Metco SC Pulley installed
Discussion in 'SRT Hellcat Performance' started by Billet Hellcat, Sep 21, 2015.
  1. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,066
    649
    413
    So Cal
    Sunday I installed the Metco SC 2.75 SC Pulley. I would say you should be a experienced mechanic to perform this install. I did not have a hoist to pull the SC so I did it a little different. Approx time 3-4 hrs. This is just the way I did it so I did not have to completely remove the SC and put it on a bench.Tuning will be done by HHP/ Hemituner ;)
    • Winner Winner x 10
    • Like Like x 7
  2. owenspackman
    owenspackman BritishCat
    Feb 11, 2015
    975
    516
    368
    Charleston SC
    This is great! Thanks so much for taking the time to do the write up. Looks like you did a great job! Any special requirements on the lube for the seal?
    • Like Like x 3
  3. DB2
    DB2 Silver Member
    Feb 4, 2015
    342
    83
    No catch can, is that a fair amount of oily residue in there or am i seeing things?
    Nice job man!
  4. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    Looks great,, one picture shows three bolt holes,, what are they.. Second, did you do anything with the coolant, line vacuum release or seal??? And have you driven the car with the new pulley...is this your only mod???
  5. Billet Hellcat
    Dec 2, 2014
    1,066
    649
    413
    So Cal
    Thanks no I just used. Light white lithium grease they say light engine oil it's just to prevent damaging the seal when putting the top cover back on.
    Yes there was some oil most coming from the drivers side not the side most have there catch can on ?? I'm going to order one from BT today.
    HC1. If your talking about the 6th pic there are 3 o-rings for the top cover make sure they don't get missed.
    Nothing on the SC coolant it is self contained I did not take the hoses off.
    I did drain the engine coolant because I thought I could take the inlet nose off and slide it forward without lifting the SC but you can't get to the bottom middle bolt. So you don't need to drain any coolants if your not removing the SC to put on a bench. Then you would need to remove the 2 hoses on back of the SC & remove the fuel line.
    Yes I drove it after the install but I am waiting for the PCM from AJ right now yes stock air box & exhaust.
  6. Rick@Metco
    Rick@Metco Gold Member Hellcat Supporting Vendor
    Sep 7, 2014
    331
    178
    Just one point for those considering this swap...The Metco supercharger pulley ships fully assembled as part of the final QC, but as indicated on the box it must be fully disassembled prior to installation. The pulley hub is installed on the shaft by itself, with the provided threadlocking compound applied to the threads. Once tightened, the ring and front cover are re-installed, using the same threadlocker on the ring and cover fasteners.
    What length supercharger belt did you use?
    This is great info...Thanks very much for sharing.
    • Useful Useful x 2
  7. Ray Hunsaker
    Jan 26, 2015
    603
    198
    great write up do you happen to have a pic of the back side of the snout? just curious what's there to get ahold of when removing pulley.
  8. Rick@Metco
    Sep 7, 2014
    331
    178
    • Useful Useful x 3
  9. Billet Hellcat
    Dec 2, 2014
    1,066
    649
    413
    So Cal
    Rick I did not receive any thread lock in my box ?? I did use blue not sure what you recommend ? Also there were no torque specs for the pulley or bolts ? But I did install the hub first
    The belt I have on is at the min of the working gauge I ordered another belt I should have Wed / Thur I will post up the part # soon as I test fit it ok Thanks.
  10. Ray Hunsaker
    Jan 26, 2015
    603
    198
    thanks Rick, now I understand.
  11. Rick@Metco
    Sep 7, 2014
    331
    178
    We recommend blue threadlocker on the shaft threads, and also the single bolt for the pulley cover. I usually include a single-use container of threadlocker with each pulley, but it seems I forgot. Sorry about that.
    The pulley ring fasteners and pulley cover fastener are not torque-sensitive, and can simply be tightened securely.
    It sounds like you did everything just right.
    Thanks again for the post...We all appreciate it.
    • Useful Useful x 2
  12. Supercharged_Fun
    Supercharged_Fun Gold Member
    Jun 25, 2015
    917
    368
    This is awesome.
    Will be very interesting to see the results, especially with stock air box and headers and so on.
    Good luck and keep us posted.
  13. owenspackman
    Feb 11, 2015
    975
    516
    368
    Charleston SC
    hey Jeff,
    any luck with the torque specs yet? We'll be installing the pulley Friday morning!
  14. hellcat1
    Sep 27, 2014
    10,672
    2,033
    You guys are making me jealous
    • Funny Funny x 1
  15. Billet Hellcat
    Dec 2, 2014
    1,066
    649
    413
    So Cal
    Yes I will get on it and get it to you today ;)
hellcat pulley and air intake result
hellcat sc pulley
hellcat supercharger bolt torqu sequece
metco hellcat pulley hp gain
metco pulley hellcat
metco pulley hellcat forum
metco pulley installation onhellvat
torque spec for supercharger pulley on a hellcat
