M6 Skip Shift Feature
Discussion in 'Dodge Challenger SRT Hellcat' started by usmc341, Nov 15, 2015.
  1. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,668
    484
    368
    Henderson, NV
    I've done some searching but rather than go through bunches of pages can someone please give me a quick overview of how the skip shift works? Does it lock you out of 3rd gear below a certain rpm, light throttle, etc.? I don't believe my Shelby had that, or maybe I just didn't notice.
    Thanks
  2. Sublimecat
    Sublimecat Silver Member
    Oct 2, 2014
    903
    323
    173
    Akron, Ohio
    Transmission forces you to go from 1st to 4th below a sped of somewhere around 20mph. If over ~20mph you can go to second or third. I never find myself in the range where it affects me!
  3. GreenPirate
    GreenPirate SRT Hellcat Supporter Gold Supporting Member
    Apr 10, 2015
    168
    65
    178
    Grimesland, Eastern North Carolina
    Precisely...only a problem if you are in a neighborhood with a strict speed limit, or you are waiting for the oil temperature to come up, first drive of the day.
    Once in a while, I've been not "on my game" and the skip shift interferes.
    I'll be installing a "skip shift eliminator" next time the car is on a lift for service.
    Gap
  4. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,668
    484
    368
    Henderson, NV
    Agreed. I wouldn't be granny shifting a Hellcat anyway. What's the point of having a manual if you don't let 1st gear sing? Thanks!
  5. Hemi Rocket
    Hemi Rocket Gold Member
    Sep 27, 2015
    1,532
    489
    Albany NY
    Yeah if you rev out in first it won't activate. It has a solenoid that locks out second gear when you driving it easy... forcing you to pull it back into 4th rather than 2nd. Kinda stupid... but it was for gas mileage. They make a skip shift eliminator... that plugs into solenoid harness that bypasses this feature. They are fairly cheap.
  6. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,668
    484
    368
    Henderson, NV
    So, if you hit 4th at low speed does the engine lug? Seems like it wouldn't be good for it.
  7. FreightTrain
    FreightTrain Comfortably Numb
    Sep 13, 2014
    3,514
    1,428
    818
    Endless Mtns of Pa
    if it activates when you hit neutral and it shoves the stick over, you can quickly u-turn the shifter and select any gear
  8. GreenPirate
    Apr 10, 2015
    168
    65
    178
    No, this car has enough torque that 4th gear has plenty of go. It's just that one expects the torque multiplication of second, and instead is surprised by "flat" acceleration. Not what one needs in a bad*** muscle car!
    GP
  9. Hemi Rocket
    Sep 27, 2015
    1,532
    489
    Albany NY
    It won't do that if you're driving aggressive... but agree it's a PITA.
  10. FreightTrain
    Sep 13, 2014
    3,514
    1,428
    818
    Endless Mtns of Pa
    well it doesnt lug but its bogged down and takes a bit to climb out of it... she idles a 8mph in first so u can do the math for hitting 4th at 20mph
  11. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,668
    484
    368
    Henderson, NV
    OK, found this on my owners DVD (yes I should have looked there first) :-(
    1–4 Skip Shift
    There are times when you must shift the transmission directly from first gear to fourth gear instead of from first gear to second gear. This is to help you get the best possible fuel economy from your vehicle. This occurs when the engine coolant (antifreeze) is higher than 106°F (41°C), vehicle speed is greater than 19 mph (30 km/h) but less than 21 mph (34 km/h), and the transmission is in first gear, and the accelerator is at ¼ throttle or less.
    After you shift the transmission to fourth gear, you can press the clutch in and shift to another forward gear.
    So if I'm reading this correctly, you would have to shift at EXACTLY 20 mph for the feature to activate? Also, it appears that if I'm driving after a cold start, it also will not activate. So, if I wanted to granny it to let the coolant come up to temp, all I have to do is shift at 18 mph or less. Doesn't seem too obtrusive at all.
  12. Harley88
    Harley88 Gold Member
    Nov 15, 2014
    1,254
    365
    ^^^ this feature will get you killed in my opinion.
    Your ganna grab the gears pulling out in traffic and... It ain't ganna happen!
    The shift isn't there.. I hated it.
    The "skip shift eliminator" or a cpu tune will delete this "big bro" feature...
  13. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,668
    484
    368
    Henderson, NV
    Yes in that scenario I could see it causing some problems..
  14. FreightTrain
    Sep 13, 2014
    3,514
    1,428
    818
    Endless Mtns of Pa
    its more like a window of 19-22mph... i agree with harley that the big brother feature could be dangerous
  15. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,668
    484
    368
    Henderson, NV
    Thanks for all the input. I'll probably be getting an M6 real soon, so I want to get as much knowledge as possible.
