Magic offset number for 11" wheel rear
Discussion in 'SRT Hellcat Wheels and Tires' started by BAADCAT, May 19, 2016.
  1. BAADCAT
    BAADCAT Senior Hellcat Member
    Apr 14, 2016
    141
    35
    The Great State of Texas
    What's the magic offset number for 11" rim in the rear? I know the 10.5" is 27mm. I would like to squeeze that extra half inch in there if I can.
  2. SRT HC
    SRT HC BANNED
    May 11, 2015
    879
    320
    Jacksonville, FL
    Easy to calculate if you know the limits on back space and front space
  3. Tire God 2.0
    Apr 24, 2016
    381
    95
    My guess would be 15mm.
  4. SRT HC
    SRT HC BANNED
    May 11, 2015
    879
    320
    Jacksonville, FL
    Well 20mm gives you the same back space as 27mm is on a 10.5 inch wide wheel. But that means you'll have an additional 1/2 inch of front space
  5. BAADCAT
    Apr 14, 2016
    141
    35
    Yeah that may be the problem. Don't want them poking out past the fenders and it's been lowered so make it that much tighter. probably better to stick with the tried and true 10.5/27mm. Thanks guys
  6. Booky
    Booky Gold Member
    Feb 6, 2016
    924
    604
    763
  7. Tire God 2.0
    Apr 24, 2016
    381
    95
    I'm sorry I thought it was an 11.5" rim. Probably right around 20mm.
  8. DGatzby
    Jan 16, 2015
    3,401
    1,783
    598
    Twin Cities, MN
    • Like Like x 3
  9. theRealJA105
    theRealJA105 Silver Member
    Oct 23, 2015
    279
    I have 11" at 26mm offset with the 305/35R20 Pirrellis. Had to heat up and shape the inner liner and the sidewall is still sticking out from the fender a little bit. I wanted to lower the car, but not now with the sidewall out past the fender.
  10. DGatzby
    Jan 16, 2015
    3,401
    1,783
    598
    Twin Cities, MN
    That car is 1/2" lower in the back and could go lower, no problem. The beauty of that offset and the size of the 305/35 is it fits! I have tried two different types of 315/35's on 10.5" from 22-25 mm and from OEM height to -1/2", not good. Interesting is I have seen one member's car, full slammed to the lowest KW height, 25mm offset, 10.5", Nitto NT05, with my own eyes he has nearly 1/2" gap between tires and the liner!
    The point of showing the 11" at 21mm is to show the Bravado as purchased requires little or no mod and the 305/35 fits within the fender. Perfect for a drag radial set.
  11. BAADCAT
    Apr 14, 2016
    141
    35
    Billet did 315s on the 10.5 with 27mm and lowered with no problems.
  12. Jettster
    Jettster Gold Member Hellcat Car Club
    May 1, 2016
    371
    191
    Fitting 11's must take some massaging of the inner fender for sure-I ran 10" OE Replicas with 18mm offset to track last night and could hear slight rubbing on inner fender when making a sharp turn. Running 305/35/20 MT's.
  13. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    697
    234
  14. B5HLCAT
    B5HLCAT Rookie
    Jun 11, 2016
    25
    6
    South Louisiana
    Do you think that the Bravado Tribute 20 x 11" w 305/35/20 will fit a 2006 SRT8 Charger the same or close to it?
  15. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,170
    576
    413
    PASADENA, CALIFORNIA
    Did you take the wheel off and see where it was rubbing? In my experience the tire will rub at the bottom rear of the tub first. The wheel tub mod I posted will take care of this problem without hacking the wheel tub.
challenger with 20x10 18mm offset
charger hellcat replica wheels 11-20
hellcat magic
