More info about the hellcat engine in detail
Discussion in 'SRT Hellcat General Discussions' started by Carnage, Oct 6, 2014.
  1. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
    Wardauto.com did an article so I'm copying and pasting the article here for easier access
    In my opinion this gets me worked up in a good way, love all the details, enjoy!
    Hemi Hellcat Engine Fully Loaded
    Tom Murphy
    Oct 06, 2014
    Chrysler engineers developing the most powerful muscle-car engine in the U.S. needed to incorporate bigger fuel lines, more cooling, a stiffer crankshaft and crushed diamonds for more friction.
    [​IMG]
    Firing pressure in Hellcat cylinder at peak power approaches 21,000 lbs.
    AUBURN HILLS, MI – An engine that almost never stops consuming fuel while generating 707 hp in the 2-door Dodge Challenger SRT Hellcat and the 4-door Charger creates extreme internal loads that can cause catastrophic failures if not offset properly.
    Bulkheads in the block needed stiffening. Additional cooling was vital. Alloy pistons had to be forged (like those of the SRT Viper) for additional strength rather than cast. Fuel lines needed to be bigger. Crushed diamonds were embedded in steel washers to deliver the necessary friction to power the supercharger.
    It’s because of this painstaking attention to detail that Chris Cowland, Chrysler’s director-Advanced and SRT Powertrain, grows prickly when defending the validity of the horsepower and 650 lb.-ft. (881 Nm) torque rating.
    “If you see any of this crap in the press that it’s not a 707-hp engine, it’s absolutely untrue,” he says. “SAE (officials) were here; they witnessed it. No one should be doubting that’s the real number.”
    Most blocks for new engine programs today are made of aluminum. The Hellcat, which is machined and built in Saltillo, Mexico, requires cast iron.
    “It’s important to keep the bores as round and cylindrical as we can, and an iron block really helps in that respect,” Cowland tells journalists during a Hellcat deep dive here.
    “If we switched from iron to aluminum, we couldn’t get the bulkhead stiffness we need under those firing loads,” he says.
    “Of course, we can redesign the engine to run under aluminum, but we would have to spread the bore centers and would have to change lots of things within the engine. We always started this program with the premise that we wanted it to be based on the Hemi architecture.”
    Apache V-8 With Shorter Stroke
    The high loads result from a 1,595-psi (110-bar) firing pressure in the cylinder at peak power. “Do the math, and that’s 93 kilonewton or 21,000 lbs. (9,526 kg) of load,” Cowland says. That’s the equivalent of piling 4.5 Challenger SRT Hellcat coupes on the piston every time the twin spark plugs ignite the air-fuel charge.
    “They’re the loads that go through the connecting rods, through the pistons, down into the crank train, through the main bearings and get reacted in the cylinder block,” he says.
    The basis for the Hellcat was the current 6.4L naturally aspirated Hemi (codename Apache), but that engine has a longer stroke of 3.72 ins. (94.6 mm). The Hellcat has a 3.57-in. (90.9-mm) stroke (and loses some displacement) because the team needed to stiffen the crankshaft to accommodate the heavy loads.
    “The reduction in stroke was based around increasing stiffness of the crank,” Cowland says.
    The alloy crankshaft is made from the same forging as in the Apache engine, with a number of modifications. For instance, bearing profiles are unique to the Hellcat.
    “Some people ask, ‘Can I just run an Apache long-stroke version of the crankshaft?’” The answer is no. “Even down to micron levels, there are changes in this crank that are necessary to withstand the really high peak firing pressures and loads we have.”
    The Hellcat and Apache blocks appear to be identical. But flipping them over reveals significant changes to the Hellcat unit to incorporate additional cooling galleys to help stabilize the block at high engine speeds.
    Computer analysis revealed high thermal loadings atop the cylinder would cause the shape of the cylinder bore to distort, breaking down oil on the bore walls. “So we flow increased coolant and get improved cooling around the top of the bores,” Cowland says.
    The Hellcat program required much more than merely slapping a supercharger on an Apache. True, the engines share fasteners and other mundane components, and the powder-forged connecting-rod bolts carry over. But based on dollar value, 91% of the Hellcat V-8 is all-new to handle the loads, he says.
    Alloy Cylinder Head Heat-Treated
    The cylinder head employs variable valve timing and incorporates the same valve angles and valve sizes as the Apache. But cam profiles are optimized for the boosted Hellcat, and the new head requires 356-grade aluminum alloy with a special heat treatment while most Hemis use standard 319-grade aluminum.
    “The thermal conductivity of 356 is significantly better,” Cowland says. “It enables us to take heat from the combustion chamber. It stops engine knocking, and we get the performance we need.”
    Intake valves are hollow so they are lighter, and exhaust valve stems are sodium-filled, allowing heat to be drawn away from the valve head.
    Cylinder deactivation, marketed by Chrysleras the Multi-Displacement System on other Hemi engines, doesn’t appear on the Hellcat due to the complex control strategies associated with the supercharger.
    Cowland says the team could have found a way to add MDS to the Hellcat but didn’t have the time. The program began in 2011 and stalled for four months due to a financial hiccup for the automaker.
    Like other pushrod Hemis, the Hellcat relies on tried-and-true port fuel injection. The injectors spray 38.4 cu.-ins. (630 cc) of gasoline per minute. “If you put all eight injectors into a pint (0.5 L) glass, they would fill it in 7 seconds at rated power,” he says.
    Direct injection could have improved volumetric efficiency, but port injection helps keep the intake valves cool. On DI engines, intake valves run hotter, requiring a more robust valve material, Cowland says.
    In addition, high-pressure direct injection requires a pump, which leads to parasitic losses. The Hellcat would require two DI pumps, which would increase cost and create packaging problems, he says.
