting into park it won't...I think its the torque converter
  12. dodgeboy
    Dec 31, 2014
    344
    113
    It barely lunges at all if I shut the engine down and wait a couple seconds before releasing the brake. I'm going to train myself to do this from now on. It also doesn't lunge (in either direction) if it was last in reverse.
crown vic lunge forward park
