M6 second gear
Discussion in 'SRT Hellcat General Discussions' started by sahak, Mar 7, 2016.
  1. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    So I have 3,700 miles on my challenger hellcat so far and the only problem I've been having is my second gear. Sometimes it won't go in at all and sometimes if it does go in when I release my clutch it pops out of the gear. Anyone have an idea of what this could be or should I just take it to the dealer?
  2. BlackbirdWS6
    BlackbirdWS6 Gold Member
    Jan 28, 2015
    389
    155
    Definitely take it to the dealer. Sounds like something has gone bad in the trans. If it was the clutch, I would assume you would have trouble in more than one gear. Does it do it all the time or infrequently? Hot or cold or doesn't matter?
  3. Dragon
    Dragon Gold Member
    Oct 16, 2014
    658
    230
    AZ
    no trouble with mine......
    take it to a dealer
  4. bighit2883
    bighit2883 Gold Member
    Mar 15, 2015
    1,389
    496
    358
    Could it possibly be the skip shift is blocking you out? Also when i drag raced with my m6 i had issues with it not wanting to go into 2nd and i think it was just due to it bunching up.
  5. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    It happens all the time and it doesn't matter if it's cold or hot. And only 2nd gear
  6. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,981
    1,422
    498
    Virginia
    Sounds like shift lock (certain acceleration profile wants you to shift from 1st to 4th) locking you out of 2nd gear. Read the manual. It's a real PITA; somebody's better idea for saving fuel. I believe there is a light on the dash that indicates the shift lock out. It's been around a long time...was that way in my 2010 Challenger R/T M6.
    You can double clutch it to work around the shift lock out or buy one of the skip-shift by-pass plug ins.
    There are better descriptions on this forum.
    Speedlogix Skip Shift Eliminator 09-15 Challenger
  7. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    Ya I've heard about that but why would it pop out of gear after its in?
  8. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    I don't think it's the skip shift because when it happens it doesn't want to go in 3rd either and if it does go in 2nd it pops out after I let go of the clutch
  9. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,739
    504
    423
    Henderson, NV
    Sounds like bad syncros. Uncommon with this trans but happens. Warranty..
  10. graybear
    graybear Silver Member
    Nov 4, 2015
    103
    62
    168
    The skip shift kicks in below 20 mph. Try shifting a few times with speed over 20 mph and see what happens. You can get a fix for the skip shift.
  11. natesrt
    natesrt Silver Member
    May 9, 2015
    200
    85
    178
    This used to happen to me on my 392. I felt it sometimes on the HC also being difficult to get into 2nd. The trick I've found that seems to work is to hold the lever to the left a bit hard while pulling down into 2nd.
  12. Toolman_42
    Jan 26, 2015
    2,981
    1,422
    498
    Virginia
    Are you getting the dash light indicating that you are in skip shift mode? If you have tried to force it into 2nd gear you might have bent or mis-aligned something within shifter mechanism. It's a mechanical design to keep shifter from entering 2nd gear. If you've jammed/forced it before, you might now be able to get partially into gear but not completely in and thus it pops back out of gear. It's not an old H pattern 4 speed shifter, it's now rod length and rotation that controls the gear selection
    Any problems downshifting into 2nd gear? If it goes into 2nd without problem on the downshift then more than likely the skip-shift mechanism has been balled up. Time to go to the dealer and find the root cause.
    When you get home from the repair, immediately install the skip shift eliminator...one of the best $20 you'll spend. A tuner can also delete the skip-shift but since the PCM is locked, the harness plug is a much cheaper and effective alternative.
  13. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    Nope it even happens when I shift from 1st to 2nd almost at redline
  14. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    Yes it mostly pops out when I'm down shifting it from 3rd to 2nd
  15. sahak
    sahak Silver Member
    Jan 17, 2015
    269
    70
    I'll try that next time
shifting my m6 2016 hellcat challanger
what rpm do shift your 2016 hellcat challanger with m6