    Blowing 30,000 Liters of Air
    The twin-screw supercharger, supplied by IHI from its plant in Shelbyville, IL, truly sets the Hellcat apart from the naturally aspirated Apache. The only other Chrysler vehicle to use an IHI supercharger was the Chrysler SRT6 Crossfire coupe.
    Driven from the front of the crankshaft, the blower produces 11.6 psi (80 kPa) of maximum boost and displaces 0.54 gallons (2.4L) of air each time it turns over. At an engine speed of 6,000 rpm, the supercharger is spinning at up to 14,600 rpm. There’s a 5-lobe rotor and 3-lobe rotor turning in tandem, and the secondary rotor spins at just under 20,000 rpm.
    Every minute, the blower moves 6,810 gallons (30,000 liters) of air. “If you are sitting in an office 10 ft. by 13 ft. with a standard 9 ft. ceiling (3 m, 3.9 m, 2.7 m), it would empty that office of air in one minute,” Cowland says.
    The team needed a high coefficient of friction for washers on the camshaft drive sprocket to prevent any slipping as the supercharger spools up. The fear was that conventional steel-on-steel washers would slip, so the engineers tried crushed industrial diamonds embedded on the steel washers. The result is a coefficient of friction that is three times higher.
    “It can withstand the resistance of 80 hp from the supercharger without slipping,” Cowland says, adding that the washers cost about $2 or $3 each. “We can’t afford for this to slip.”
    When cruising at moderate speeds, a bypass valve routes air around the supercharger to improve fuel economy. When the driver lifts off the accelerator, a one-way clutch prevents inertia from the supercharger from driving the engine. Torque can be transmitted in only one direction.
    The blower has a separate cooling circuit with two air/coolant heat exchangers that keep air temperatures below 140º F (60º C).
    Cowland offers a word of caution to enthusiasts hoping to build their own Hellcat engines without using the cooling system. “If you want to generate 707 hp and you don’t take the coolant system with it, it won’t work,” he says.
    Chrysler likes to boast of the Challenger Hellcat’s rated fuel economy of 13/22 mpg (18-10.6 L/100 km) city/highway with the 8-speed TorqueFlite automatic transmission. With the 6-speed manual, the highway rating dips to 21 mpg (11.1 L/100 km).
    A 707-hp engine in a car with a starting price below $60,000 is impressive, and it’s done a great job boosting the visibility of the Dodge brand. But it won’t do much to help Chrysler comply with pending CAFE requirements. Plus, gas-guzzler taxes on the car can reach $2,100.
    • Like Like x 4
  2. Tammie
    Sep 11, 2014
    13,484
    4,561
    1,223
    Washington
    AND THAT is why the Mustang version of the supercharger will NEVER be in the same class as the Hellcat!!! Great article HCDC, thanks for posting it.:)
  3. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
    Yes Ma'am it is my duty to inform the public and our members what really happens under our hellcat hoods. The competition has to fear all of us lol
  4. ChallengerDad
    ChallengerDad SRT Hellcat Moderator Staff Member Gold Supporting Member
    Oct 5, 2014
    1,469
    627
    563
    Bethlehem, New York
    Great technical information!
    My only qualm with the information in the article is that the numbers for fuel consumption and air passage "assume" that the engine is under full throttle. They don't specifically state that in the article.
    I've been digging for more information on the engine specs (like oil capacity and oil filter number), but have only found that the engine uses 7.5 US quarts of 0-W40 synthetic oil specifically engineered by Pennzoil for this application. Just wondering if my 6.1L oil filters will be useable on this engine or not. I'm a bug about oil and filters and only use NAPA gold / WIX, MOPAR, or Mobil1 oil filters. I'd hate to give away five filters sitting on my garage shelf..... :(
  5. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
    Yeah I see what you mean. The engine doesn't have MDS like it was planned but that's ok, true fuel injectors work too.
    I think a member or two on here has the actual hellcat manual, they may have specifics on the oil and capacity.
    I have a 5 gallon of Royal Purple API Licensed for my super bee that I have used for only one oil change with the RP oil filter cap but will probably end up giving the rest away considering hellcat will be the main.
  6. ChallengerDad
    Oct 5, 2014
    1,469
    627
    563
    Bethlehem, New York
    I've been looking for a manual online, but haven't had any success finding one yet. It would be GREAT to have that info if that member is willing to share! :rolleyes:
  7. Tammie
    Sep 11, 2014
    13,484
    4,561
    1,223
    Washington
    WHAT?? Your not going to get rid of your Super Bee are you? I thought you were keeping it and your fiance was going to trade in the 6 cyl? I hope you get to keep yours and get the Hellcat too.:)
  8. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
  9. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
    Not yet I really love it. Until Charger hellcat comes out tho. My fiancé said keep it for a while longer.
  10. Tammie
    Sep 11, 2014
    13,484
    4,561
    1,223
    Washington
    She really is smart!! :)
  11. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
    Haha thanks Tammie
  12. perry
    perry Active Hellcat Member
    Oct 4, 2014
    291
    73
    28
    ANACONDA MT.
  13. perry
    Oct 4, 2014
    291
    73
    28
    ANACONDA MT.
    very interesting
  14. perry
    Oct 4, 2014
    291
    73
    28
    ANACONDA MT.
    thank you sir
  15. texasrevy
    texasrevy Silver Member
    Oct 18, 2014
    287
    128
    Amarillo TX
    OMG!!! I want mine so bad!
hell cat cooling system
hellcat cyclinder deactivation
hellcat engine made in mexico
hellcat engine production
hellcat engine pushrods
is hellcat engine cast iron
is the hellcat engine a push rod engine
where is hellcat engine made
